Transmission shutter/clunk issue.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dellosa89, Dec 24, 2010.
  1. Dec 24, 2010 at 6:12 PM
    Dellosa89
    Dellosa89 [OP] Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Im wondering if anyone has an idea whats wrong with my truck. I have a 07 TRD OR prerunner with the 4.0 and 5 speed automatic trany with 69k miles. I notice about 3 days ago my truck seams to have started having transmission problems.
    When im accelerating easy shifting from 2nd to 3rd my truck starts to shake and clunk almost like hitting a rough piece of road. Also when im cruising on the freeway ~65 to 70 mph and i barely get on the gas my truck down shifts and makes a pretty hard clunk.
    My truck doesnt act up at all when its still cold or if i accelerate medium to hard. Also i never had my transmission fluid changed. could that be the problem.
  2. Dec 24, 2010 at 6:17 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    trans might be f$%$. take it in. mine was shiftn hard and i had it flushed. could be a carrier bearing causing rough vibs?
  3. Dec 24, 2010 at 6:19 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Could be a bad u-joint or carrier bearing. I have 71k miles on my truck and no transmission problems, like you I haven't changed my fluid.
  4. Dec 24, 2010 at 6:22 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    i did my fluid yesterdy and it helped. its either the bearing or ur trans is messed up.
  5. Dec 24, 2010 at 6:23 PM
    Dellosa89
    Brian
    Murrieta CA
    Thats what im afraid of. the only reason why i dont think its the carrier bearing because it only does it once its worm. Also it feels just as good as my friend tacoma.
  6. Dec 24, 2010 at 6:26 PM
    Dellosa89
    Brian
    Murrieta CA
  7. Dec 24, 2010 at 6:30 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    take it in and hopefully if u have your warranty to cover damages if any. mines shifted hard and couldnt decide to hold the gear or shift down. had it recalibrated and flushed. fixed for me.
  8. Dec 24, 2010 at 6:32 PM
    Dellosa89
    Brian
    Murrieta CA
    I doubt they would warranty it im 10k over my warranty, lifted and 33s. Did you go to the dealer to have yours done?
  9. Dec 24, 2010 at 6:33 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    i did the same thing on monday. water got in my tail lights and i blew 4 fuses.
  10. Dec 24, 2010 at 6:35 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    im in warranty cert used. flushed u pay for. its $95hr to have the dealer look at it. i went to toyota of san luis obispo yesterday.
  11. Dec 24, 2010 at 6:36 PM
    Dellosa89
    Brian
    Murrieta CA
    Ah that sucks but it was worth it im sure.
  12. Dec 24, 2010 at 6:39 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    some trans take ws required fluid so i had toyota do it and my dad works there so i paid 180 for serp belt and trans flush done. its normally around 200 to have it flushed. i wouldnt recommend doing it urself if u decide to do it because the temp has to be a certain degree to hold to proper amount of fluid or else a code is thrown.
  13. Dec 24, 2010 at 6:40 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    yea but my tail light was almost half full of water.... back toblacked out tails for awhile
  14. Dec 24, 2010 at 6:45 PM
    Dellosa89
    Brian
    Murrieta CA
    Yeah im thinking monday, im just going to a Toyota specialist thats down the street from me. I would take it to a dealer but this shop is cheaper and i trust them since they have done many of my friends and family's toyotas.
  15. Dec 24, 2010 at 6:50 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    good deal hope for the best
  16. Dec 26, 2010 at 12:10 AM
    Dellosa89
    Brian
    Murrieta CA
    Thanks im really hopping my tranny is not f***ed, ill keep in update.
  17. Feb 26, 2011 at 10:53 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Sinse soooomeone is to lazy to give the good folks an update, I will :p
    The issue turned out to be a bad U joint right off the transmission output where it links to the drive shaft. The joint was physically bent/disfigured from some hard offroading. Not sure how or when it occured. Had U joint professionally replaced and problem is now completely gone.
    He's my neighbor :D
  18. Feb 27, 2011 at 12:07 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    the issue could have been caused by flying your truck through the air like an airplane!!!
    j/k sig looks awesome man !! :laugh:
  19. Feb 27, 2011 at 8:38 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    :D Thanks
    My U joints are still fine, ironically. It was the OP's that went bad.
  20. Feb 27, 2011 at 8:39 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Oops, I just realized we both have signatures of trucks flying. haha :eek:
