TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 21, 2019 at 3:23 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
  2. Oct 21, 2019 at 3:28 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Turn the gauge on and pull the tubing off the boost port. What does it read?
    Torspd likes this.
  3. Oct 21, 2019 at 4:58 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
  4. Oct 21, 2019 at 5:11 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    on the topic of boost gauges. could tube density alter readings? my meth gauge has a very small almost rigid line. my aem gauge is larger, softer silicone. there is a tee fitting dividing the two. my aem always reads about 1lb lower. according to previous feedback im more confident in the meth gauge for accuracy. maybe more light can be shead on this topic when @Roostfactor gets his meth system up and going.
    Roostfactor likes this.
  5. Oct 21, 2019 at 6:40 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Interesting, in that both the Tacoma (with Speedhut gauges) and my Shelby (with Autometer gauges) show similar (-20 - -15 in Hg) vacuum readings. Both gauges also show the boost expected, based on the way each vehicle is configured. The Shelby was smoke tested for leaks and the dyno pulls I've done confirm its boost readings are accurate. (Haven't tested or dynoed the Tacoma.) AFR readings in both vehicles also appear good.
    Not arguing with either of you, BTW. Just reporting my observations.
  6. Oct 21, 2019 at 7:24 PM
    findingthingsout
    midwest
  7. Oct 21, 2019 at 7:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yeah! What he said^^^ :anonymous:
  8. Oct 21, 2019 at 8:09 PM
    TRON
    It’s all good brother! I’m curious if this link with the pressure to elevation is accurate to engine idle :thumbsup:
    Norton[QUOTED] likes this.
  9. Oct 22, 2019 at 6:38 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I have noticed vacuum at idle change a fair amount depending on various factors.
    There is not a single correct value.
    Some things that could/will cause it to vary include:
    Idle rpm
    Idle engine load.....a/c, rad fan engagement, etc.
    Atmospheric pressure as discussed
    If tuning yourself, early (low load) VVTI engagement
    Ignition timing, etc.
    They all play a part and now that we have more tuning options, the deviance between two vehicles can be greater.
    Roost
  10. Oct 22, 2019 at 6:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Adding cam gears will also move the vacuum.
    Norton, Anderson, Roostfactor and 2 others like this.
  11. Oct 22, 2019 at 7:09 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    or cams?
  12. Oct 22, 2019 at 7:50 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Or stroke and/or bore? :D
    Yes cams too.
  13. Oct 22, 2019 at 9:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Waiting waiting on my compadres to get their beefed internals in!
    henryp and mightytacoman like this.
  14. Oct 22, 2019 at 10:40 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Question for the double bearing pulley on the Roush tensioner crowd:
    Does the stock tensioner pulley bolt work with the dbl bearing or is a longer one needed? Would prefer to know before I pull everything apart and strand myself on an island.
  15. Oct 22, 2019 at 11:13 AM
    mightytacoman
    Kel
    4.5L 1grfe
    You'll need a longer bolt
    garciav and 12TRDTacoma[OP] like this.
  16. Oct 22, 2019 at 11:19 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Thanks for the heads up!
    12TRDTacoma[OP] likes this.
  17. Oct 22, 2019 at 12:01 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Just heard from BC. Shipping out Thursday he said.
  18. Oct 22, 2019 at 12:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Oct 22, 2019 at 1:21 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Like 4 all of us?
  20. Oct 22, 2019 at 1:23 PM
    mightytacoman
    Kel
    4.5L 1grfe
    He didn't specify. He usually acts like he's in a hurry/busy over that way so I didn't get around to asking.
