Transmission Trouble
Discussion in 'Wheels & Tires' started by Wildcard, Jan 22, 2010.
  1. Jan 22, 2010 at 8:48 AM
    Wildcard
    Wildcard [OP] Member
    I have a '99 taco 5 speed and recently an issue has popped up with first gear. When I put it in gear and start moving it pops out of gear with a loud pop. This only happens in first gear and only when I'm starting to let the clutch out. Once the clutch is all the way the way out and I'm driving along its fine. This only happens in first gear and only when I start rolling. Is this a sign that the tranny is starting to go bad or could it be something else. I need to change the fluids and my buddy recommended RTX 90. Any one have any ideas or other suggestions? Thanks in advance.
  2. Jan 22, 2010 at 8:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    It is the shifter bushing going out. Very cheap and easy fix.
  3. Jan 22, 2010 at 8:57 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Jan 22, 2010 at 8:59 AM
    Wildcard
    Really, just a bushing? That would be sweet. Do I just need to tell toyota I need a shifter bushing or does it have a fancy name or part number. Thanks.
  5. Jan 22, 2010 at 9:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just tell them you need the shifter bushing and seat. As far as the oil goes, I recommend Mobil 1 synthetic or Amsoil. I have never used the RTX 90 so I can't speak for that.
  6. Jan 22, 2010 at 9:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can pull the shifter out quick before you get/order the parts to make sure they are FUBAR.
  7. Feb 7, 2010 at 10:31 AM
    MrNick80
    MrNick80 New Member
    Nick
    SR5 V6
    Hey Wildcard did you check your bushing? I have the exact same problem in my '99 tacoma and it isn't the bushing. I had the tacoma dealer replace it when they replaced my clutch. It only happens to me in first gear so I'm thinking my transmission might be totally hosed as well.
  8. Feb 7, 2010 at 10:39 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    i think toyota calls is a nylon bushing. (goes on the end of the shift lever, into the trans correct?) sounds like the shift sleeve is not fully engauging. it may be a synchro-ring not letting sleeve sit.
  9. Feb 7, 2010 at 12:04 PM
    Wildcard
    I haven't had a chance to try it yet but here in the next week or two I'm doing a maintenance day for brakes, fluids, tires, etc and I'll be doing the bushing at the same time.
    Just curious, is this bushing we're discussing the little green one on the shifter? Cause I melted that one about 4 years ago and just never bothered to replace it and my shifting issue is recent within the last 2 months or so.
  10. Feb 8, 2010 at 12:34 PM
    MrNick80
    MrNick80 New Member
    Nick
    SR5 V6
    Yeah it's the green ring as seen here:
    http://www.instructables.com/id/Toy...r/step4/Installing-the-new-Seat-Cap-and-Seal/
    I pulled it out to look at it thinking the dealer hadn't replaced it, but it looked brand new. I was hoping that would fix it, but it looks like I'll have to find out what a syncro-ring is and try to replace that. I'm thinking the problem does have something to do with the synchromesh because even with the clutch in when I'm trying to cram it back into gear it doesn't match revs like it should. All the other gears work flawlessly though... hmmmm.
  11. Feb 8, 2010 at 10:32 PM
    tacobo670
    Ray
    Las Vegas
    that does sound like major trans "open-heart" surgery to r&r the synchro. when u drain trans oil, carefully look at the gear oil to see if any unusual metal shavings/deposits drain out with fluid. check magnet drain plug. its an indication that trans is grinding and eating itself up.
  12. Feb 9, 2010 at 5:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    That is what a synchro looks like. Old one on the right, new one on the left. (There was a design change)
    This is what you would be in for to overhaul. This is a R151 tranny.
    http://www.4x4wire.com/toyota/tech/r151f/
  13. Feb 9, 2010 at 5:16 AM
    98tacoma27
    Ben
    Not Beech Creek
  14. Feb 10, 2010 at 1:34 AM
    MrNick80
    MrNick80 New Member
    Nick
    SR5 V6
    Thanks a lot guys, I know a lot more about my yoters tranny now... and about how big of a job it is to rebuild it. I wish I could find the 1st gear synchro ring somewhere for $$ reasons. I wouldn't mind rebuilding the entire transmission, but with rebuild kids including synchro rings starting at $700... uhg.
  15. Feb 10, 2010 at 5:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    That seems excessive for a rebuild kit. I have seen them cheaper.
