Transmission troubles!
Discussion in 'Technical Chat' started by ImplicitlyAlberta, Jun 23, 2012.
  1. Jun 23, 2012 at 10:43 PM
    ImplicitlyAlberta
    ImplicitlyAlberta [OP] VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I have been out and about today, cruisin on the trail in 4low with no trouble. I pulled a jeep outta the mudd yadda yadda yadda.....the usual. Upon my departure from the great Canadian outback I was driving quite normally when my trucks rpm rose up with no acceleration. When I drive in OD she sometimes pops outta gear, whether its popping into neutral or not Im unsure. Also when I get to about 80 kph or 50 mph she holds in third gear at a high rpm without shifting. I cannot manually downshift the transmission as well. I am a little concerned and hope I can get some much needed input. I just need to know if it could be a sensor, vent line blockage, loose wiring or have i just burned up a perfectly good working transmission, which i would be kinda proud of.
  2. Jun 24, 2012 at 12:46 AM
    ImplicitlyAlberta
    David
    edmonton
    K she's goin to the doctors tomorrow. Mayfield Toyota do your thing.
  3. Jun 24, 2012 at 8:57 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    sounds like low fluid to me but it's hard to say
  4. Jun 26, 2012 at 3:29 PM
    ImplicitlyAlberta
    David
    edmonton
    Got my truck back from Toyota today.............drove about a block and turned around. Absolutely no change in the transmission. How can they tell me its OK, clear the codes and give me the keys back?
    I was told they took it for a test drive around the parking lot. HA! The first 3 lines is what I told them was wrong.......How can you get 3rd gear to change at 5000 rpm in a dealership parking lot without doing at least 80kph? Checked connectors hey!? Oh and one was shorted...Funny I found no shorted connector or wire around the transmission when I did my own prior inspection. Cleared codes hey!? Didnt check into them just cleared them. Hmmm sounds like I want to be a Toyota technician. I will be checking into these codes and they will be checking into my transmission.
    CANT BULLSHIT A BULLSHITTER!!!!!!! they wont get a cent until the problem is solved.
  5. Jul 7, 2012 at 7:38 PM
    ImplicitlyAlberta
    David
    edmonton
    Well new transmission here I come.$5200 later. all in the name of fun.:rolleyes:
  6. Jul 7, 2012 at 7:40 PM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
    Did you figure out the issue? Why not get a used transmission and do the swap yourself?
  7. Jul 8, 2012 at 10:40 AM
    ImplicitlyAlberta
    David
    edmonton
    I didnt think I would have the time, working out of town and what not. Figured they'd have had the problem solved in a week or so and id be back on the trail. Ha! three weeks later and still no truck. Plus they'll give me a 1 year warrenty on the new trans other then a 90 day from the wreckers.
  8. Jul 8, 2012 at 10:49 AM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
    :/ bummer still
  9. Jul 11, 2012 at 3:53 PM
    ImplicitlyAlberta
    David
    edmonton
    Alright. Got the baby back today. Seems good to go. Trails here I come.:D
