TRD Baja Wheels Fitting OEM Tire Size
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmbloom37, Nov 26, 2013.
  1. Nov 26, 2013 at 12:10 PM
    jmbloom37
    jmbloom37 [OP] Member
    Mitch
    Maryland
    03 Prerunner "Taco Runner"
    K&N Intake Painted Stock Wheels Stickers for HP Debadged Lettering
    Whats up guys? Just curious and away from my trucks wheel measurements in class... would these TRD Baja Wheels fit the oem tire size of 265/70-16 or something along those lines.
    http://www.ebay.com/itm/Toyota-Taco...t=Motors_Car_Truck_Wheels&hash=item1e816f6a66
    I currently have the cheap steelies that came from the factory. They have some bad curb rash from a sibling driving and need a new pair of shoes. ;) I don't know where the size of the wheels would read on the steelies or I would look. If it doesn't fit the tire could the tire be stretched in some way to fit it? My plan (if the Bajas fit) would be take the truck to my local Sams, where they said it would be like a $20 charge or something little to swap the tires and wheels. Any help would be great.
  2. Nov 26, 2013 at 12:12 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Recommended tire size for those rims are 265/75r16. I could be wrong but I wouldn't run anything smaller
    Also beware because I'm in the same boat, I wanted to get rid of my steel rims that you can see in my sig. Bad thing is the TPMS sensors are not interchangeable between those TRD wheel and the steels something about being a 20 degree sensor and 40 degree. I just bought some level 8 rims from Discount tire direct.com and some TPMS Sensors from Amazon ( VDO SE10002 REDI-Sensor ) You'll need those swell if you plan on changing over to a different tire.
  3. Nov 26, 2013 at 12:18 PM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Ah i just realized your truck was a 1st gen!
    yup they will fit. Get some good tires for them!
  4. Nov 26, 2013 at 2:56 PM
    racd772
    racd772 Member
    Florida
    04 TRD Pre-runner DBL cab & 01 TRD 4x4 Cab
    Yes will fit perfect!!
    I'm running the same wheels with 265/75/16 Duratracs.
  5. Nov 26, 2013 at 4:26 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    C'mon now, click your link again:
    My local Toyota dealer has TRD truck wheels for $170/ea. It may be worth asking your dealer and saving the shipping cost (though it may be offset by tax).
