TRD CAI Rattle at WOT
Discussion in 'Performance and Tuning' started by JB3CK24, Apr 7, 2010.
  1. Apr 7, 2010 at 6:32 PM
    JB3CK24
    JB3CK24 [OP] Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    Hey guys,
    I searched around the forum and found rattle issues at low rpm and reverse but nothing at wide open throttle. Just installed my TRD (old non CARB) CAI on my tacoma and its rattle city at 4500+... I tightened the box down really well... the tube, everything.
    Is there a known area that rubs causing this rattle or is that the sound its supposed to make? I have had quite a few intakes on other vehicles and it has never been like this... It does sound amazing though when you get on it. :)
    Thanks for any input!
  2. Apr 7, 2010 at 6:36 PM
    Dan893
    Dan893 Well-Known Member
    Dan
    Connecticut
    09 SR5 doublecab longbed
    TRD cold air intake, 6k HID headlights, 3K HID foglights, custom sockmonkey decals
    i just installed mine and i get this new vibration when it gets up around 4000+ or so i think its from the sound not the motor actually vibrating i know with my silverado with duals the sound would vibrate and you could feel it in the pedal under acceleration so i wasnt alarmed when i got a vibration in the pedal from the loud intake noise the trd intake creates.
  3. Apr 7, 2010 at 7:00 PM
    JB3CK24
    Jeff
    SD, CA
    Yeah pretty similar I guess. Mine feels like its vibrating through the fender or some crap into the cabin... idk, maybe i'll go triple check my bolts.
  4. Apr 7, 2010 at 7:09 PM
    Dan893
    Dan
    Connecticut
    im pretty sure their fine but if it will give you peace of mind then by all means check them. all the new vibrations are coming from the sound of the intake because there arent any air silencers or extra filters to quiet this loud v6
  5. Apr 8, 2010 at 4:01 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    Not sure if you noticed or not, but when you remove the stock intake, you lose the intake resonator. This helps in quieting any noises occurring in the intake. I still have the stock intake but just throwing out some info.
  6. Apr 9, 2010 at 1:13 AM
    JB3CK24
    Jeff
    SD, CA
    Um, I realized that. I tightened a bolt on the box and most of the vibration went away...figured out the prob. Thanks guys..
  7. Apr 10, 2010 at 6:50 PM
    JB3CK24
    Jeff
    SD, CA
    So I am undecided if I like the sound. It sounds great at 3500 rpm + but kinda gurgly (idk?) at 1500-2000 rpm... Is the AFE Pro Dry filter quieter?
  8. Apr 10, 2010 at 6:53 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Don't kill the gurgle! The MOST satisfying sound for me from the CAI/Catback combo is that gurgle when the valvetrain shuts off after you come off a low speed acceleration.
    I'd say get a good catback (or preferred muffler, some on here will recommend) put in and see how you like the two together.
  9. Apr 10, 2010 at 7:00 PM
    JB3CK24
    Jeff
    SD, CA
    It almost sounds like its popping lol...*put put put put put* when the engine is dragging in a high gear on my auto... is that normal? haha..:)
    See, I come from having bimmers where the intake systems are quiet as heck till you step on it and the Vanos (sorta like VVT-i) kicks in..
    I'm thinking of a TRD catback someday...
  10. Apr 10, 2010 at 7:08 PM
    jandrews
    Not sure...mine sounds more like an angry animal swallowing a growl...if that makes any sense...it's definitely a smooth gurgle.
  11. Apr 10, 2010 at 7:37 PM
    saltshaker
    saltshaker Well-Known Member
    johnny
    north carolina
    2011 TRD Off Road MGM AC
    AFE CAI, Fold-a-cover
  12. Apr 10, 2010 at 7:44 PM
    JB3CK24
    Jeff
    SD, CA
    haha yeah I just did that sound myself...pretty accurate. I'd have to say mine sounds like that... 1500-2000 rpms?
  13. Apr 10, 2010 at 7:45 PM
    jandrews
    Yeah low RPM, right after you completely let off the gas...I *love* that sound.
  14. Apr 10, 2010 at 7:47 PM
    JB3CK24
    Jeff
    SD, CA
    mine does when I am on the gas or under load...interesting. And barely audible at 60-65 mph freeway speeds.
