TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 25, 2019 at 7:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have will? It will be done.
  2. Jul 25, 2019 at 7:32 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    50mm pulley is smaller than the OE size which is 54.58mm.
  3. Jul 25, 2019 at 7:40 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks. Now I can tighten my belt wrap a little more.
  4. Jul 25, 2019 at 7:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    For any pulleys smaller than 2.6 I actually recommend running @BillDaCat8 pulley "noose wrap" mod.
    Problem is, you need access to the lathe and you create one more rotatational load in the idler system so it's one more idler which can go bad, or make noise.
  5. Jul 25, 2019 at 7:46 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So the jfr belt wrap you dont find enough help from?
  6. Jul 25, 2019 at 8:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I pulled mine off in attempts to isolate the noise I had when I had squeaks from the supercharger system and have not out it back on since because I want to make sure that I minimize the amount of idlers I had in the system.
    My 2.3 is too small to benefit I feel like. I might be wrong though.
  7. Jul 25, 2019 at 8:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So you're not running any belt wrap currently?
  8. Jul 25, 2019 at 8:18 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    At this point there’s no turning back
  9. Jul 25, 2019 at 8:26 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Dude. Buy and mod the idler like I showed you. Use the Gates RPM belt intended for our trucks.
  10. Jul 25, 2019 at 8:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Tell more about this. Did I miss this in the past?
  11. Jul 25, 2019 at 8:29 PM
    BillDaCat8
    Jake
    PHX
    zippsub9 and Norton like this.
  12. Jul 25, 2019 at 8:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    But... It needs lathe work. Lol.
    Post 1
  13. Jul 25, 2019 at 8:34 PM
    BillDaCat8
    Jake
    PHX
    Got a drill press?
  14. Jul 25, 2019 at 8:39 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That was my first thought. Huge drill bit needed.
    12TRDTacoma[OP] likes this.
  15. Jul 25, 2019 at 8:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not even at work. :(
  16. Jul 26, 2019 at 8:16 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Wasn't it you who just told me to get rid of my noose wrap?? Lol!
    Edit: I guess you didn't tell me to get rid of it, just to get rid of part of it.
  17. Jul 26, 2019 at 9:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Someone did. Said it was too much contact. Let's find them and shame them. Rarr.
  18. Jul 26, 2019 at 9:40 AM
    Athlaos
    Leigh
    Edmonton
    @12TRDTacoma I'm pretty sure it was you. What are you doing, giving people contradictory information! Hahaha. Just pulling your leg.
    BassAckwards and 12TRDTacoma[OP] like this.
  19. Jul 26, 2019 at 9:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm all for my pulley contact and wrap, but too much is actually bad for you. Lol. So the upper pulley is okay, but remove the lower one or remove the upper and run the lower. It just depends on your pulley size and how much wrap one provides over the other.
  20. Jul 26, 2019 at 10:40 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Yes there is. Get OV Tune's OBD2 ECUtek cable, get a 2-day sub to Toyota Techstream, and you can reflash yourself. Annoying, but I did it.
