Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, Mar 14, 2008.
  1. Mar 14, 2008 at 5:30 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Can anyone tell me the name of the 5 spd transmission and what are the gear ratios for 1st through 5th. Much appreciated.
    I have finallly found it.
    The transmission is A750F for 4x4 and A750E for 2x4 I don't know if the gears are different, I didn't look.
    1st- 3.52 Transfer case Ratios
    2nd-2.04 High 1.1
    3rd-1.40 Low 2.48
    4th-1
    5th-.71
    R-3.22
