TRD off road wheel offset vs TRD pro wheel offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Mar 23, 2023.
  1. Mar 25, 2023 at 2:57 PM
    #41
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  2. Mar 25, 2023 at 5:45 PM
    #42
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    I don't care. I laugh. Y'all amuse me. :D
    RIX TUX likes this.
  3. Mar 27, 2023 at 10:27 PM
    #43
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I believe my post in a thread about wheel spacers may have the information you're looking for. I was specifically referencing 2" wheel spacers, or the equivalent of an offset reduction of 50.8 mm, but a proportional added load would apply to smaller changes in the offset as well.
    I was mostly discussing added load applied to bearings here, but there would be added load applied to the ball joints and shock/spring as well.
    glockman, BLtheP and RicerRabbit like this.
  4. Mar 27, 2023 at 10:39 PM
    #44
    MGMDesertTaco
  5. Mar 28, 2023 at 2:58 PM
    #45
    RIX TUX
    I don't care about wheel spacers
    ok then show me the data for added load and wear between the OR and PRO wheel
  6. Mar 28, 2023 at 3:08 PM
    #46
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    ….it’s the same concept. Take the 2” spacer he used (50.8mm) and sub 12mm in place of it.
    Installing a 13mm offset 16x7 in place of a 25mm 16x7 is the exact same concept as using a 12mm spacer on the +25mm 16x7. This can’t be that hard to grasp.
    pstod14, glockman and blu92in99 like this.
  7. Mar 28, 2023 at 3:56 PM
    #47
    RIX TUX
    12 is not 50 ....just show me the wear and tear difference between the 2 wheels
    and you typing it is not data
  8. Mar 28, 2023 at 7:06 PM
    #48
    Jeff Lange
    Calgary, Canada
    With the stock TRD Off Road wheels, the inner bearing sees a load equal to 43.3% of the wheel load, the outer sees a load equal to 143.3%.
    With the TRD PRO wheels, the inner bearing sees a load equal to 83.3% of the wheel load, the outer sees a load equal to 183.3%.
    The inner bearing load is increased by 92.4%, the outer bearing load is increased by 27.9%.
    The added load from the TRD PRO wheels means the wheel bearing life expectancy will be 43.9% of what it would be with the TRD Off Road wheels. It's probably still a really long life expectancy - obviously within Toyota's engineering standards, but it is a significant reduction.
    Jeff
  9. Mar 28, 2023 at 7:17 PM
    #49
    MGMDesertTaco
    we're splitting hairs here
  10. Mar 28, 2023 at 7:37 PM
    #50
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Wider stance (more poke / more negative offset / etc) puts more stress on wheel bearings, due to the additional leverage against the wheel bearings, due to increased lateral forces on a bearings designed for vertical forces. This applies only when the same width wheel is pushed further outwards, not when a wider wheel expands in both directions. This is not even open to debate. The effect will be greatest on the front wheels where the stub-axles have minimal support for the bearings supporting them.
    The Toyota Tacoma pro wheels have only a very minimal amount of additional poke, so the effect is likely negligible. However, it probably could be measured over the life of the vehicle if you sat down to do it.
    The reason why Toyota only adds 1/2” of poke on the Tacoma Pro wheels, when they could have easily added up to 1” of poke or more, is mainly so the wheels stay within the fenders, but also, to a lesser extent, so they don’t have to deal with wheel bearing issues over the life of the vehicle.
    glockman and RIX TUX like this.
  11. Mar 28, 2023 at 8:06 PM
    #51
    Jeff Lange
    Calgary, Canada
    It's an approximately 66% reduction in rated bearing life (see my previous post). It's certainly not negligible, but the bearings are also likely rated for much longer than the expected life of the vehicle.
    Jeff
  12. Mar 28, 2023 at 9:23 PM
    #52
    RIX TUX
    blowing smoke
    why would toyota put this wheel on the top model if this is true?
    the lawsuits would never stop
  13. Mar 28, 2023 at 9:45 PM
    #53
    Jeff Lange
    Calgary, Canada
    I mean... I'm an mechanical engineer who has designed wheel hub assemblies and braking systems. I can assure you my analysis is sound, and I'm certainly not blowing smoke. That's just the mechanics of altering wheel offset.
    If you actually calculate the L10 bearing life with the TRD Pro wheels, it would be still be rated for more than 2 million miles. I'm sure the engineers at Toyota also ran that calculation, among others before specifying the wheels.
    Just because this wheel has a lower bearing life than that wheel doesn't mean either reduces the bearing life to below Toyota's reliability threshold. There's not going to be any lawsuits.
    Toyota likely designed the hub and suspension geometry around a lower offset wheel and specified the bearings as such, not to mention I'm sure a healthy margin of safety. Once you do that, you can easily run higher offset wheels and see longer bearing life. Nobody complains about longer bearing life.
    Next time why not just do the analysis yourself? You’re basically arguing that a longer wrench doesn’t make it easier to loosen a bolt.
    Jeff
  14. Mar 30, 2023 at 3:10 PM
    #54
    Atoll93
    Atoll93 Member
    Casey
    Maryland
    2023 LR TRD OR
    This isn't true because Rix doesn't want it to be true. Don't you understand?
  15. Mar 30, 2023 at 3:25 PM
    #55
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    That's your opinion flat lander... I drive a shit tone in blizzards... I want to be as visible as possible. Most of my driving is in Wyoming and Colorado. Both states will pull you over for driving on a highway with a light bar... I'm not try to blind on coming traffic. Or look cool... I'm trying to give the car in the other lane .9 seconds more possibly to see me.... that's ultimately the goal and reason why DOT requires lights. Better visibility.
    So you want raptor lights here.
  16. Mar 30, 2023 at 3:42 PM
    #56
    BLtheP
    Plano, TX
    eh....people make these arguments, but when is enough lighting enough? Are the headlights, parking lights, and fogs not good enough? What makes adding raptor lights adequate? Why not multiple sets of raptor lights? I get your point, but it could go on forever....most folks raptor lights aren't that bright anyways.
    blu92in99 likes this.
  17. Mar 30, 2023 at 4:12 PM
    #57
    blu92in99
    Elk Grove, Ca
    Ooh, I touched a nerve! :burp:
    This flatlander spends most of the winter season well above the snow line. White-out conditions are nothing new. A few low-powered LEDs in your grille, putting out the equivalent to a couple 194 marker bulbs ain't making a difference in blizzard conditions.
    I don't believe in light bars on public roads either.
    Sorry my opinions offended you, but that's all they are. Opinions. Like assholes, everybody has one.
  18. Mar 30, 2023 at 6:15 PM
    #58
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Does this mean a 0 offset wheel with the same backspacing as OEM will put less stress on the bearings?
  19. Mar 30, 2023 at 6:16 PM
    #59
    Jeff Lange
    Calgary, Canada
    No. Equivalent load is applied at the center of the wheel, which is what offset measures.
    Jeff
  20. Mar 30, 2023 at 6:25 PM
    #60
    blu92in99
    Elk Grove, Ca
    *you're, and *their. I never said DOT or the FMVSS was wrong, just doubtful your truck is any more visible in a blizzard because of a couple tiny LEDs in your grille with the candle power of a Bic lighter.
    Sorry about your penis. :notsure:
