TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 5, 2020 at 5:20 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Can you list the part numbers you order?
    I am thinking about doing the same/similar thing.
    Thank you.
  2. May 5, 2020 at 6:36 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Credit goes to @12TRDTacoma and @billthecat2.
    I want to try with the AFE intake so there is a risk that it won't work. This trick requires the 4runner MAF sensor and splicing the wires to adapt it. Don't know if the Tacoma sensor fits on it but if it does it might be able to be calibrated with Hptuners.
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-1292#post-23069972
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-1296#post-23101545
  3. May 5, 2020 at 7:07 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The Tacoma sensor will NOT work with this mod.
    Show me a picture of the AFE intake tube and I'll let you know if it does.
  4. May 5, 2020 at 7:50 AM
    TodayWasTHeDaY
    Russ
    Calgary
    As an educated guess I was pretty sure the taco sensor wouldn't fit.
  5. May 5, 2020 at 7:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I really dislike messing with electronic wiring and keeping the OE stuff when possible in the engine bay, so I was really hoping I would be able to keep the OE MAF. Now that it's set though I don't see any issues arising for a long time if ever.
  6. May 5, 2020 at 8:20 AM
    TodayWasTHeDaY
    Russ
    Calgary
  7. May 5, 2020 at 8:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What is your intention of use with that tube?
    Like, are you trying to see if the TRD intake tube will work in place of it?
  8. May 5, 2020 at 9:01 AM
    TodayWasTHeDaY
    Russ
    Calgary
    That is the idea. For the bigger size/airflow scale. I should check my old logs to see where my MAF readings are. I am at altitude so my truck is somewhat neutered.
  9. May 5, 2020 at 9:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We all have a trade off really. I live at sea level but am neutered due to the exhaust manifolds and CARB regulations, you high altitude but no emissions regulations of a strict nature like ours. Lol. It sucks man.
    As for the tube, you should be able to run the FJ/ T4R one. All you need are the tube couplers and the tube itself.
  10. May 5, 2020 at 9:24 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    And the MAF / wiring.
    nudavinci64 likes this.
  11. May 5, 2020 at 9:28 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Looking at my logs from 6 months ago I am safe. I just added cam gears and urd headers and am currently working on porting the SC inlet/outlet, intake runners and adding the 76mm throttle body. I know the throttle body actually increasing flow is up for debate but it does increase the throttle response.
    So the intake tube would likely just be to increase flow. I don't think I'll top out the Maf even with these mods.
  12. May 5, 2020 at 9:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Duh. Lol.
    I meant for physical fitment.
    Are you not seeing your current setup peg you out on the MAF side?
  13. May 5, 2020 at 9:42 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Its totally not. I thought it was reading higher than it actually was.
  14. May 5, 2020 at 10:06 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Did anything ever happen on the custom request for Silicone lower hose?? I found these guys maybe we could send them a hose for them to make a copy of?
    https://www.siliconehose.com/custom-hoses/
    henryp and 12TRDTacoma[OP] like this.
  15. May 5, 2020 at 10:29 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I think because of covid hps is at a stand still currently. More options wouldn’t hurt though so that may be a good option to look into.
  16. May 5, 2020 at 12:07 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Before I saw your post I had sent them an email about buying just the top hose. This is what I got back. Keeping fingers crossed.
    Unfortunately, were are not able to separate the hose kit for your 2011 Tacoma, but we are in the development of producing a lower hose kit for the Tacoma with the super charger kit because we have been getting a couple of inquiries about the lower hose. It should be coming out in a couple of months. Follow us on instagram or facebook for any updates.
    If you have any other questions, feel free to let us know.
    Thank you,
    Gerald Dojillo
    Senior R&D Associate
  17. May 5, 2020 at 12:09 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    thats promising. The couple of months is prob due to not being able to do much right now.
  18. May 5, 2020 at 12:14 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Here is the last info I have on the hps hose:
    @Boozng is the one who sent in a hose for them to scan so they can make a copy.
  19. May 5, 2020 at 12:57 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Looking at getting quick change pulley and put it on when the front end is apart for the NST pulley swap.
    Anyone have a pulleyboys or smoothflow puller I can buy/rent?
    Gonna run HPTuner can I use the TRD injectors? (I searched and see conflicting ideas here but I think I can) if I’ll need bigger injectors I’ll probably just stick to 2.8.
    Planning to get a Steeda tensioner do I also need a wrap or can I just buy shorter belt and the steeda? I’d prefer not to mess with wrap mod as I don’t have access to machine shop although I’m fairly handy with hand grinder.
    I’m sure these have been over covered previously but I can’t find a straight answer.
  20. May 5, 2020 at 1:16 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’m in as soon as they are out. I purchased them a while back like 3 years ago but as we all know the lower wasn’t compatible. At least I was able to sell the ones I bought for what I paid.
    zerotimeouts[QUOTED] likes this.
