Transmission R-A60 manual transmission information . Your 6 speed transmissiom (WRITE UP )
Discussion in 'Technical Chat' started by gearcruncher, Aug 2, 2014.
  1. Mar 4, 2023 at 11:20 AM
    #181
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Hmmm…
    I have a stupid question for @gearcruncher or anyone else who might know!
    Is there anyway the Toyota R-155 5 speed behind the 2.7L I4 2TR-FE can be attached 4.0L V6 1GR-FE?
    Bell housing to engine or mount the R-A60 bell housing to the R-155 transmission?
    Now remember I said stupid question…
    :anonymous:
    Thanks in advance!
  2. Mar 4, 2023 at 12:09 PM
    #182
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Hayrider[QUOTED] and Torspd like this.
  3. Sep 23, 2023 at 10:19 AM
    #183
    knoagreen
    knoagreen Well-Known Member
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Does anyone know the part numbers for the bolts that go through the bell housing and into the block? One of my 14mm bolt heads is stripped, I’d like to order a replacement before I drill it out.
  4. Sep 25, 2023 at 7:08 PM
    #184
    Jeff Lange
    Calgary, Canada
    90080-11426
    Jeff
    knoagreen likes this.
  5. Jun 16, 2024 at 8:14 PM
    #185
    Valvecoverlover
    Valvecoverlover New Member
    I have a question. I’ve got a 2010 Prerunner and wanting to swap to 6 speed. I found a 2008 x runner and don’t mind keeping it 2 wheel drive and would to use the transmission from that. I was wondering if anyone has done it before and what problems I might run into. I’ve been trying to research parts and compatibility but not sure if the drive shafts or mounts will match up. I’m expecting to have to find a crossmember and maybe swap out drivesaft pieces from either one. If anyone knows more that would be helpful.
  6. Jul 27, 2024 at 6:47 PM
    #186
    MisterM70
    MisterM70 Well-Known Member
    Jack
    Mesa, Az
    2012 Super White-TRD OR SB
    -Icon remote resi 2.5 extended travel coil overs Front and Rear - Icon Billet UCA's - Icon progressive AAL's - Toyo 255/85/16 - Bud Built Aluminum 5 Piece Skids-
    Ok..I'm confrucketed now. 2012 v6 4x4 6 speed. I did my clutch and TOB in January. I'm getting a squeaking/squealing while in neutral now. If I push in the clutch it goes away.
    Do I need to adjust it or lubricate the input shaft behind the TOB?
  7. Aug 2, 2024 at 9:39 AM
    #187
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Double check the adjustment of the clutch pedal and if that doesn't do anything, turn up the radio and learn to live with it. It's brand new, you know it's new. They will start to squeak at some point, but that doesn't mean it's necessarily failing or in jeopardy of failing or that you did something wrong. Its what they do. Continue to monitor it and it gets worse or becomes a grinding noise, investigate further.
  8. Aug 2, 2024 at 4:20 PM
    #188
    MisterM70
    Jack
    Mesa, Az
    Thanks for the input. Slight pedal pressure makes it stop. I was curious if the OP was correctly stating that the TOB shouldn't be spinning in neutral.
