TRD, EBC or Hawk brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beavis87, Jan 13, 2018.
TRD, Hawk or EBC pads and rotors?
  1. TRD pads with OEM or StopTech rotors
    32 vote(s)
    50.0%
  2. Hawk pads and rotors
    11 vote(s)
    17.2%
  3. EBC pads and rotors
    21 vote(s)
    32.8%
  1. Oct 4, 2018 at 3:10 PM
    #41
    STEVON
    STEVON Well-Known Member
    STEVO
    San Diego
    06 SR5 Prerunner
    Reinforce tailgate
    crashnburn80,
    Yes, I agree that lighter wheel/tires would mean better use of the truck's other stock design parameters. Engine power, gearing, braking, suspension control and alignment issues. I had taller/heavier tires once and the handling, acceleration, fuel mileage and braking all suffered severely. After that debacle actually went to larger rims and low profile tires! performance increased exponentially. Braking issues are more of a recent problem
    crashnburn80 likes this.
  2. Oct 5, 2018 at 6:13 AM
    #42
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm rolling a Sport, so no ATRAC. And I refuse to go down to a smaller tire. Right now I'm running a 34x10.5x17 KO2 and it's pretty much the perfect size. They come in at 55lbs and there's no lower rating than D.
  3. Oct 5, 2018 at 8:58 AM
    #43
    STEVON
    STEVO
    San Diego
    06 SR5 Prerunner
    Reinforce tailgate
    ItalynStylion,
    Guessing big brake kit is your only solution, I wouldn't expect the barely adequate stock brake setup to do anything extraordinary in your application. My crewcab 4 door Prerunner came with the smaller drums in back! cheap and light as possible from the factory all in the name of cost savings and gas mileage!
    I hope you changed the stock diff gearing for those bad boys! " I'm running a 34x10.5x17 KO2 "
  4. Oct 5, 2018 at 9:04 AM
    #44
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I used wagner stuff from rock auto, works like any other brake ive felt lol
  5. Oct 5, 2018 at 9:34 AM
    #45
    ItalynStylion
    Steven
    DFW, Tx.
    4.56 baby! It was necessary. Truck was a total pig without them!
  6. Oct 5, 2018 at 9:36 AM
    #46
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That actually isn't bad for the tire size. Your running a narrow tire, not E load, and AT instead of MT. So weight savings options staying in that size are going to be minimal. It is hard to tell in your picture but looks like you are running sport wheels. The TRD 17" 4runner SEMA wheels are a few pounds lighter but overall savings would be very small and weight savings at the wheel isn't as great as at the tire.
    Your best bet would be the semi-metalic pads for a small improvement, or the big brake kit for a more noticeable one.
    Biscuits likes this.
  7. Oct 5, 2018 at 3:48 PM
    #47
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    when its time for me to change, I'll stick with Toyota pads and go with the cryo treated slotted stop tech rotors.
  8. Oct 5, 2018 at 4:02 PM
    #48
    Cash13
    Cash13 Well-Known Member
    Northern Colorado
    2014 Tundra
    I put the EBC brake kit off Amazon with the green pads and slotted rotors. After about 4000 miles the rotors are warped, still waiting on my warranty claim with EBC. Anyone else had a similar issue?
  9. Oct 5, 2018 at 4:12 PM
    #49
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    'Rotor warping' is often pad material transfer to the rotor. EBC Green stuff is an Organic material pad. As far as pads resistance to heat, and their heat performance goes:
    Organic<Ceramic<Semi-metallic
    Green Stuff is a very low temperature pad, and is easily overheated on a truck, especially if you have larger/heavier oversized tires. Chances are you baked off some pad material onto your rotor which now causes pulsing and vibrating when braking. I would not recommend organic pads on a truck. They have strong initial bite for a light weight car, but they do not have high heat tolerance or performance for a heavier vehicle.
  10. Oct 5, 2018 at 4:31 PM
    #50
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Any idea on what the weight difference is between the two? Ive been thinking about a set of these for my truck
  11. Oct 5, 2018 at 4:35 PM
    #51
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I think @crashnburn80 states the delta on his wheel/brake thread.
  12. Oct 5, 2018 at 4:37 PM
    #52
    BassAckwards
    Thanks buddy:thumbsup:
    Biscuits[QUOTED] likes this.
  13. Oct 5, 2018 at 4:43 PM
    #53
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I list most, but the Sports are one I haven't found the official number on yet. The SEMA wheels are a great choice though, they push the stock width tires right out to the edge of the fender and are only 25lbs.
  14. Oct 5, 2018 at 4:47 PM
    #54
    Cash13
    Northern Colorado
    2014 Tundra
    Thank you for the info, I did not know that. What brake and rotor combo would you recommend?
  15. Oct 5, 2018 at 5:03 PM
    #55
    BassAckwards
    Thats what i was thinking, im trying to keep my wheels and tires as light as possible
  16. Oct 5, 2018 at 5:24 PM
    #56
    Cash13
    Northern Colorado
    2014 Tundra
    Ignore that response, I found the thread you made on brakes.
  17. Oct 8, 2018 at 12:44 PM
    #57
    STEVON
    STEVO
    San Diego
    06 SR5 Prerunner
    Reinforce tailgate
    Got the new rotors and TRD pads installed. Did the break in bedding procedure. Way better braking! back to stock feel! Truck used to "slide" on the last ten feet with me straining hard on the pedal to actually stop. Truck is used as a commuter vehicle (empty, no load) Now brakes grab overall better than before and at the last ten feet the "sliding" feeling is gone. The truck will never brake tight like my Hybrid Ford Fusion or other modern cars, but I feel safer now.
    I don't think the extra money spent for the "premium high carbon" rotors was necessary. I believe the TRD pads did the trick. We'll see about the dusting and the longevity of this setup.
  18. Oct 15, 2018 at 4:53 PM
    #58
    STEVON
    STEVO
    San Diego
    06 SR5 Prerunner
    Reinforce tailgate
    Update,
    Yeah there definately is more black dust on the front wheels now.
  19. Oct 15, 2018 at 7:47 PM
    #59
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Dang, that was quick!
  20. Nov 4, 2018 at 7:35 PM
    #60
    Seek Help
    Seek Help Corn passes right through
    Haslet, Tx
    2002 Lexus LX470, 2016 Quicksand Tacoma TRD Sport 4x4
    Insain Fab Front Bumper, ICON Stg 6 Suspension, Konig 16x8 w/275/75/16 KO2, BAMF Raptor Style Grille w/ custom lettering, Custom MESO LED mirror/taillights, Custom bed TRD Sport and tailgate decals, ICI Magnum RT Steps, LED interior lights, 30" LED light bar, Baja Squad LED fog lights, 2xLED Bed 5ft spot lights, AirZenith OB2 w/3 gallon tank bed air setup, CCW gun mount....more to come.
    Been running Brakeperformance.com slotted/dimpled rotors and EBC yellow stuff on my truck for over a year now with zero issues in all situations and I run my truck like a super car(just not as fast...). Have used brakeperformance rotors on all my Audi's and now the truck and never had warping or cracking. EBC pads are awesome if you don't mind 2 things, squeaky brakes for a few thousand miles or when its super cold and the dust. The performance destroys any other company I have seen out there without going into the super high end while cutting into your retirement funds.
