TRD 16" wheels and a lift
Discussion in '4 Cylinder' started by TSondo90, Sep 16, 2013.
  1. Sep 16, 2013 at 6:21 PM
    TSondo90
    TSondo90 [OP] Active Member
    TJ
    Westford, MA
    2012 Tacoma SR5
    Hey guys, I have been doing a little research and trying to get an opinion on if doing the toytech ultimate lift and trd 16" bead lock wheels. Will it kill my acceleration by allot or a little? Most guys who did it that I've read have the v6. I plan on running 265/70R16 on the trd wheels from the stock 245's. Will it be a huge loss in acceleration or will it be not noticeable after a while of driving it?
    I did research and the weight of the bead lock wheels are 26lbs and the stock steelies are 26 as well. I know that running the bigger tires will add more weight.
  2. Sep 16, 2013 at 6:33 PM
    InfernalTacoma
    InfernalTacoma Member
    Pedro
    Toms River, NJ
    2013 4x4 Double Cab Long Bed Sport
    No real modifications, just add ons. Extang Tuff Tonno bed cover, Toyota rubber bed mat and aluminum bed divider, 5% tint, Bilstein 5100's all the way around (1.75" setting on front)
    I went from the 265/65R17 sport edition wheels with BS Dueler tires and went to the same bead locker style wheels with 265/75R16 BFG All Terrains and Bilstein 5100's at 1.75" up front, noticed no real difference in acceleration whatsoever. Dont know if this helps you but just my input.
  3. Sep 16, 2013 at 6:48 PM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    I'm still running 245s I would imagine it would be noticeable as the 2.7 is a dog already.
  4. Sep 16, 2013 at 9:08 PM
    TSondo90
    TJ
    Westford, MA
    2012 Tacoma SR5
    I know this is prob the most noob question but will the lift by itself slow the trucks acceleration down at all?
  5. Sep 17, 2013 at 3:09 AM
    camojared
    Jared
    SE Ohio
    It will hurt mpg shouldn't hurt acceleration to much if at all. Your adding extra weight and changing the aerodynamics of the truck.
  6. Sep 17, 2013 at 8:02 AM
    TSondo90
    TJ
    Westford, MA
    2012 Tacoma SR5
    Thats what I figured, but I didnt want to spend all that money and regret it later on. I know I will probably loose some power but a huge amount.
  7. Sep 17, 2013 at 3:40 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    The research I'd done in the past on the 16" stock steel rims had them at about 28 lbs. If the alloys you're looking at are 26, then you've got a couple of lbs savings.
    According to the tire size calculator, the size you're looking at is very similar in diameter.
    http://www.tacomaworld.com/forum/tirecalc.php?tires=245-75r16-265-70r16
    The stock tires weigh 32 lbs. Depending on which 265/70-16's you're looking at, they can weigh as much as 51 lbs for the Silent Armor Pro-Grade. Look at them all on Tire Rack. Decent all terrain tires that people give decent reviews for weigh about 40 lbs. Be careful with the tire weight.
    http://www.tirerack.com/tires/TireSearchResults.jsp?customSizeSearch=&width=265%2F&ratio=70&diameter=16
    Since you're really not gaining any height, you may want to stick with stock size and just get a better tire. You may save a few pounds over the 265/70-16's that way. Goodyear Wrangler All-Terrain Adventure with Kevlar and BFGoodrich Rugged Terrain T/A (decent reviews) are 37 lbs. When combined with the TRD wheels I doubt you'd see a difference in acceleration (3 lbs per wheel), but you'd see an increase in overall performance/capability. They'd look a lot better too. If the TRD wheels are 16x8, that's still within spec for the tires.
    http://www.tirerack.com/tires/TireS...omSizeSearch=&width=245/&ratio=75&diameter=16
    http://www.tirerack.com/tires/tires...n+Adventure+with+Kevlar&partnum=475TR6WATAOWL
    http://www.tirerack.com/tires/tires...odel=Rugged+Terrain+T/A&partnum=475TR6RTTAOWL
    This is assuming you're wanting an all terrain tire. If you stick with all season, you could save more weight.
  8. Sep 18, 2013 at 1:57 PM
    TSondo90
    TJ
    Westford, MA
    2012 Tacoma SR5
    The Tires that I am looking at are the Cooper Discoverer A/T3, They dont seem to bad from reviews.
    The 16" trd wheels are rated for the 265/70 size tires. Now I want to have a little bit of poke outside of the fenders. Do you think this could be accomplished by going for 275's? I am ordering the toytech ultimate 3" lift will that allow for more clearance or no?
