TRD Double Cab Coil length question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AGENT-X, Jul 25, 2009.
  1. Jul 25, 2009 at 6:22 PM
    AGENT-X
    AGENT-X [OP] Well-Known Member
    Austin, TX
    13' DCLB 4x4
    Current: 2018 TRD ORP 4runner Eibach pro truck lift TRD pro wheels 2013 Tacoma DCLB 4x4 5100's all around, 885s front, rear ToyTec AAL and Ride Rite Airbag rear. 265/75/16 BFG AT KO2. Previous: 2007 DCSB TRD OR Toytec OME 3" w/ 885s, TC UCA's, 265/75/16 BFG MT's
    Recently my girlfriend bought a 4 cyl. 09 Tacoma. I was looking around the garage this weekend and noticed I still have the coils and uca's left over from when I lifted my 07 double cab TRD Off Road. My question is are the TRD coils any longer than the stock 4 cyl coils and if so can I replace the 4 cyl ones with the TRD ones (are they interchangeable)?
  2. Jul 25, 2009 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Does she have a 5lug or the 6 lug?
  3. Jul 25, 2009 at 6:42 PM
    AGENT-X
    Austin, TX
    13' DCLB 4x4
    6 lug, it's a PreRunner
  4. Jul 27, 2009 at 4:03 PM
    AGENT-X
    Austin, TX
    13' DCLB 4x4
    anyone?
  5. Jul 27, 2009 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use the ones from your 07 on her 09. They are the same length, but a slightly higher spring rate, so it may give her a little lift.
  6. Jul 27, 2009 at 4:11 PM
    AGENT-X
    Austin, TX
    13' DCLB 4x4
    ok thanks, I'll just order her some 885's from wheelers.
  7. Jul 27, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Does she have a double cab?
  8. Jul 27, 2009 at 4:48 PM
    AGENT-X
    Austin, TX
    13' DCLB 4x4
    no, access cab. I was going to use the 885's because they have about 2" of lift and it would almost level the truck out. Would you suggest 884's instead, if so is there a reason?
