TRD E-Locker Capabilities??
Discussion in 'Off-Roading & Trails' started by PreRunning, Aug 31, 2012.
  1. Oct 9, 2014 at 11:02 AM
    TheMontanian
    TheMontanian Member
    Ben
    Missoula MT
    02 prerunner Dbl-Cab
    OME add a leaf. Toyota MT open country's. Grille and little shit
    What's the bottom look like?? Anyone did a conversion from limited slip to lockING or seen it done?
  2. Oct 9, 2014 at 6:06 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    There is supposed to be a sticker on your door, plus the owners manual...
    For safety reasons, the locker is to get you unstuck or to get you up or over an obstacle. It is engaged at a stop or barely rolling. Yes it will work/ stay locked at any speed, but TOYOTA says NOT to drive faster than 5 MPH. The reason is that a locked rear makes steering more difficult, and Toyota doesn't need a bunch of stupid people suing them because they weren't warned, and drove off a cliff or into a tree because the truck doesn't turn as quickly when locked.
    The 4WD locker only works in LOW RANGE, so getting faster than 30 mph isn't common!
    If you all keep racing with your rear locked, and wreck your trucks, it won't be long before that locker is gone and TRAC and A-TRAC will be all that's available, since they do not affect steering.
  3. Oct 9, 2014 at 9:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  4. Oct 10, 2014 at 7:54 AM
    wizardfishin
    wizardfishin Well-Known Member
    Aaron
    Birmingham, AL
    01 PreRunner SR5, TRD offroad, stepside
    Do any of you know if all generation one TRD Offroad trucks have the Limited Slip Differential? I have a 2001 2wd pre runner SR5, i don't have a button to control the rear locker so i assume that it is a LSD. I got stuck in the mud this week, one of my tires was in a bad rut and never did spin once we got stuck. The driver's side rear tire spun and spun, but the passenger's side rear tire never moved once it lost traction. I was thinking it would have engaged the Limited Slip Differential at some point and gotten both tires to spin, but it sure didn't. Any words of wisdom?
  5. Oct 10, 2014 at 8:03 AM
    David K
    No, they all are OPEN differentials, as are all of today's Tacomas. Only the 2005-2008 TRD SPORT Tacomas had mechanical limited slip. Since then, we all have electronic limited slip.
    You are describing an open differential (the one tire in the air spins and the one with good traction does nothing).
    Limited slip would apply resistance (brake pressure) to the free spinning tire so some power would apply to the good traction tire to move you ahead.
    A locking differential would lock both tires together and no spin at all, both would turn equally.
  6. Oct 10, 2014 at 8:33 AM
    David K
    It may have been a special order option, sure.
    What does "one tire fire" mean?
    'Limited' means only so much slip is allowed before the slip is stopped. Slip = spin.
  7. Oct 10, 2014 at 9:09 AM
    wizardfishin
    Aaron
    Birmingham, AL
    This is why I was asking. I thought all V6 trd tacomas had the button to lock the rear differential, but my tacoma does not have that, and it does not appear that it has a LSD to me either. Did the generation one TRD trucks not all come with either a rear locker or a LSD?
    What year TRD offroad trucks did definitely come with a rear locker? and was this only in 4 wheel drive? Sorry for all the questions, i'm pretty confused
  8. Oct 10, 2014 at 9:24 AM
    sixspeedlife
    sixspeedlife Well-Known Member
    Braden
    MB, Canada
    05 TRD OFFROAD Six speed
    Leveled, BHLM, Black mesh grill, black skid plate
    I have a 2005 4L trd off road. As far as I thought, only the manual trans OR comes with the locker
  9. Oct 10, 2014 at 12:25 PM
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    I still get confused.
    So do a lot of dealers going by ads.
    Is making the E-locker work a matter of hooking up juice and a switch on non-E-Locker trucks or is this a different differential?
  10. Oct 10, 2014 at 2:38 PM
    nealkas
    nealkas
    Pee-Ay
    Thank you RL.
  11. Oct 10, 2014 at 2:51 PM
    sixspeedlife
    Braden
    MB, Canada
    Yes great info RL
  12. Oct 10, 2014 at 2:59 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    Rock lobster you suck :spy:
  13. Oct 10, 2014 at 6:04 PM
    David K
    The First Gen TRD was an Off Road. In 2005 they invented and added the Sport TRD, which did not have a locker. Only Off Road TRDs have a rear locker.
  14. Oct 16, 2014 at 11:33 AM
    Manwithoutaplan
    ID
    :laugh: So mean.
  15. Oct 21, 2014 at 9:02 PM
    #35
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    RR locker ftw
  16. Dec 27, 2015 at 12:44 PM
    #36
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I just read that if your e-locker actuator fails in the field, you can manually engage and disengage the locker. How do you do this? Would the actuator need to be pulled off? Would a special tool be needed to actuate it?
