TRD OR --- No LSD? Is this correct?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cluck024, Dec 8, 2010.
  1. Dec 8, 2010 at 2:36 PM
    cluck024
    cluck024 [OP] -cluck
    Robert
    Greenwood, Arkansas
    09 Prerunner TRD-OR DC Barcelona Red
    Blacked out badges, Anytime Fog Light Mod, Sockmonkey Decals and Third Brake Light Cover, Yellow fog lights, custom homelink install, Radflo 2.0 coilovers, LR UCA's, AAL, Moto Metal 957 matte black with Nitto Terra Grappler 285/70/17 shoes, more to come...
    Title says it. Fixing to do 30K tune-up. Just to be completely sure, I dont need to add LSD fluid?
  2. Dec 8, 2010 at 2:38 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    TRDs do have limited slip, so yes, you will need LSD additive (not lysergic acid diethylamide, the original LSD).
  3. Dec 8, 2010 at 2:45 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Thats what I thought. For the longest time I believed it had LSD, but what I thought was the LSD was actually being accomplished by the VSC using braking correct?
  4. Dec 8, 2010 at 2:52 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Right!! But since its the brakes I dont need LSD additive correct? There is A LOT of conflicting info on this because of the change in the 09+ models. Thanks for the help!
  5. Dec 8, 2010 at 2:56 PM
    toddt
    toddt Well-Known Member
    todd
    Houston, TX
    2011 D-cab 4x4 TRD OffRoad
    TRD Supercharger, TRD cold air intake, TRD Sport Hood, TRD Exhaust, Pro Comp 6" lift
    Toyota dealer still use the additive in ALSD vehicles.
  6. Dec 8, 2010 at 2:56 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Thanks whipper snapper + rep
  7. Dec 8, 2010 at 2:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Why would they do that? Its an open diff, and uses the brakes to modulate power to the wheels that slip...
  8. Dec 8, 2010 at 3:00 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Thanks for chiming in, LOL!! Dont need the confusion.:D
  9. Dec 8, 2010 at 3:02 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    x2.
    I bet they meant to say they're using fluid with an additive in it. I've heard that all the gear oils have the additive in them, but it's just not enough for our mechanical LSDs...thus the need for an additional tube of additive. So it was probably a misstatement/misunderstanding where ever that info came from.
    Either way, TRD OR has never (at least for a Gen 2) had a mechanical LSD!
  10. Dec 8, 2010 at 3:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the ones I have contacted said they DONT have the addative in them, but the "LS" on the bottle means "Safe for use in limited slip differentials".
  11. Dec 8, 2010 at 3:08 PM
    toddt
    todd
    Houston, TX
    I work at a toyota dealer. As I read this 3 of the technicians were walking by my desk so I asked them.
    We use valvoline, which "includes" the additive, but they still put it in just to be safe. All LSD, mechanical and auto.
  12. Dec 8, 2010 at 3:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are misinformed. The Valvoline doesnt have it in the oil. It IS Safe for use in LS diffs.
  13. Dec 8, 2010 at 7:32 PM
    05Moose
    Jim
    Ah, that explains it then. There are a lot of people that don't use the additive because the bottles state just what you said and then they have problems. Now I too know why. Thanks.
