TRD, EBC or Hawk brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beavis87, Jan 13, 2018.
TRD, Hawk or EBC pads and rotors?
  1. TRD pads with OEM or StopTech rotors
    32 vote(s)
    50.0%
  2. Hawk pads and rotors
    11 vote(s)
    17.2%
  3. EBC pads and rotors
    21 vote(s)
    32.8%
  1. Nov 17, 2018 at 7:22 AM
    #61
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I ended up getting this kit from BuyBrakes.com. The part number is 970.44042
    https://www.buybrakes.com/brake-kits/disc-brake-pad-and-rotor-kit-970-44042
    Better compound and new rotors were my buying points. The 34" tires I run now are making the truck less willing to slow down. I wanted better initial bite than the OEM pads and boy did I get it. These stop very well. They almost seem "sticky" with regards to the pedal feel now. With just a little bit of braking force I can feel these grab. I'm sure these will yield a bit more dust but that's understandable. I'd rather have slightly dusty wheels than die in a crash while everyone on TW is hoping I part out the truck so they can get my shiny wheels. It should also be noted that these pads have a larger contact patch than the OEM pads. It's hard to explain but the OEM pads are shaped in such a way that they don't take advantage of the full area of the pad backing. These do and I think in part, it helps translate into better initial bite.
  2. Nov 17, 2018 at 7:40 AM
    #62
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    i have EBC rotors with Greenstuff pads and I am pleased with their performance.... cannot speak for longevity of the pads, but I rotated tires last weekend after 8-10k miles on brakes pads still look meaty... if that's the route you go shop around, i found the cheapest price on ebay...
    #62
  3. Dec 1, 2023 at 2:02 AM
    #63
    yellowdogpaddler
    yellowdogpaddler Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    Do the TRD Pads fit the OffRoad? I ask b/c when ordering from the dealer's website, the website state the TRD pads are not compatible. I am thinking this is just b/c when I put in my model it doesn't match TRD.
