TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 1, 2019 at 9:12 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I put in right around 10 if I remember
  2. May 1, 2019 at 9:16 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Wow. I had trouble getting into AT temp mode so I just drove around some to warm up the engine then removed the fill check plug while running. When nothing came out, I shut it down then add until fluid starts to drip down and repeat. I will drive around and check again tomorrow.
  3. May 1, 2019 at 9:24 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ahh. I did this too to get the temp to 130, and around a half quart max came out at exactly 130 degrees
  4. May 1, 2019 at 10:21 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You need an intake as it is an absolute bottleneck.
    With doing all the stuff you listed as well as an intake you will be very happy with the results.
  5. May 2, 2019 at 5:47 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Pulley press on tool would be helpful too.
    RyanL[QUOTED] likes this.
  6. May 2, 2019 at 6:37 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I have a snout cutter for sale guys. Figured I'd post here before making an ad. PM me for details.
  7. May 2, 2019 at 6:50 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Please buy the quick change setup guys. I helped pull a urd stealth pulley last night. An absolute bastard.
  8. May 2, 2019 at 7:56 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I showed you my pulley pls respond.
    GT7 likes this.
  9. May 2, 2019 at 8:19 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I'm leaning toward the AFE Magnum Pro Dry S, seems like the fellas here like that one.
    henryp and JuanitoBonito like this.
  10. May 2, 2019 at 8:52 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ha! ask @crashnburn80. It was his. Mangled.
  11. May 2, 2019 at 9:00 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, that URD 2.85 was worse to get off than the stock one. Completely mangled. Part of it was trying to secure the jaws of a 10-ton pulled behind it. Can post pics this evening.
  12. May 2, 2019 at 9:03 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Pulled my 2.825 this past weekend. Mangled the red pulley when trying to pull it from the back lip. I found that pulling it from the front lip worked much better. Slightly thicker material to grab onto from the front.
  13. May 2, 2019 at 9:35 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The aluminum pulley comes off much easier than the steel one.
  14. May 2, 2019 at 10:28 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would go with the Momentum. It is a much larger design and looks more refined than the previous version.
  15. May 2, 2019 at 11:19 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  16. May 2, 2019 at 11:27 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    @TheFang I didn’t realize the damage rate on URD pulleys. I will let you know after this weekend with pics how it fairs. I will add a little heat for expansion to help the removal process.
  17. May 2, 2019 at 11:56 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I massacred mine and had to remove it with a dremel and very steady hand when I removed my URD pulley. I sliced the shaft a little bit by the time it was all said and done but it does not affect the blowers performance.
    DO NOT use heat expansion for that pulley! It will end up warping the bore of the pulley and will make it nearly seize on the shaft since the two are dissimilar metals. Just use a good old fashioned quality 3 jaw puller and it should come out. Bent albeit, but it should come out without issue.
    zippsub9[QUOTED], Norton and DocME like this.
  18. May 2, 2019 at 11:56 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Doesn't help as much as you would hope, or experience with other setups. If you actually do get enough heat in the pulley to make a difference (torch) you'll probably compromise the seals in the nose cone. I've got a jacked up red pulley at home as well. That thing was son of bitch. I ended up buying a three jaw puller and that thing made short work of the pulley. Here' the link: https://www.amazon.com/gp/product/B002RCNKMO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I HIGHLY RECOMMEND THIS PULLER. It did an awesome job. Also it looks like the price went up about $20 from when I bought it. Interesting.
    Norton and 12TRDTacoma[OP] like this.
  19. May 2, 2019 at 11:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    OTC is one of the quality pullers out there, along with Mac, Matco, and Snap-On. I wouldn't use any other brand or it could explode in your face quite literally while attempting the removal. Lol.
  20. May 2, 2019 at 12:00 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I was unaware of this as well.... I did just pick up a snout cutter from @White lightning boosted so that may push me to do a 2.7 from the get go.... let me know how it goes. Good luck!
