TRD Iridium Spark Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Sep 29, 2011.
  1. Sep 29, 2011 at 6:52 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    TACOMA ’05 - ’10 TRD Iridium Spark Plug, 4.0L V6, Set of 4 PTR24-35070
    I'm just about do for my 60,000 mile tune up. I have seen the TRD plugs and I'm thinking about getting a set. Dose any one have them in there truck?
  2. Sep 29, 2011 at 7:02 AM
    saugus
    saugus Well-Known Member
    Am I missing something? set of 4???:confused:
  3. Sep 29, 2011 at 7:17 AM
    Glamis
    you can get a set of 4 or ech plug.
  4. Sep 29, 2011 at 7:17 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Those have got to be for the 4 bangers. The V6s take regular copper plugs.
    REDdawn6 likes this.
  5. Sep 29, 2011 at 7:26 AM
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    TacomaEd15 and Kory450 like this.
  6. Sep 29, 2011 at 7:29 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  7. Sep 29, 2011 at 7:42 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Too bad... I just popped Denso iridiums in mine and runs smooth and starts quick. Can't tell any difference from the copper plugs I just took out that needed re-gapping every 10K. It's real nice knowing it'll be that way for 100K now.
    Didn't you crack one over tightening when you installed them? Seems kinda unfair to blame the plugs since that could have been the cause for uneven firing.
  8. Sep 29, 2011 at 7:49 AM
    09Doright8126
    Andrew
    Greenwood, SC
    One did crack, and I'm not blaming the plugs entirely on the fact that they didn't work but since the new plugs are installed I might try Iridium next change...
    Edit: http://www.tacomaworld.com/forum/technical-chat/156652-ngk-iridium-spark-plugs.html Others have seen issues also. Not saying that its standard across the board tho. Glad yours are working out.
  9. Sep 29, 2011 at 7:58 AM
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    I just replaced mine again with the Denso IKH20's gapped at .040 and man it runs great. The first time around I had the IKH20 but had them gapped at .044. It made some difference with a smaller gap and most of my rasp noise that I have had with my DTLT's seems to have vanished. It's crazy I know but it did.
  10. Sep 29, 2011 at 8:03 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    my truck liked iridiums too, well it runs fine i mean
  11. Sep 29, 2011 at 8:09 AM
    09Doright8126
    Andrew
    Greenwood, SC
    I definitely would like to run them... next go around I'll try the Denso Iridiums. Thanks guys.
  12. Sep 29, 2011 at 9:21 AM
    saugus
    I know the wires are weird on the v6 but they do use 6 plugs still don't they?
  13. Sep 29, 2011 at 9:28 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    not sure if serious.....
    Midnighttaco08 and RedRed like this.
  14. Sep 29, 2011 at 9:41 AM
    11B4X4
    11B4X4 Well-Known Member
    Northern VA
    2006 tacoma 4x4, Black
    Trd intake, Doug Thorley offroad headers, magnaflow exhaust, RBP running boards, 2.5In spacer, URC O2 simulator, 5100's all around
    Yep, six cylinders, six plugs
  15. Sep 29, 2011 at 2:50 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Iridiums are not necessary but can be used...they have a different temp range then standard copper plugs...Iridums are used in conjuction with TRD SC or any significant modified engine upgrades. I used iriduims on my 05 before I got a SC it wont hurt anything just a little more pricey
  16. Sep 29, 2011 at 2:54 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    They're a waste of money if you're not super charged. NGK's will do you just fine and they hold a better gap than the Denso's.
  17. Jan 8, 2016 at 3:55 AM
    Spider48
    Spider48 New Member
    Owen
    2013 Tacoma
    Xsp-X package
    An Auto Parts Dealer recently tried to convince me to purchase Iridium Plugs for my 2013 V6 Tacoma. Based on the comments I have seen I not convinced either way.
  18. Jan 8, 2016 at 4:55 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The only reason I can see to use Iridium plugs is where its a PITA to change the plugs. On the Tacoma the plugs are right there (unless you bury them under a SC).
  19. Jan 8, 2016 at 5:43 AM
    Pigpen
    Dan
    Northwest Montana
    I put in NGK iridium plugs at 45k. I hadn't read any advice not to prior to installing them. I'm nearing 70k now and they seem to have been fine. I might reconsider when I do the plugs at 90k, but these have worked for me.
  20. Jan 8, 2016 at 5:50 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Subaru specs NGK iridiums on their 6-cylinder Outbacks. Not fun to change plugs on one of them. Very little room to fit a ratchet.
    First time I did it, it took me 3 hours!
    The Tacoma probably took me 45 minutes.
