Transmission swap just done and it seems to slip from 1st to 2nd
Discussion in 'Performance and Tuning' started by 1999tacotrd, Jun 3, 2009.
  1. Jun 3, 2009 at 1:06 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi i just did a transmission swap on my 1999 tacoma automatic 4x4 and it seems to slip from starting off to 2nd and it works fine after that as far as i can tell i have not drove it much. We made sure everything was right on the swap its all hooked up and everything. only thing is alot of the fuild spelt out the tourqconveter when we was installing it but that shouldnt matter should it? cause i filled it back up with fuild when we got done.
    Is there a certin amount of time u got to let the truck run after doing a swap or is there something wrong
    also i forgot to hook up that little Vac line from the tranny to the transfercase could that cause this?
  2. Jun 3, 2009 at 1:22 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    what was the tranny out of?
    ON my Dad's old Dakota a vac line was missed and he had all sorts of issues with it, well issues above it being a Dodge
  3. Jun 3, 2009 at 4:45 PM
    1999tacotrd
    it came out of another 1999 tacoma 4x4
  4. Jun 5, 2009 at 7:10 AM
    1999tacotrd
    I put some lucas stop slip in it and as well as it seems when i take off if i push the gas then let off it then push it again it dosent slip. only when i push it and try to take off dose it slip
  5. Jun 5, 2009 at 8:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes, you will have to recheck the fluid several times to be sure the torque convertor is full. Second, did you replace the filter?
  6. Jun 5, 2009 at 10:41 AM
    1999tacotrd
    Recheck the fluid? i drove it some and checked it last night it was pretty full. i haven't checked it seance i added stop slip
    no didn't change the filter i can do that if u think it would help
  7. Jun 5, 2009 at 10:45 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Slipping is the sign of a dirty filter/low fluid. That stop slip crap is a waste of money(IMHO). You have to drain the tranny to change the filter.
