TRD CAI
Discussion in 'Performance and Tuning' started by Tacomatahiti, Jul 31, 2012.
  1. Jul 31, 2012 at 8:28 PM
    Tacomatahiti
    Tacomatahiti [OP] Member
    tahiti
    08 4Xa access cab supercharged
    Supercharger, TRD exhaust
    Hi everyone,
    Since I've put a TRD CAI, my engine has a big loss of power. The speed of the automatic transmission is very slow. When I put back the original air filter and the housing, the problem remains. I've changed MAF sensor and it's stiil the same. The engine makes black smoke, runs bad at idle and the exhaust smells bad.
    Can someone help me.
    Thank you.
  2. Jul 31, 2012 at 8:50 PM
    Tacomatahiti
    tahiti
    Check engine light is on and the MAF sensor is pluging in.
  3. Jul 31, 2012 at 8:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pictures help a lot with diagnosing a problem. Did you happen to take any? Any other points that could help us help you?
  4. Aug 2, 2012 at 8:44 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    what code did it throw? and let me know if you want to sell the trd intake :)
  5. Sep 8, 2012 at 11:00 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    If you have the new style TRD intake you may have melted down your catalytic converters and plugged them up. That will kill power.
    The new style TRD intake makes the engine run overly lean. I have tested and verified this on several trucks and get calls all the time from customers and Toyota dealer mechanics trying to solve lean code check engine lights with the new intake.
    Just something to consider.
    G
  6. May 20, 2013 at 11:42 PM
    Tacomatahiti
    tahiti
    Hi,
    I have put back the OEM air filter and I still have a check engine light with rotten egg smell from my exhaust and a big loss in engine power. Aind I don't find any leak.
    What can I do ? Take the catalyst out (In my country, no smog teste) ? Change them ?
