TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 4, 2020 at 6:23 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Send to Butthead. I’ll add it to the Kelford thread.
  2. Sep 4, 2020 at 7:40 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Been running them since I got them. Nothing really to report, no issues, same fuel economy. So..
  3. Sep 4, 2020 at 7:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Anyone in here have the ability to bench test coil packs?
    @JustDSM , you know anyone?
  4. Sep 4, 2020 at 7:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What is it you would be looking for? Hotter spark as in more Kv?
  5. Sep 4, 2020 at 7:47 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  6. Sep 4, 2020 at 7:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Exactly^^^
  7. Sep 4, 2020 at 7:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Sep 4, 2020 at 7:53 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Sadly I do not :(
    I had some contacts back in the day, but I'm not sure those folks are even in the industry anymore.
    Torspd[QUOTED] likes this.
  9. Sep 4, 2020 at 9:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh. That post. I saw that one a while ago, you know, a small part of me thinks the RIPPs may not be necessary if you are running the Rutheniums because any MPG gains which may be had with the RIPPs have shown me none have been obtained by the "hotter" coils.
    I almost am going to venture out on a limb here and say this: If you run Iridiums and have no intention on switching out to Rutheniums then it may be a worthwhile mod to you. If you do plan on switching to Rutheniums then the mod may not be worth the money and energy invested required to do the swap over.
    As of right now I am on track to making a never before tracked (via odometer trip meter) 255 miles to the tank. I am currently sitting at 210 miles right at 1/4 tank. I am anxious to see what my max range will be before I consume 17.4 gallons (when the low fuel light comes on for our trucks) I'll report back what my final range is when I get there which should be in the next day or two at most.
  10. Sep 4, 2020 at 10:07 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    How much money are we willing to spend chasing MPG improvements in a supercharged pickup, and will we ever get it back?
    I swear everything I've done to my truck has slaughtered my mileage.
    Bone stock, living at high altitude and running non-ethanol gas: 19-20mpg
    California sea level crummy gas on 31.5" tires: 17
    Added Relentless aluminum front bumper: 16-ish
    Supercharged: 15.5
  11. Sep 4, 2020 at 10:27 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think my all metal hybrid bumper along with the 140+ lbs of skids has killed my mileage.
    At this point the mileage increase is a perk. We aren't doing the mods for mileage though, the mileage is secondary the power gains is what we are still after. However small they may be.
  12. Sep 4, 2020 at 10:46 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Add some cam gears
  13. Sep 4, 2020 at 11:02 AM
    Voodoo Rufus
    Bakersfield, CA
    Got those already. Came with my UCON.
    Athlaos and mightytacoman like this.
  14. Sep 4, 2020 at 11:41 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    But I bet your smiles per gallon are at an all time high. How can you put a price on that? :burnrubber:
  15. Sep 4, 2020 at 12:38 PM
    Voodoo Rufus
    Bakersfield, CA
    The Tacoma is still the second slowest thing in my stable. :D
    Sportbike > Tuned STI > S/C Tacoma > N/A Forester
    jamesepoop and Athlaos like this.
  16. Sep 4, 2020 at 12:57 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Mine might be the fastest as heavy and slow as it is lol. Tacoma > 4Runner and dirt bike are probably the same > Race support Elantra
    jamesepoop, JacksonTacoma and Athlaos like this.
  17. Sep 4, 2020 at 1:31 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    I think my girls 2012 rav4 V6 would give mine a run for its money.
  18. Sep 4, 2020 at 2:15 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Mines the slowest :anonymous:
    F80 M3> GEN 2 R8> S/C Taco
  19. Sep 4, 2020 at 2:29 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    TT swap 300ZX > SC Tacoma
    Although my one buddy swears my truck is faster than my car. It's really not, but he's just in love with the truck...
  20. Sep 4, 2020 at 3:45 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Doing a log tonight. Seeing what kinda Rpms she can run. She loved it. Except for the knock :(. 0EFFD005-A31B-4F90-BDFB-7223A8080ACA.jpg
    jamesepoop and 12TRDTacoma[OP] like this.
