Transmission Service
Discussion in '1st Gen. Tacomas (1995-2004)' started by Holzcman80, Jan 5, 2017.
  1. Jan 5, 2017 at 7:15 PM
    Holzcman80
    Holzcman80 [OP] Well-Known Member
    Ian
    2003 Tacoma Double Cab SR5 TRD
    ok so I want to get my transmission fluid changed. I have a 2003 Tacoma v6 auto with 185,000 miles. What type of change/flush should I do and what fluid? Thanks
  2. Jan 5, 2017 at 7:31 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    It should say on the automatic transmission dipstick. I have an 04 Tacoma DC 4x4 auto and mine says to use Toyota Type 4 fluid. People on here mostly say to do a drain & fill rather than a complete flush. Since it could loosen up stuff and plug up your lines.
    Toyota Lexus ATF Type T-IV Automatic Transmission Fluid OEM, 1 Quart https://www.amazon.com/dp/B009W391PQ/ref=cm_sw_r_cp_api_jbXBybDQ986TQ
    Clearwater Bill and Mush Mouse like this.
  3. Jan 5, 2017 at 7:54 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    I did just a drain and fill, then a few months later a drain and fill again. It's not perfect, but it's easy and not messy. Then in about 30k, drain and fill again.
    ZachPrerunner, twp and ramonortiz55 like this.
  4. Jan 5, 2017 at 8:03 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use maxlife...cheap at Walmart and Toyota WS compatible
  5. Jan 5, 2017 at 10:38 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I dropped pan at 200k and washed it out really good. Surprisingly it was pretty clean. Going to do a drain and refile at 250k.
  6. Jan 6, 2017 at 8:02 AM
    prayzhm
    prayzhm Active Member
    Bob
    2004 Tacoma Dbl Cab TRD
    I did a Trans flush at 97k and put in Max Life ATF and my DC shifts like a dream. I'm gonna probably continue the flush cycle in the future to stay on top of a smooth running trans.
  7. Feb 26, 2017 at 5:51 PM
    TacoTRDSport4.0
    TacoTRDSport4.0 Member
    2010 burgundy red Tacoma TRD Sport 4.0
    Hey guys when you switched over to the max life, did you do a full 11-13 quarts drain then flush and then add the 3.2 quarts plus filter? I'm having problems when turning that my transmission is slipping out of gear and to neutral than a couple seconds later catching again. You think it maybe just a little low?
  8. Feb 26, 2017 at 6:13 PM
    757yotas
    Virginia
    2007 TRD Sport
    I just drain and fill every once and awhile with it. Never did do any flushing. Flushing is bad
  9. Feb 26, 2017 at 9:04 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    If you pull the pan and clean it out and then flush its ok. If you flush first you stir up all the sediment in the pan.
    Clearwater Bill likes this.
  10. Feb 26, 2017 at 10:17 PM
    TacoTRDSport4.0
    Awesome thanks 757yotas and mechanicjon, I did exactly what you said mechanicjon I think I'm just low a little bit. Do one of you have a 4.0 by chance? If so how many quarts do you put in? I put in what Haynes told me and it was roughly over 3 quarts
  11. Feb 26, 2017 at 10:28 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    FSM fill instructions. Sounds low on trans fluid.
  12. Feb 28, 2017 at 3:59 PM
    TacoTRDSport4.0
    Yep I was a quart too low, shifts like butter on a knife now. Also this valvoline max life is way better than the WS fluid!
  13. Feb 28, 2017 at 4:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Curious how you know ?
  14. Feb 28, 2017 at 4:44 PM
    TacoTRDSport4.0
    Just have noticed a difference when shifting gears also going from park, neutral, drive and down to 2L the truck doesn't want to hesitate and then jump off the line when it catches the gears. The truck just shifts smoothly now.
    gearcruncher likes this.
  15. Feb 28, 2017 at 4:45 PM
    TacoTRDSport4.0
    And by all means my transmission fluid when I drained, it was still a nice clear red so it was not looking like it desperately needed changing.
  16. Feb 28, 2017 at 5:15 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    There's been some studies done on it. Lots of info in the trans section
  17. Feb 28, 2017 at 8:02 PM
    757yotas
    Virginia
    2007 TRD Sport
    Cuz its Valvoline duh :boink:
