Transporting a Bike 5.5 bed
Discussion in 'Off-Topic Discussion' started by TACOMA TRD, Feb 22, 2012.
  1. Feb 22, 2012 at 11:01 PM
    TACOMA TRD
    TACOMA TRD [OP] Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Im possibly buying a bike this weekend. Its a 2004 DRZ 650. Will this bike fit in my bed with the tailgate down? It will be about a 60mile trip back home. I do have some extra D rings in my truck, they are mounted through the bed with metal plating behind them, but not to the frame.
    Also, will the weight approx 350lbs resting on tailgate bend it? Should I put a peice of plywood over the gate?
    I measured with gate down i have 78 inches. The bike is around 90 inches but I really only need the rear tire on gate.
    Bike Specs
    Overall Length:2255mm (88.8 in.), low seat setting 2235mm (88.0 in.)Overall Width:865mm (34.1 in.)Overall Height:1195mm (47.0 in.), low seat setting 1155mm (45.5 in.)Seat Height:885mm (34.8 in.), low seat setting 845mm (33.0 in.)Ground Clearance:265mm (10.4 in.), low seat setting 225mm (8.9 in.)Wheelbase:1490mm (58.7 in.), low seat setting 1475mm (58.1 in.)Dry Weight:147kg (324 lbs.)
  2. Feb 23, 2012 at 12:26 AM
    TACOMA TRD
    Tom
    PA
  3. Feb 23, 2012 at 5:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't worry about it :D
    The bike in that pic weighs about 450ish dry and is probably longer than your DRZ. No issues with the tailgate. Just be careful with the front tire turning, I made a 2x4 frame to keep the front tire straight.
    lo2hi likes this.
  4. Feb 23, 2012 at 5:48 AM
    TACOMA TRD
    Tom
    PA
    Thats a good Idea....Actually if transporting a lot I should build one similar for rear tire too where it elevates the bike and distributes weight even across the gate.
    PS did you use you factory cleats?
  5. Feb 23, 2012 at 5:55 AM
    Pugga
    Massachusetts
    I wouldn't worry about the rear. That dirt bike doesn't weigh that much so there really won't be much weight on the tailgate. I'd only be worried if it was a heavier cruiser. I've had no issues transporting the Katana. The back stays put with tie downs, the only reason I build that chock for the front is because the front end turned on me because the bed flexes so much. After I built the chock, 0 issues.
    I don't trust the tie down cleats with the weight of a motorcycle. I added extra d-rings in the front by drilling out the outter 2 water drain holes and using a plate washer underneath the bed. If you have already added d-rings using the frame bolts, you're good to go. Here's a couple better shots of the tie down.
    BTW, all the pics were taken from this thread, might help you with loading/unloading:
    http://www.tacomaworld.com/forum/motorcycles/120955-loading-motorcycle-dcsb-pics.html
    lo2hi likes this.
  6. Feb 23, 2012 at 1:46 PM
    positraction127
    positraction127 Active Member
    MN
    2011 TRD Sport DCLB 4X4
  7. Feb 23, 2012 at 11:53 PM
    DATZ WEAKSAUCE
    DATZ WEAKSAUCE Well-Known Member
    San Jose, CA
    17 DCLB TRD OFF ROAD LT PROJECT
    heres black cx with 2 bikes in his short bed
    lo2hi likes this.
