TRD Exhaust Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by novakills, Oct 28, 2009.
  1. Oct 28, 2009 at 12:05 PM
    novakills
    novakills [OP] Well-Known Member
    Scott
    Tampa FL
    2010 Prerunner TRD Sport
    TRD CAI, debadged, TRD exhaust, bed d-ring mod, rubber bed mat, 6000K Bi-xenon headlights, 3000K HID foglights, Redline Tuning QuickLIFT PLUS Hood Struts, 2" Toytec AAL w/Bilstein 5100s, 1" aluminum tapered leaf spring spacer, Eibach 1.6" lift coils on Bilstein 5100s set at .85 with Light Racing UCAs, 10% tinted windows, 285/70/17 Toyo Open Country A/T, Pioneer MVH-X560BT,TRD Supercharger, Grillcraft Black MX upper and lower grill, RAAMmat Sound Deadening, Hybrid Audio Technologies Imagine Series I61-2 in rear doors, Hybrid Audio Technolgies Legatia L6 and L1V2 in front doors running through Hybrid Audio Legatia L2X crossovers, JL Audio 13TW5 in a bedlined Mr. Marv enclosure, Zed Audio Leviathan Amp on a bedlined Mr. Marv amp rack, DTLT Exhaust Headers w/O2 simulators, full LED lighting interior and exterior, OEM roof racks
    So I'm planning on installing my TRD exhaust tonight. I have plenty of mechanical prowess to accomplish this but to those with experience, can I install this exhaust with the truck on the ground? I have a floor jack and will go get some jackstands (all mine are in TN) if need be. My concern is snaking the exhaust over the axle to its final position with no interference with the ground or necessitating more space between the axle and the chassis.
  2. Oct 28, 2009 at 12:07 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Yea you will be fine. Did mine 2 weeks ago. If you jack it up, just do the passenger side.
    Oh, and it helps to rub some dish soap on the flanges before you hang the new exhaust, helps them slide into the hanger real easy, and you can wash it out with water if you want after.
  3. Oct 28, 2009 at 12:10 PM
    novakills
    Scott
    Tampa FL
    Thanks! I knew to lube the hangers to ease removal/replacement. Mine should come apart fairly easy since I only have 1900 miles on the truck.
  4. Oct 28, 2009 at 12:14 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Lowering the spare tire made it a lot easier for me.
  5. Oct 28, 2009 at 12:17 PM
    novakills
    Scott
    Tampa FL
    i will keep that in mind too. thanks!
  6. Oct 28, 2009 at 12:19 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Yea it does help with the hanger in the back, I managed to work around it also with a broken finger with 3 pins stuck through the bones. It is really quite easy.
  7. Oct 28, 2009 at 1:09 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Easy to do under a pre-runner. 20 minute job.
    Don't pull the shipping cover off the tip until you're done. It can get scratched up when you slip it over the axle. Watch out for the ABS wires. If something gets hung-up, you're doing it wrong.
  8. Oct 28, 2009 at 1:20 PM
    novakills
    Scott
    Tampa FL
    I'm saving your rep until I complete the install in 20 mins or less LOL
  9. Oct 28, 2009 at 1:21 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    You will get it in 20 or less. I rolled my passenger side up on ramps and had the stocker off in about 10 mins and had the TRD on in about 5-10 mins. Literally easier than shit to do. I asked the same questions as well.
  10. Oct 28, 2009 at 1:45 PM
    novakills
    Scott
    Tampa FL
    I usually perform a thorough search before I ask a question. Oh well, I got what I needed. Thanks
  11. Oct 28, 2009 at 1:51 PM
    JACKEL142
    JACKEL142 Well-Known Member
    Nashville
    2009 Sport LB 4x4 Speedway
    Did mine in 20 also, sounds ok.
    just make sure they shipped you the correct one. They sent me a SWB at first. Caught is before I dropped the old one.
  12. Oct 28, 2009 at 2:11 PM
    novakills
    Scott
    Tampa FL
    it does say SWB on it. i have a DC SB and it eyeballs approx the same length as my stock exhaust. my VIN was part of the order so i hope they used that info before they shipped it. we'll see within the next hour!!!
  13. Oct 28, 2009 at 4:17 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Just put on my TRD today.. Hardest part was taking the flowmaster apart cuz the clamps crushed the tubing so much. Once i had the old one off took about 10min to put the TRD on
  14. Oct 29, 2009 at 6:27 AM
    novakills
    Scott
    Tampa FL
    Yep, 20 mins is about right. thanks everybody!
  15. Dec 13, 2009 at 2:11 PM
    Rooty
    Rooty Tacfroma
    Jesse
    Missoula MT
    2010 Access Cab 4x4
    ARB Bumper with Foglights, IPF 968 Driving Lights, Color Matched Grill Surround and Eyelids, Grillcraft Grill with Custom Taco Emblem, Black Headlight Mod, EGR Hood Deflector and In Channel Rain Guards, Stock Wheels Painted Black, BFG TA/KO's in 265/75/R16, Debadged, Stubbs Welding HDSKO Sliders, Front Windows Tint, Wet Okole Seat Covers, Weathertec Floor Mats, Autolights Unlimited Smoked 3rd Brake and Tail Lights, Powdercoated Rear Bumper, TRD Cat Back Exhaust, AFE Pro Dry Filter, Factory Bed Mat, Compustar 1 way remote start
    I'm getting ready to do this myself. Don't you need to slather up the input flange with high temp gasket adhiesive on the new one before you stick it into the header pipe? I know I had to on the aftermarket exhaust for my motosnickle.
  16. Dec 13, 2009 at 11:57 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    its just like work, insert dry
  17. Dec 14, 2009 at 1:47 PM
    Rooty
    Rooty Tacfroma
    Jesse
    Missoula MT
    2010 Access Cab 4x4
    Wow, that's surprising. That must be some kind of clamp up they engineered.
    I think I may do it anyway just to be on the safe side, it couldn't hurt and it may prevent a leak.
