TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 16, 2022 at 7:01 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    @SUMOTNK thanks man. I enjoy it when others get a kick that it looks like toy. The 39s were looking small. I'm going to 40s soon!
    Once upon a time, 37s.
  2. Apr 16, 2022 at 7:06 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I like the way this guy thinks^^
    jamesepoop likes this.
  3. Apr 17, 2022 at 9:36 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Gonna want to look into JD fab inner fenders if going to 40"
  4. Apr 17, 2022 at 10:07 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Gonna want to look into JD Fab inner fenders if you're going to drive at all.
  5. Apr 17, 2022 at 11:14 AM
    jamesepoop
    California
    2007 Fj Cruiser
    Weren't they only tested to 37" tires? I'll have to look see. I may ask JDfab about doing the rear end to the Ford 9 at this time. May just cut and patch parts where it's not clearing not too concerned with looks as it's just bashed in with a BFH and self clearanced at the moment. Got the job done.
    SUMOTNK and scootter82[QUOTED] like this.
  6. Apr 17, 2022 at 1:01 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    And here I was getting excited going to a stock size tire that was a pound lighter than the current stock size tire I have...
  7. Apr 17, 2022 at 4:05 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    For the 2nd Gens..
    Found my solution for the AC Auxiliary fan activation for the upcoming E-fan conversion.
    I'll be adding a add a circuit to the 10amp AC fuse that's located in the engine bay fuse box. I get constant 14+ volts when the AC is on and running, no matter the state the compressor clutch is in. Zero volts when the AC is off.. This will activate a relay that will run a Auxilary AC Compressor Fan.
    Zero volts with AC off
    Mini LED indicator lights will be installed next to the gauges to show fan operation. E-fan LED light will turn on when at 100% command, trans cooler fan will turn on whenever that fan is on.
  8. Apr 17, 2022 at 4:09 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Could I use this for a 32” light bar?…..using a add a fuse.
  9. Apr 17, 2022 at 4:13 PM
    MonkeyProof
    SoCal- SGV
    Lmao..
    All you need is a suitable trigger/activation for a relay right? Theoretically you would run it off a relay right!?
  10. Apr 17, 2022 at 4:14 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yes. Believe it came with a relay
  11. Apr 17, 2022 at 4:17 PM
    MonkeyProof
    SoCal- SGV
    ....why would you want a light bar to turn on when the AC is turned on?
    henryp and TodayWasTHeDaY like this.
  12. Apr 17, 2022 at 4:22 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I figured that is when it would have power (ign on or acc on) to be able to then turn on if I hit the switch. Sorry, I’m just trying to be able to remember how to wire shit up since it’s been a while
  13. Apr 17, 2022 at 4:26 PM
    MonkeyProof
    SoCal- SGV
    Oh ok. It would be more suitable if you wire the relay to a 12v switch in the cab. the switch is attached to a constant 12v source.
    edited:
    JuanitoBonito[QUOTED] likes this.
  14. Apr 17, 2022 at 5:13 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Interesting…. You would be adding a 3rd fan? I’m going to have to come hang out at your house. Now let’s figure out the e fan. Are you going to use tie lingen whatever controller for the efan?
  15. Apr 17, 2022 at 5:23 PM
    nudavinci64
    Robert
    Maybe you can piggy back off what this guy did. There should be one open relay spot for a clean install. Assuming you are planning to add a fan up front.
    https://www.tacomaworld.com/threads/a-c-condenser-fan.239576/
  16. Apr 17, 2022 at 5:24 PM
    MonkeyProof
    SoCal- SGV
    yes, the breakdown...
    The Lingenfelter will be the controller for the E-fan. Trans Temp gauge will be the controller for the trans cooler fan. The 10amp AC fuse will be the controller for the AC Condenser Fan. Being in SoCal with the hot climate it's essential to have a seperate AC condenser fan in working relationship with a e-fan conversion. There isn't at this time a PWM fan controller available that has a proper AC fan trigger/controller. So, a seperate AC fan is necessary
  17. Apr 17, 2022 at 5:26 PM
    MonkeyProof
    SoCal- SGV
    nice find, I haven't seen this thread until now. I shall dig into it..
  18. Apr 17, 2022 at 5:27 PM
    nudavinci64
    Robert
  19. Apr 17, 2022 at 5:45 PM
    MTB Tac0
    MTB Tac0 Active Member
    Just finished changing my plugs for the first time, can't figure out where this last hose on the driver's side hooks up, any hints?
  20. Apr 17, 2022 at 5:51 PM
    MonkeyProof
    SoCal- SGV
    Probably won't wire in a kill switch. That would be simple though, a switch on the ground side of the relay.
    I am debating on wiring a kill switch for the leginfetler controller for water crossings..
    HappyGilmore and scootter82 like this.
