Transmission TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 270, May 13, 2010.
  1. May 13, 2010 at 9:46 AM
    270 [OP] Well-Known Member
    Jeff
    California
    09 Dc TRD 4x4
    bilstein 5100s, bull bar
    I have an appointment for the dealer to look at my 09, and they said the tech has to drive it first. My truck will only lug and shift funny every now and then, so im sure theyre gona say i dont need, they couldnt even fix my spongy brakes which i had to bleed myself. So the people who did have it done did your truck lug at all turns and when you went to speed up, or like mine every now and then.
  2. May 13, 2010 at 12:02 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Mine did it fairly often.
    I'd try another dealer. Mine did the reflash without even looking at the truck first, because they were aware that it is a common problem with the '09's.
    Call another dealer up and say, "are you aware of the a reflash for the '09 tacoma transmissions?" If they say no, just hang up, and try another.
  3. May 13, 2010 at 12:08 PM
    Jeff
    California
    09 Dc TRD 4x4
    Yea when i said i wanted to get the transmission tsb done he had this sound in his voice like what the hell is that.
  4. May 13, 2010 at 12:18 PM
    KPT
    09 Prerunner
    Yeah, if you live in a metropolitan area and there are lots of dealers around, I'd find one that has done it. They will be familiar with the problem and likely give you no hassle.
  5. May 13, 2010 at 12:31 PM
    DestroyerFan
    DestroyerFan Well-Known Member
    SoCal
    09 MagGray PreRunner SR5 Sport
  6. May 13, 2010 at 12:55 PM
    Jeff
    California
    09 Dc TRD 4x4
    Thanks Destroyerfan. My dealer is right down the street and the nearest one after them is about 60 miles, but ima give it a shot.
  7. May 13, 2010 at 1:36 PM
    KPT
    09 Prerunner
    I'd bring the TSB with you, but don't show it to them unless they start to give you a hard time. I've heard of some dealers getting very defensive when the customer busts out the tsb :duel:
  8. May 13, 2010 at 3:23 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I had to use this line when they wanted me to load my truck bed for the spring TSB.
    " Why would i need to show or prove to you the problem, that is
    (1) already known, and (2) already has a Technical Service Bulletin to correct it."
    In other words, the TSB is confirming that this is a problem - now fix it!
  9. May 13, 2010 at 4:42 PM
    Creemore
    Creemore Well-Known Member
    Toronto
    Magnetic grey TRD Sport/leather pkg.
    I don't mean to hijack this thread, but I'm wondering what problems exactly this TSB solves. My '10 has one transmission vice: it downshifts too far for slow corners. Exiting a corner from a near-stop, I'll find myself in first rather than second gear, so the truck revs for a couple of seconds, losing momentum, and then finally goes into the gear it should. Strikes me as just dumb programming. Will this TSB solve it do you think?
  10. May 13, 2010 at 5:38 PM
    skistoy
    Western New York
    Yes, it may
    keep researching this site to learn more.
