TRD Cold Air Intake
Discussion in 'Performance and Tuning' started by geezer, Jul 22, 2007.
  1. Jul 22, 2007 at 7:06 AM
    geezer
    geezer [OP] Active Member
    Has anyone installed one of these on the v6? I was changing oil this morning and was looking over the big chunk of plastic covering most of the engine thinking it was rather large. Then I remembered seeing a pic of the TRD CAI and thinking doesn't most of that plastic go away? That might make the upgrade even more sensible, plus I bet it traps a bit of heat?
    ................geezer
  2. Jul 30, 2007 at 12:58 PM
    VTA HOT TACO
    VTA HOT TACO Member
    The mass air flow system (big plastic box) restricts alot of the cold air coming into your intake. Not only will you get better gas mileage out of a new intake system, you will gain about 5-7hp at 4k rpms and about 7-10hp at about 5k rpms. It's kinda loud at first when you really step on it. But totally fun when gassing it around other cars. They will notice you instantly!
  3. Jul 30, 2007 at 1:20 PM
    jccyr
    jccyr New Member
    I have just purchased a new 07 tacoma access cab, 4x4 and removed the charcoal filter inside the air box, and installed a k+n air filter. So far, I am impressed, and the noise did not increase drastically.
  4. Jul 31, 2007 at 4:34 PM
    geezer
    The noise part bothers me. I looked and read a lot to find an exhaust system that didn't remind me of it's presence every time I nailed it. Seems a little counter productive to install an intake mod that wouldn't do the same thing. Plus I can't help wondering how much the stock computer can accommodate our qwest for performance? At what point you need electronic intervention?
    .............geezer
  5. Jul 31, 2007 at 6:15 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    This is how I understand it, but I am far from the expert as I am still gathering information and trying to pic the right combination of intake and exhaust myself. The 4.0 V6 engines run rich from the factory. Any kind of performance intake will cause them to run richer still as you are now feeding it more air so it will then feed in more fuel according to it's already rich ratio.
    So yes, like the other members have said you will get more power out of a performance intake, but I doubt it will be as high as you have been previously quoted. Also, in the process of getting that additional power you will loose fuel economy, I'd guess probably as much a a mile per gallon.
    To answer your question you need electronic intervention as soon as you add the intake. As I understand it the only electronic intervention that you are going to want to consider is the MAF calibrator from URD. It will give you full controll over your air fuel mixture to correct the rich misture from the factory as well as dial in the mods you already have as well as those you may add in the future. The SUPERCHIPS, EDGE and BULLYDOG type of one size fits all chips are a waste of money, and will do nothing to help you unlock the full potential of your mods.
    Check this thread for the answers I got when I asked this very same question a few weeks ago http://www.tacomaworld.com/forum/2nd-gen-tacomas/2034-help-cai-exhaust-maf-calibrator.html and look to Spyder327 for the best understanding of how the MAF calibrator works.
    Let us know what you choose
  6. Jul 31, 2007 at 11:54 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    Sounds like you pretty much covered it man. ;)
    But yea i can answer any additional questions anyone else has about it.
  7. Aug 1, 2007 at 11:05 AM
    VTA HOT TACO
    VTA HOT TACO Member
    I have seen these $500.00 chips on Ebay lately that are pre-tuned to your mods and they fit right over the existing chip. I haven't really researched it at all yet due to the time I'm spending on looking for the right exhaust system but I plan to get more info on it soon.
  8. Aug 1, 2007 at 11:26 AM
    maverick491
    South Jersey
    I'm not thinking pre-tuned is going to work, I believe that this is something that you need to do yourself or have done by a competant shop near you.
    Examples:
    If the chip is marketed to be tuned for say exhaust and intake... Well is it tuned for Flowmaster, or Gibson, or Borla, or TRD exhaust? Each one going to perform somewhat differently, and therefor alter the variables to some extent. Same with all the various intakes on the market... Prime example was over on another forum, someone with just a TRD intake, had a drastically different map from another guy with just a K&N intake.
    Which brings me to my second point... Each engine is also different. Toyota accepts a plus or minus 15% varience in the MAF sensors, hence the reason that the 4.0's run rich, and why the MAF calibrator is able to do what it does. Therefor, if both you and I had the exact same mods (same manufacturer even) our corrected air/fuel maps would still be different.
    Last point... Where were these pre-programed chips made? Example, if they are made and programed with data from say Denver, then they are not going to work well and possible even lean out the motor to the point of damage here at the Jersey Shore, and conversely if they are made here, then they certainly are not going to work correctly in Denver.
