TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 10, 2019 at 5:13 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Made the pile of parts in the garage smaller today...
  2. Jul 10, 2019 at 5:18 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Are you getting cams sir?
  3. Jul 10, 2019 at 5:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    It does seem that belt slip is more of an issue the faster it turns. I can see the boost going up and slipping down on my snow gauge and its most noticeable at wot in high rpms
    thanks for posting that chart they sent you man. Pretty interesting stuff for us still running UCon. Makes you wonder what other kind of weird stuff it does behind the scenes:spy:
  4. Jul 10, 2019 at 5:29 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Uhhh... depends how my strategy to become independently wealthy in the next little bit goes.
  5. Jul 10, 2019 at 7:14 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Prezzie on the porch today.
    JacksonTacoma, Norton, DocME and 2 others like this.
  6. Jul 10, 2019 at 7:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
  7. Jul 10, 2019 at 7:29 PM
    BillDaCat8
    Jake
    PHX
    exactly.
  8. Jul 10, 2019 at 7:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If it is the member from XRU, in days long past, that was Sparkys Tacoma. Blew his stock engine. Also adapted an automatic into his XR. Built another engine, did massive Intake plenum porting, and dropped psi down from 16 to ~9. Plus had headers etc.
    Remember though, that tiny aftercooler gets saturated pretty damn quickly, with all stock cooling components, and boost that high. Meth, or increase the size of the aftercooler. ( Internal to the s/c)
  9. Jul 10, 2019 at 7:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yep, meth helps in some of lifes situations.
  10. Jul 10, 2019 at 7:47 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yep, meth was my next step, if that pesky cam GB doesn’t get in the way.
  11. Jul 10, 2019 at 8:00 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    There is a 15% discount on snow purchases. PM for details.
  12. Jul 10, 2019 at 8:23 PM
    DocME
    California
    '07 FJ Cruiser
    The “racer” code?
  13. Jul 10, 2019 at 8:27 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes. I have other ideas too.
  14. Jul 10, 2019 at 8:33 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Which would you reccommend... stage 1 or 2.5?
  15. Jul 10, 2019 at 8:36 PM
    DocME
    California
    '07 FJ Cruiser
  16. Jul 10, 2019 at 9:34 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I hear coke...a cola is great too...
  17. Jul 10, 2019 at 10:06 PM
    Athlaos
    Leigh
    Edmonton
    My strategy will be to get snakebite, do extensive porting, and then put a smaller pulley on to bring boost back up to 16.
    BassAckwards, 12TRDTacoma[OP] and GT7 like this.
  18. Jul 10, 2019 at 10:55 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Don't chase numbers bud. I know it's tough because it's sort of a bragging rights thing, but just remember, your 13 or 14 psi after all the airflow mods could beat the same dude who is 13 or 14 psi next to you.
  19. Jul 11, 2019 at 12:42 AM
    Athlaos
    Leigh
    Edmonton
    Sounds like you're jealous of the boost I make. ;)
    I'm actually offended you think I'm chasing numbers for bragging rights. Well I'm not really offended, since I guess I am chasing numbers to an extent. But if I want to chase a number, why shouldn’t I? Someone has to do it.
    I am the first one to know that boost doesn't equal power or ability to win a race. If I thought that way, I would have blown my engine ages ago. I'm certain my truck's barely noticeably faster than people running 2.3 pulleys on here. My friend got a 94 tune on his NA x-runner and he's as fast as me now. Significant weight advantage, smaller tires, better aerodynamics go a long way. It makes me a bit frustrated given the money and work I've put into the truck. But I remind myself they're completely different vehicles.
    It's definitely an exercise in diminishing returns when you go smaller than 2.3, that's something I've learned. Airflow is getting pretty limited when you start boosting that high on stock everything. So saying I make 16psi isn't really bragging anyways.
    TodayWasTHeDaY likes this.
  20. Jul 11, 2019 at 6:10 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bragging rights.
    :D ;)
    Athlaos[QUOTED] likes this.
