TRD Big Brake Kit
Discussion in 'X-Runners' started by Shaunk23, Aug 7, 2013.
  1. Aug 7, 2013 at 11:49 PM
    Shaunk23
    Shaunk23 [OP] New Member
    Shaun
    Everywhere
    06 X-Runner
    I am at the point where I need to replace my rotors and pads. I am having trouble figuring out if you can buy rotors other than the TRD ones. Any help would be wonderful!
  2. Aug 14, 2013 at 9:47 AM
    mortifer
    mortifer .
    San Jose, CA
    06 X-Runner
    Make sure you purchase the correct size.
    My TRD BBK is 332x32. I purchased these and swapped them out, it was easy. I'd recommend new brake fluid too, make sure you bleed both sides of each caliper properly to get new fluid throughout.
    http://www.racingbrake.com/Rotor-Rings-s/3262.htm
    and the pads my BBK uses are ST-40
    http://www.racingbrake.com/SearchResults.asp?Search=st-40&Extensive_Search=Y
  3. Aug 14, 2013 at 9:51 AM
    Large
    Large Red
    Someone is selling a set of the shoes for the TRD BBK for an XR in the BST section, then all you would need is the calipers.
  4. Aug 14, 2013 at 11:12 AM
    mortifer
    mortifer .
    San Jose, CA
    06 X-Runner
    The BBK does not use shoes, it is a disk brake, as is all Tacoma front ends.
    He should already have calipers for his BBK, I read his post as he needs rotors and pads.
  5. Aug 14, 2013 at 11:19 AM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    I think he just used the word shoes a little too loosely.
    Hey, You're from SJ... Why don't you ever go to any X-Runner'ish events?
  6. Aug 14, 2013 at 11:20 AM
    Large
    Large Red
    Shoes, calipers, toMAYto, toMOTto.. idk how else to word that.
  7. Aug 14, 2013 at 2:35 PM
    mortifer
    mortifer .
    San Jose, CA
    06 X-Runner
    I keep meaning too, is there anything planned for the future?
  8. Aug 14, 2013 at 2:59 PM
    GuyWithCamera
    Alan
    Tracy,CA
    Nissan 370Z
    Not to my knowledge.
  9. Aug 15, 2013 at 9:56 PM
    Shaunk23
    Shaun
    Everywhere
    06 X-Runner
    Thanks a lot, I have never found just the rotor rings. That saves a lot of money. It seemed like I was going to be buying the entire rotor.
