TRD CAI installed
Discussion in 'Performance and Tuning' started by Street Runner, Jul 12, 2013.
  1. Jul 12, 2013 at 10:43 AM
    Street Runner
    Street Runner [OP] Active Member
    Tampa, FL
    TRD Sport BSP
    TRD CAI, JBA LT's, TRD CatBack, Hellwig Sway Bars, SS Brake Lines
    I installed the TRD CAI on my truck a few months ago, here's what happened.
    I ordered the intake from TRDparts4u. It went in with no problems. The directions were very easy to understand and the whole thing took about 1 hour. Everthing fit perfectly and it looks like a factory installed part. This airbox uses the same hole in the fender well to pull in cold air from outside the engine compartment. When I started the truck it seemed to rev up slightly smoother and quicker. Next I went for a drive and immediately noticed the growl/howl coming from the engine compartment that gets progressivley louder as you accelerate. My "butt dyno" says she pulls harder especially in the upper RPM range. It pulls strong all the way to redline where before it seemed to run out of steam on the top end. I find myself putting my foot down more just to hear the nice howl of this intake. I am very happy with it.
  2. Jul 12, 2013 at 10:50 AM
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    Looks great, one of these one day I may get one, I do believe they make a difference, I had one on my last car and made a BIG difference, but they are illegal in Cali if you don't get a CARB sticker with it which SUCKS!!!
  3. Jul 14, 2013 at 5:50 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    That intake is pretty much a copy of the stock intake found on the 2010+ FJ and 4Runner. Same basic layout, same filter, same carbon trap.
    We dyno tested that intake and found it performs close to the AFE intake, but makes the engine run very lean. It seems to have a significant amount of induced MAF sensor error.
    I have had a chance to tune several of these now with the URD MAF Sensor Calibrator and can fix the induced MAF sensor problem.
    You may want to check yours by checking three data points. 1. Check the fuel trim deviation at a steady 60 MPH on flat ground. 2. Check the fuel trim deviation at idle in neutral, and 3. check the AFR at full throttle full RPM with a wideband.
    I get calls all the time from Toyota dealer mechanics chasing down lean codes with this intake. The fix is simple, remove the intake or install the URD MAF Sensor Calibrator.
    G
  4. Jul 15, 2013 at 9:05 AM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    Up to this point I have had no trouble codes.
  5. Jul 17, 2013 at 7:44 AM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    Gadget and OP. If your computer is not throwing codes are we good to go or is the CAI still running lean but the computer doesn't sense it?
  6. Jul 17, 2013 at 7:46 AM
    MagnumTaco
    Tony
    New Mexico
    I put an AFE on my S/C 2013 but I am seeing the same A/F ratio and no codes. A/F from Scan gauge. Is the Scan Gauge not accurate enough?
  7. Jul 17, 2013 at 10:12 AM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    Still no check engine light. I am going to continue to drive it "as is" for now, no big deal. In fairness it should be mentioned that all of the aftermarket CAI's cause maf sensor error at some level. The issue is not exclusive to the TRD intake.
  8. Aug 15, 2013 at 9:53 AM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    I have been reading a lot about CAI's on this forum lately and it seems that most if not all of them cause MAF sensor errors to occur. Not all cause the trouble light to come on but there are still problems going on under the hood. At this time I do not wish to invest more money into the CAI by adding a MAF CAL. I plan to re-install the stock system with the K&N drop in that I had before. I ran it for years with no problems. I am curious to see if I can "feel" any loss of performance.
    UPDATE: TRD CAI was removed for testing and then re-installed after finding that it is not the source of my issue. My truck runs better with the TRD CAI.
  9. Aug 15, 2013 at 10:09 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I use the same system, dealer threw it in with my purchase, I had the same issue with it being lean, after further investigation I discovered that the thin o-ring seal that seals the MAF sensor in the CAI Tube did not seal well at all, while working the throttle and using chem tool I could induce an engine stumble spraying around the MAF from a distance..
    I used a bit of RTV at and around the base of the Sensor, cleared the codes and in 2 years I have never had an issue since.
  10. Aug 16, 2013 at 6:27 AM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    Thanks! I will inspect the o-ring and make sure it is not leaking. My truck runs and drives fine 99% of the time but sometimes I notice some odd behavior that I did not have before installing the CAI. When I romp on it she runs good.
  11. Sep 17, 2013 at 8:05 PM
    Hollywood218
    Hollywood218 Active Member
    Alex
    WI
    13 TRD Off-Road
    I installed a CAI in my VW (traded towards the Taco) and had similar issues with lean codes. Found it to be a similar issue with O-rings not sealing in the new duct work for the CAI. I used ATF to lube the O-rings(it also caused them to swell slightly, thus sealing the leaks) and never had problems after.
  12. Feb 20, 2014 at 8:43 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    you mentioned the 2 intakes run very similar in the sense the way they run the engine lean. what one would you pick out of the two and why?
    idk anything about URD MAF i know what an MAF is.
  13. Feb 25, 2014 at 6:51 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    He's talking about the power gain.
    The AFE intake is like the 1st gen TRD intake and i think most of owners here prefer it to any other model of intake.
    An intake will always change the way the air is circulating but the FI is there to take care of it. If the form of the funnel is inducing a error too important so the closed loop can't correct it, you have a problem and it's worst for the open loop.
    I think you can have a lean problem not big enough to generate a check engine but still a lean problem.
    I have a TRD 1st gen and never had a MAF error induced. I have a MAF calibrator but mostly to adjust the AFR in open loop and at WOT.
  14. Mar 27, 2014 at 12:15 PM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    Okay so I re-installed the factory air box with K&N filter that I have had on the truck since 2005. I drove the truck in all conditions over last few months and I still notice the same minor issue even with the factory air box. This leads me to conclude that the TRD CAI is NOT the problem I am having. I went ahead and re-installed the TRD CAI about a week ago and man am I glad that I did. I can totally feel that the truck revs quicker and pulls harder in all conditions over the factory box. And it sounds way better too.:) I am just going to ignore the minor issue and enjoy driving my truck. No check engine lights with either air box.
  15. Mar 27, 2014 at 6:24 PM
    Corndawg
    Corey
    Utah
    probably going to pull the Trigger on one. by the end of the summer, to complement trd exhaust.
