TRD off road wheel offset vs TRD pro wheel offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Mar 23, 2023.
  1. Mar 30, 2023 at 6:25 PM
    #61
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I would assume that you would have to have identical specs to the stock wheels, to have the bearing being in the perfect location for longevity. I believe the stock wheels are not 0 offset. If you did the math, you might be able to come up with a different combo that puts the center of the contact patch of the tire, in the same location as stock, but with different offset and backspacing, but you’d have to think about it.
    Ultimately, nobody is really interested in aftermarket wheels that keep the tires tucked inside the fenders, like OEM Tacoma wheels do, so most options introduce more poke. The only exception would be wider wheels that expand inwards and outwards.
    So many people, like me, run the 4Runner wheels, that give you about 1” more poke on a Tacoma, without any immediate issues. I ran to the Arctic Ocean and back on my 4Runner wheels and my bearings are still fine, even after 1000’s of gravel miles.
    When and if my bearings blow out, it will have been worth it for having such nice wheels for so many miles.
  2. Mar 30, 2023 at 6:30 PM
    #62
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Good to know. I just put some 0 offset 16x8s on my Tacoma, so about the same poke.
    Stocklocker[QUOTED] likes this.
  3. Mar 30, 2023 at 7:01 PM
    #63
    Stocklocker
    17TRDORDCSBAT
    Nice!
    e6400ultra[QUOTED] likes this.
  4. Mar 30, 2023 at 8:42 PM
    #64
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    There isn’t really any math to do. Offset measures the distance from the mounting face to the centre of the wheel. If you have the centre of the contact patch in the same spot the offset will be the same. It doesn’t matter how wide or what the backspacing of the wheel is.
    Jeff
  5. Mar 30, 2023 at 9:41 PM
    #65
    Stocklocker
    17TRDORDCSBAT
    You are disregarding the fact the mounting face of the wheel may not be directly over the desired center of force on the bearing carrying the load. Certainly the hub face is not directly over the center of the bearing, which is why Toyota puts positive offset (inward / negative poke) wheels on the Tacoma. The wheel extends inwards into the front hub assembly, to center the tire contact patch over the bearing assembly, so there is no lateral force.
  6. Mar 30, 2023 at 9:55 PM
    #66
    Jeff Lange
    Calgary, Canada
    Yes, I know all that, and I wasn’t disregarding any of it.
    A wheel with an offset of, for instance, +25 mm like the Tacoma has, will always have the centre of the wheel in the same spot regardless of width or backspacing.
    It’s literally the definition of offset.
    Jeff
  7. Mar 30, 2023 at 10:19 PM
    #67
    Stocklocker
    17TRDORDCSBAT
  8. Jul 22, 2023 at 3:21 PM
    #68
    Morpheus
    Morpheus Member
    Blue
    2020 Tacoma TRD OR
    It will add negligible stress. It will have no impact that you will be able to quantify at that small of a difference. Your drive style, acceleration, braking and what you tow would have more impact than the 8mm offset.
    Nearly all the suspension component from the SR5 to the PRO are identical other than shocks and struts and the pro has a different upper control arm. The pro does have a slightly different lift but you’re not asking about that. (Someone correct me if I am wrong here).
    They are all designed to hand the same wheel and tire package as the PRO. The PRO has a different upper control arm but it supports minimal load for the suspension and will have no difference on wear and tear by simply changing from one stock wheel offset to another stock wheel offset.
    Changing the lift and tire size (weight per tire) will have significantly more impact on the needle bearing and wheel bearing which will be the first to failure points on the front suspension. (example going from a 38lb x 30.5” diameter 4 ply tire to a 52lb x 32” diameter 10 ply tire).
    For what you are asking. If you are just changing the OR wheel to a TRD pro wheel then don’t worry about premature failure. The truck is designed for either offset without issue.
    If you are under warranty and you are worried about it ask your Toyota dealer for a quote for new PRO wheels and ask them if it will void warranty. They will tell you no it won’t. That should be good enough for you. If it did void warranty then they wouldn’t do it because they aren’t covered.
  9. Jul 22, 2023 at 3:47 PM
    #69
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Not that I feel like adding to the conversation. I'm just trolling.
    Force on the lower ball joint and possible wheel bearing, I could see.
    What does the correlation between heavier aftermarket springs pushing down on the lca have with lower ball joint/wheel bearing stress? Extra weight in general with bumpers and skid plates. All play a part.
    Never have I ever seen such an in depth analysis over some lights in a grill.
    I have them because I like them. lol
  10. Jul 22, 2023 at 6:02 PM
    #70
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    All lies. Nobody gets drunk on American Bud Lite....:rofl:
  11. Jul 29, 2023 at 10:16 PM
    #71
    Iceman43
    Iceman43 New Member
    2006 Black TRD Off Road Access Cab
    Thinking of going from stock 30mm offset rim to a TRD Pro rim with a 13mm offset on a 2006 TRDOR. Will the new rims still be tucked in the fender wells and do I need to worry about tires being gouged by fender edge during any increased suspension travel? I think it will be fine but any thoughts/advice would be greatly appreciated.
  12. Aug 6, 2023 at 3:59 AM
    #72
    fjrmurph
    fjrmurph Well-Known Member
    i have a 2023 PRO all stock , i have winter rims and tires off the 2018 TRD SPORT . Can i put those rime on the new truck this winter ? THKS
  13. Oct 9, 2023 at 7:08 AM
    #73
    Jenkem
    Jenkem New Member
    Cape Cod
    23' Off-road
    Stock for now
    I have 2023 off-road and am looking to put 17x8.5 with 0 offset and 265/75/R17. I believe the stock offset is 25mm, so going to 0 offset will push the tire out 25mm right ? Also anyone know if they will rub? I know the stock wheel is 16. Bigger rim bigger tire seems like it will rub but I don't know.
  14. Feb 20, 2024 at 7:28 AM
    #74
    EdisonCavani
    EdisonCavani New Member
    What's the offset on pro wheels?
  15. Feb 20, 2024 at 9:37 AM
    #75
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Depends on which pro wheel.
    Most 3rd gen Tacoma Pro wheels are 16x7.5, +13mm. There might be a few versions that are +10mm.
    The 4Runner Pro wheel (which is popular amongst Tacomas) is 17x7, +4mm
    https://www.tacomaworld.com/threads/wheel-specs.30754/
    EdisonCavani[QUOTED] likes this.
  16. May 11, 2025 at 6:43 PM
    #76
    TacOCD
    TacOCD Active Member
    CP
    Pennsyltuckey
    2022 BlueCrush Tacoma 4x4 TRD OFF Road DCSB Auto
    Black TRD Pro Wheels 21’ 6 Spoke; GY Duratrac 265/75/16; Head Rail; Rocky Mounts; Useless Interior Red Trim; TRD Shift Knob; Red Meso Start Button and Trims; Tint
    I have this exact set up (same TRD Pro 2021 with offset +13 wheels in link) and it is fine on my 2022 Gen 3 TRD OR... No issues - Cheers!