    My point is just that, to my understanding, in performance tuning there really is no plug and play, to get the most power out of your truck safely, you need to tune everything to that truck as is where is.
    Please check me on all that again Spyder if you don't mind :eek:
  9. Aug 1, 2007 at 11:47 AM
    VTA HOT TACO
    VTA HOT TACO Member
    Nah man, that makes perfect sense. With the smog equipment that California requires along with the rich running 4.0L there could most definitely be a problem that could arise from installing a chip manufactured in just about any other state.lol (California has the strictest clean air laws). Again, I haven't looked into what I'm going to do yet with this. That MAF cal. from URD is looking pretty tempting at this point though. I'm saving money right now anyways so I've got some time to research that. I'll probably get my exhaust in and then go with the MAF cal. Exhaust in 3 weeks, MAF cal. in 6 weeks. I'll work on getting some video of how it sounds to post here once installed. I might even video the installation.;):cool:
  10. Aug 2, 2007 at 12:49 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    Yea thats pretty much right. The idea of a "tune" with those chips is basically to lean out AFR. This can be a very bad idea because like you stated, there are differences between each trucks, and that depending on mods, AFR will need to be tweaked differently. URD's MAF calibrator is the only thing that allows for you to retune as you add more mods, Chips that come to you "pre-tuned" are a very bad idea.
  11. Aug 3, 2007 at 4:49 PM
    Kevin296@adelphia.net
    Kevin296@adelphia.net Member
    Central NY
    Rad Red Sport
    TRD exhaust TRD CAI Urd Maf Cal TRD seat covers Black Tacoma and Toyota Emblems Subbie ant
    This is TRD CAI on my truck. I relly like it with the TRD exhaust and URD maf
  12. Aug 4, 2007 at 3:30 AM
    geezer
    Kevin - Thx for the pic. Not sure why I thought the large plastic air box went away but obviously it does not.
    ............geezer
  13. Aug 5, 2007 at 10:19 PM
    hokihigh
    hokihigh Active Member
  14. Aug 6, 2007 at 12:53 PM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
    I am either going with the URD CAI or I am just going to put in a high flow drop in. To me the other ones that sit in the engine bay dont seem to do much more that the stock airbox. :confused:
  15. Aug 18, 2007 at 1:09 AM
    XxMalfunktionxX
    XxMalfunktionxX Well-Known Member
    Orange County,California
    2008 4x4 TRD SPORT SR5 Double Cab
    K&N Drop in, Bilstein 5100's in front with Readylift kit on top for a 3 in. lift in the front and a 1 in. block in the rear. Next project is going to be TRD Supercharger and Camburg coilover long travel system with custom skid plate and tubes. Maybe some new tires and wheels then..
    I got an 08..just grabbed it last nite actually..since this is my first new Taco..old one was an 04..im taking it the Cold Air intakes for 07's will fit an 08?
    Im gonna wanna make some adjustments under the hood here and I wanna make sure its done right..so i will be asking alot of questions..
  16. Aug 18, 2007 at 11:02 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    As far as I know the 08 uses the same 4.0L V6 as the 05-07. You will probably have a hard time finding aftermarket parts that say 08 until maybe December/January. But all of the 05-07 ones should fit.
  17. Aug 18, 2007 at 10:06 PM
    XxMalfunktionxX
    Cool Cool..thanks reid..
  18. Sep 2, 2007 at 6:10 AM
    ghostsix
    ghostsix Well-Known Member
    A WI farm, Sonora, Sedona, Lake Havesue and Canyon
    Impluse Red 2006 Toyota Tacoma TRD Off-road 4x4
    A Roo Bar comes to mind. I also protected the tail lamps. It is a farm and you back over stuff; Willows mostly. All of the factory options are on it. The dealership owner bought it for himself.He put a topper on it and pricey tyres. The Power Wagon does the heavy lifting.
    I have the TRD Off Road Packege. So I have all of this stuff, right?
    And a Diff. Lock. do I need to read this thread?
    I have not had the time to take a good look at the 2006 Taco.
  19. Sep 3, 2007 at 12:45 PM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    No! If you have the TRD package you do not have this stuff. TRD is Toyota's performance aftermarket division. Your truck has a few upgraded things but you have the same engine as the rest of us SR5 guys.
  20. Sep 6, 2007 at 7:31 AM
    ghostsix
    Thanks I was getting confused. I have a TRD exhaust I assume.
    I just bought this thing and the weather has consumed a lot of my time.
    I am the local LEO. So I own all of the problems.
    Stuff that should be up is down. The Taco escaped three times so far. I had left where trees went down just after I moved it.
