TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 19, 2020 at 10:53 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @TodayWasTHeDaY this can definitely happen. Some sensors need a ground, and they get it through contact with the engine where they screw in.
    TodayWasTHeDaY likes this.
  2. Feb 19, 2020 at 10:56 AM
    Athlaos
    Leigh
    Edmonton
  3. Feb 19, 2020 at 11:05 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    wierd, I didn't get any notification of this tag. Yes, I can dig stuff out of my box if you fellas still need it?
  4. Feb 19, 2020 at 11:23 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    lexus puts electric fans on at the factory. with a good set up reliability shouldnt be an issue.
  5. Feb 19, 2020 at 11:34 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yes you are right, but it comes at a cost. Maybe one day :D
  6. Feb 19, 2020 at 12:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Look up what @Roostfactor did for an electric fan setup, modded into his OEM shroud. It should be in the CSF Radiator thread.
    Roostfactor and Athlaos like this.
  7. Feb 19, 2020 at 1:00 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  8. Feb 19, 2020 at 1:02 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What are all the hoses that they would produce for us.....I’ve only skimmed over some of this hose talk that’s been had
  9. Feb 19, 2020 at 1:08 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    To summarize...and correct me if I'm wrong...
    I think HPS already makes the upper radiator hose for us since the NA and blower is the same.
    But we are inquiring whether HPS can make a lower radiator hose for the trd blower guys/gals as another option versus the ($130) one that comes with the kit. (HPS already has the lower hose for NA)
    The lower hose that comes with the blower kit still needs to be trimmed. Therefore the advantage of a HPS version would be that its silicon, hopefully cheaper, doesn't need to be trimmed.......and pretty colors.
    Peeps found an existing hose (Ford Mustang) that would possibly work as the lower radiator hose that we need and have passed that info to HPS.
  10. Feb 19, 2020 at 1:22 PM
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    Also looking for a cheaper aftermarket replacement less than $130 in any case the lower hose takes a crap.
  11. Feb 19, 2020 at 1:23 PM
    Boozng
    Dave
    On another note, superchargersonline called me back and said the lower hose is backordered from Magnuson, with no eta. So I'm SOL.
    Torspd likes this.
  12. Feb 19, 2020 at 1:27 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Makes sense. I had the red ones but didn’t install them because I ended up finding out the lower one wouldn’t work.
  13. Feb 19, 2020 at 1:27 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Maybe see if a local parts store stocks that mustang hose and just see if it works? That would confirm it for us, and you wouldn’t have to wait for magnuson.
    12TRDTacoma[OP] likes this.
  14. Feb 19, 2020 at 1:28 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Bling Bling!! :D
  15. Feb 19, 2020 at 1:30 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Sucks. I called RLHudson earlier and waited online for "Tucker". It went to a voicemail and I left a message, but no call back just yet. I told them that I found a part that seemed to be retrofitted and had their part number on it, but trying to get more info on its original design and fit.
    Will follow up as I hear anything.
  16. Feb 19, 2020 at 1:36 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
  17. Feb 19, 2020 at 1:42 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Bling factor. Can fit FIC custom injectors. Again more bling. Custom color also.
  18. Feb 19, 2020 at 2:00 PM
    Athlaos
    Leigh
    Edmonton
    I understand one would need to use a simple washer-like spacer about the size of a nickel for each injector in order to use them with the orange TRD injectors, which is what I'll be doing.
    Benefits of performance rails are, as I reason of it:
    1. Adequate delivery of fuel to your injectors resulting in less localized pressure drop. Localized flow problems or flow problems at one or more of the injectors could lead to an unsafe condition in the associated cylinder (lean fuel mixture or incorrect atomization of fuel) at high load. These problems may not be picked up by other sensors installed, such as the knock sensor or a fuel pressure sensor.
    2. Higher headroom at high load conditions for fuel flow (they won't be the bottleneck for fuel delivery).
    3. They is blingy.
    Note, on the 3.0L engine on my car, upgraded fuel rails were required at the 400ftlb mark. Quite different from our trucks though, I realize, since they are side feed injectors, not top feed like ours. The injectors I have there are capable of flowing at 740cc/min, which is probably good for 700ftlbs on that car.
    The benefits of upgraded fuel rails will for the most part be unseen. It's not like suddenly your engine will run more smoothly, or have more power, definitely not at the power and torque that TRD supercharged people see - 300-400ftlbs. But they are good for engine longevity and safety.
  19. Feb 19, 2020 at 2:41 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    The part number I listed, PTR29-35061, is the TRD part number for that part kit. I called Toyota Tech Line and got a replacement part number for that exact hose from Toyota. But yes, it will need to be trimmed still. I believe. I will have the factory TRD part here by Friday. So we can see markings and take measurements.
  20. Feb 19, 2020 at 2:44 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Then I stand corrected. @Murphinator this still baffles me. I don’t get it, but then again, this ain’t the first time.
    BassAckwards and Murphinator like this.
