TRD diff in a SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ji2006, Dec 13, 2023.
  1. Dec 13, 2023 at 9:33 PM
    Ji2006
    Ji2006 [OP] Active Member
    2023 sr Tacoma
    What would it take to drop a TRD locking dif in a basic SR?
    If not direct drop in compatible, what all will I need to swap or alter.
    I’m sure it has been posted but I have not been able to find it.
    I have a pretty basic sr Tacoma, 3.5l auto, axel code A07A, 4x4, it’s a work truck for checking wells and oil tanks across the country side.
    I have had the truck about a month and today was the first time I have been in the mud. I was not impressed. Found several places I should have never needed 4x4. This truck gets used for work and will see mostly dirt roads and off road.
    I'm looking to add a locking rear diff, a coworker totaled a brand new (date code 2/23) trd about 3 months ago and has offered to let me get my hands on his diff for cheap. If his will not work I’ll buy an Eaton e locker.
    Kodiak420 likes this.
  2. Dec 13, 2023 at 9:38 PM
    5minutejob
    5minutejob New Member
    2023 TRD Sport DCSB
    Hood swap,
    I would also like to know, I have a sport and want lockers.
  3. Dec 13, 2023 at 9:40 PM
    Ji2006
    2023 sr Tacoma
    If I get any info I’ll send you a message, glad to see I have company in this boat.
  4. Dec 13, 2023 at 9:43 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Requires axle swap or housing modification and custom wiring. Just get an arb or eaton and call it a day
    SH10151, usmc2msu and IvanhoeTaco like this.
  5. Dec 13, 2023 at 9:49 PM
    Ji2006
    2023 sr Tacoma
    What is it that requires the swap? What exactly is different? The housing? The ring? I’m sure I can get his entire rear end mostly curious what the differnce is.
    I already got his shocks and skid plates lol.
  6. Dec 13, 2023 at 9:55 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Size. A07A is 8 ", the trd one is 8.8
    TireFire, hiPSI and 5minutejob like this.
  7. Dec 13, 2023 at 9:58 PM
    Ji2006
    2023 sr Tacoma
    Would it be possible to gut and swap all or is the housing to small?
  8. Dec 13, 2023 at 9:59 PM
    Vlady
    Issy, WA
    The pumpkin size is small. Need to swap the whole axle. But then you need to deal with the wiring
  9. Dec 13, 2023 at 10:01 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
  10. Dec 13, 2023 at 10:03 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Have you tried better tires yet? Makes a huge difference over what it comes with stock. You could swap the entire TRD OR rear axle but would have to figure out your own wiring for to engage/disengage the locker. Seems easier to just turn the dial to 4hi rather than mess around adding a locker just to stay in 2hi with the rear locked.
    LooneytuneSR5 and gudujarlson like this.
  11. Dec 13, 2023 at 10:03 PM
    Ji2006
    2023 sr Tacoma
    I can wire it providing they didn’t do. One thing goofy like change a speed sensor or, I was thinking just add a hard wire like the Eaton elockers use. On and off.
  12. Dec 13, 2023 at 10:04 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    The factory locker isn't just a simple on/off power source
    Chew likes this.
  13. Dec 13, 2023 at 10:05 PM
    Ji2006
    2023 sr Tacoma
    Yeah today I about didn’t make it out of a couple of the mud holes in 4x4, tires are not bad but they are decent at tires. Same as my dodge that has zero issues on this route.
  14. Dec 13, 2023 at 10:06 PM
    Ji2006
    2023 sr Tacoma
    Good to know, how does it function?
    edit: link above has some more info for me.
  15. Dec 13, 2023 at 10:06 PM
    Vlady
    Issy, WA
    I assume you are trying to swap with 3rd gen one. You could look into 2nd gen trd trims(2015). Those are 8"..
    ....never mind. They have 3.72 ratio
  16. Dec 13, 2023 at 10:08 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    The stock E-locker uses pulse width modulation and not simply +12V on and off. Read through the second link I posted. Great info in there
  17. Dec 13, 2023 at 10:19 PM
    Ji2006
    2023 sr Tacoma
    I was just reading threw alot of it looks like they are trying tie into the pcm to have an anytime locker but I’m getting a pretty good idea of what I may need to get it going.
    Strictlytoyz[QUOTED] likes this.
  18. Dec 13, 2023 at 10:19 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Best of luck, post results.....for science :cheers:
    Koolbreeze7 and Chew like this.
  19. Dec 13, 2023 at 10:29 PM
    Ji2006
    2023 sr Tacoma
    I can get the wires done, just need to make sure now the whole rear axel is not messed up. If it is I guess a Eaton it will be
  20. Dec 14, 2023 at 12:15 AM
    rke1063
    rke1063 Active Member
    Louisiana
    2023 SR5 4x4 DCSB
    I’m in the same boat with an sr5. Interested to see the results
    Topanga Taco likes this.
