TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 20, 2019 at 2:24 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I believe its for the 2013 trucks that had issues with spark knock on the factory ecu. My 2013 did the same thing but i started running premium instead of getting the TSB (solid choice looking back)
  2. Nov 20, 2019 at 2:31 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I don't know about all that. I had spark knock issues from the very beginning with my truck, I don't think I ever addressed it but as soon as I got flashed over to the TRD tune the issues went away entirely which tells me that those knock issues are 100% related to garbage tuning from the factory.
  3. Nov 20, 2019 at 2:32 PM
    BassAckwards
    Could be more widespread, im just speaking from personal experience so i dont end up with my foot in my mouth :D
  4. Nov 20, 2019 at 2:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah no for sure. That's like their PCM issues that they have had with codes involving EVAP and a constant PWM duty cycle for the purge solenoid in models 2000-2005 I want to say, but they addressed a TSB for just 2000-2001 if I remember right on several models. The issue was definitely more widespread though.
    Oh Toyota. What a feeling. Lol.
  5. Nov 20, 2019 at 3:09 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Me neither, I thought it be like reflashing my powerstroke with a sct tuner effectively.
    Could very will be any 1gr my12 and up w/the extra emissions crap. I bought my 09 used yrs ago so I'm not sure if its be recall reflashed (I believe it has) but just wanted to be prepared it I needed to get a new ecu, re key it, etc in addition to blower install.
    BassAckwards[QUOTED] likes this.
  6. Nov 20, 2019 at 6:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    have a good friend around. help on this one is good.
    zippsub9[QUOTED] likes this.
  7. Nov 20, 2019 at 6:44 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Can anyone confirm the ARP exhaust studs for our trucks? The link earlier to Amazon shows a set that is listed for an LS engine and makes no mention of thread pitch. I don’t mind buying new studs and will take the recommendation but I would be stunned if LS engines used the same studs as 1GRs.
  8. Nov 20, 2019 at 6:56 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
  9. Nov 20, 2019 at 7:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  10. Nov 20, 2019 at 7:12 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i think the urd kit has everthing needed.
  11. Nov 20, 2019 at 8:16 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Just about every Tacoma variant (model year, auto, M/T, 4WD, etc) has its own specific ECU and "tune," with unique Calibration IDs. As I recall, these are what Techstream verifies before permitting flash of the ECU.
    T-SB-0044-14 applied to 2012-2014 Tacomas. In my case, running premium didn't eliminate the knock, which is why I made the strategic mistake of having my original ECU updated. :frusty:
  12. Nov 20, 2019 at 8:17 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Torspd[QUOTED] likes this.
  13. Nov 20, 2019 at 8:42 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Thanks for the id's!
    BassAckwards and Norton[QUOTED] like this.
  14. Nov 20, 2019 at 10:13 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    It should. Mine came with new studs...
  15. Nov 21, 2019 at 4:13 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I think I only counted six studs since the instructions only mention replacing the three lower studs on each side.
  16. Nov 21, 2019 at 6:34 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do you need O2 bung extensions? i have some.
  17. Nov 21, 2019 at 6:59 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    The wiring harness extensions to mount the O2 sensors in the collector of the header vice the middle tube.
    Thanks brother. I ordered a set from URD last night. Hopefully they make it by Saturday.
  18. Nov 21, 2019 at 8:24 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Is it the ARB studs? I do not see that referenced on the site.
  19. Nov 21, 2019 at 10:05 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I can take pictures of mine when I get back home, but they come with new header to y-pipe gaskets, six studs, nuts and washers. I need to confirm there are only six and not twelve, implying there were only enough to replace the bottom six. Mine are for a 12-15 SAIS capable system and all the studs are the same length, which only applies to the bottom three on the passenger side of the engine.
  20. Nov 21, 2019 at 2:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    wow. be careful with fedex and insure your valuables. 1st order had almost a full gallon of methanol lost due to damage. second order (replacement) came today. this time another gallon wasted. caps were not on tight. wtf?
