TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 4, 2022 at 12:41 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Ya I tried to tie the front sensors to the rear on a different truck and the signal would get all screwy throwing the po500. I glued the magnet ring from a Toyota bearing to the hub and mounted the sensor and it worked, but really needs to be sealed. Also I found the old style tone rings metal style with a jeep jk sensor works with the Toyota abs with a 52 tooth ring almost identical read outs until about 35mph.
    On my personal truck I went with a Currie axle with 4 runner bearings to not have to deal with the abs issue. Prolly possible to use a magnet strip from a bearing on your full floater. Another option would be to add another sensor to your front spindles
    Airdog likes this.
  2. Jul 4, 2022 at 12:59 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    There is absolutely no reason why I'd want to add the sensors back into the equation on my truck. ABS/VSC/Trac is out to kill you offroading anyways....which is why almost everyone disables it offroad. I'm also of the opinion that ABS is not a system to be "rigged" in order to make it work. You either disable it or you keep it going with the stock components/configuration. The last thing you need is the ABS to decide it gonna do its ABS thing when its not needed because of something you rigged to make it work.....its a recipe for disaster. At one time I was all for the currie setup that kept the abs sensors and the system working but by the time I decided to start doing it they discontinued making that axle for the tacomas. It was then that put me on the path to figure out the speedometer issue so I could just go full float and call it a day.
  3. Jul 4, 2022 at 1:50 PM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Ya I”d keep it disabled for sure but other member trying to smog his car is a different story
    Airdog likes this.
  4. Jul 4, 2022 at 8:06 PM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Anyone have there belt start to walk off? Opened the hood today noticed the belt had a thread hanging off it was off 2 groves on the crank and 1 grove on the bottom left. All stock setup less then 100miles almost certain it was put on correctly everything looks aligned and correct
  5. Jul 4, 2022 at 10:13 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    maybe early belt failure? Old belt at installation? Got any fluids leaking onto the belt causing it to fail? It’s a bit of a pita to change but these things go so often that I keep a spare just in case.
  6. Jul 5, 2022 at 5:02 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Aftermarket pulley or stock 3.0"? I'd check all the ribbed pulleys for correct spacing. Mine rides really close to the the edge of the idlers but hasn't moved anywhere beyond. Stock length belt with 2.7 smooth flow pulley, roush tensioner, nst crank pulley.
  7. Jul 5, 2022 at 7:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When I did the T56 swap into my 4x4, I used the sensor wires from the Toyota trans for the speed signal, with the Dakota Digital box. I am pretty sure that I still have the wiring diagram for which wires to tap into, in the ecu. Interestingly enough, they were the same wires that the XRunner used. If that means anything.
  8. Jul 5, 2022 at 8:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup, I still have them.
    DocME likes this.
  9. Jul 5, 2022 at 8:21 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    The sensor that went to the transmission? I couldn’t get that signal to operate the speedometer. I fed them to wires at the abs unit. Which should of been the same wires for speed input behind the cluster according to the diagram I followed and wire I metered. That’s the sensor that worked for me on digital speed input but the speedometer never moved. It populated speed to the ecu and my check engine light stayed off.
  10. Jul 5, 2022 at 8:22 AM
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Would you mind sharing them to me? I want to compare what I’ve been trying.
  11. Jul 5, 2022 at 10:56 AM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Brand new kit no fluids leaking all STock setup
  12. Jul 5, 2022 at 12:18 PM
    jamesepoop
    California
    2007 Fj Cruiser
    I would check belt alignment religiously. 100 miles isn't very much at all. If wear on all the pulleys have good engagement and looks straight, there's probably an obstruction on the pulley or belt issue. Pull off belt and inspect is my final answer.
  13. Jul 5, 2022 at 12:27 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pretty sure the 2012+ trucks have a way different cluster setup which is why that same fix may not work for you.
  14. Jul 5, 2022 at 12:35 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Can confirm. Don't recall the specifics, but they are indeed different.
  15. Jul 5, 2022 at 12:42 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Never had a belt problem like that. You have something not in alignment somewhere. Get a ruler out and start aligning pulleys.
  16. Jul 5, 2022 at 2:32 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Recheck the pulley's and how they're riding, the tensioner, and straight edge that alignment too.
  17. Jul 5, 2022 at 9:37 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My money is on a mis-install of the belt itself. It's very easy to miss on these trucks and when it is missed you usually pay dearly for it.
  18. Jul 5, 2022 at 9:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here's a question for the group,
    Any of you boys got a pair of CV axles in good condition? I really would rather not go aftermarket, and CV axles have been an issue for me since like 50K and I just want a new set to replace the current junk I have. Wanting a clean set in good shape.
    If you have some that you would be willing to part with, let me know. Apparently, reman is on backorder currently according to Toyota. o_O
  19. Jul 6, 2022 at 5:18 AM
    DocME
    California
    '07 FJ Cruiser
    What’s failing on the axles? The bearings rarely go out. Most remans are a grease and boot swap. Very easy to do and would save you quite a bit of money. I’d venture a guess that you could rebuild both axles in an hour once out of the truck.
  20. Jul 6, 2022 at 6:10 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Rebuild (actually reboot and regrease) the axles. It's not difficult at all. An extra set of hands may be helpful for one or two things, but not 100% necessary.
    I have some pics in my build thread. https://www.tacomaworld.com/threads/scott-b-s-2015-ac-build-expo-style.368814/page-14
