TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 24, 2019 at 4:22 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Anybody know what would cause slight clutch pedal vibration when the pedal is all the way up and at certain rpms.
  2. May 24, 2019 at 5:40 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I already got one actually. I just picked up the MAF and it is ready to install! I can't do it until Monday, however, because I am currently not in town.
    Sounds like a flywheel imbalance.
  3. May 24, 2019 at 6:11 PM
    TRON
    Yeah possible. But it doesn’t vibrate at all when shifting gears though. @12TRDTacoma
  4. May 24, 2019 at 8:25 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Who is welcoming some boost to their family? 60584132_2417469468305512_29827898815262_87a531a3754d76138a220655f78e0ab2670704c4.jpg
    60882043_2417469478305511_81715348810718_d809aa63932f724ecf10c8c18c6879c3b1db5b0e.jpg
  5. May 24, 2019 at 8:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Just the clutch pedal vibrating at certain rpms? Is it while decelerating, or when does it happen?
  6. May 24, 2019 at 9:28 PM
    TRON
    Doesn’t happen really with decelerations. The clutch pedal only vibrates when fully up and at certain speeds/rpms of gears. Slowly accelerating in a gear the speed/rpm will hit a window of the vibration. And it’s a pretty small window for vibration within 200/300 rpms. @BassAckwards
  7. May 24, 2019 at 9:43 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Just upset a tundra on stock tires from a dig. Poor guy :muscleflexing:
  8. May 24, 2019 at 9:45 PM
    TRON
    Yup tundras are just way too heavy
    GT7 likes this.
  9. May 24, 2019 at 9:53 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Well I reckon I could upset a lot of cars, sports cars if I went back down to stock tires. But the 35’s and all the steel added I’d be hard pressed to beat anything quicker than a cts-v. I live too far from Mexico for any testing though.
  10. May 24, 2019 at 10:02 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    What did you do to delete it? I want...
  11. May 24, 2019 at 10:12 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Tundra had stock tires. I have my 285s
    snowsk8air2[QUOTED] likes this.
  12. May 24, 2019 at 11:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    How bad is the vibration by the way?
  13. May 25, 2019 at 12:31 AM
    TRON
    It’s a slight vibration. Yet pretty noticeable.
  14. May 25, 2019 at 10:34 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hmm... okay so either there is a flywheel imbalance or the throw out bearing is having issues.
    It could be feedback though also to be honest with you. You are not supposed to touch the clutch pedal at all until you are absolutely committed and ready to make the shift. I have felt other cars at certain higher RPMs where they exhibit the same sort of vibration you are describing. It may not be outside of the realm of normal.
  15. May 25, 2019 at 3:33 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Perhaps he wasn’t all in, but the new Raptor was behind me.
  16. May 25, 2019 at 4:05 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    My new 3rd member and rear axel ship soon. 4:10's and a new trutrac. Time for some (closed course) performance tests this summer.
    loginfailed and BassAckwards like this.
  17. May 25, 2019 at 4:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Now just need to find a home for my stock offroad axel and 3rd member.
  18. May 25, 2019 at 5:13 PM
    ThomasMore66
    Attic. That’s where my stuff goes.
    Torspd likes this.
  19. May 25, 2019 at 5:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Have no attic. Sell it!
  20. May 25, 2019 at 6:51 PM
    ThomasMore66
    That works too. I will never reinstall all the parts I’ve removed.
