trd OR with hood scoop?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thecelt, Sep 1, 2015.
  1. Sep 1, 2015 at 6:20 AM
    thecelt
    thecelt [OP] Well-Known Member
    16' TRD OR MGM
    I thought only the sport had the hood scoop...
  2. Sep 1, 2015 at 6:29 AM
    redacted
    redacted Member
    Don
    Longmont, CO
    2016 DCSB Barcelona Red TRD OR Tech JBL
    I think that's likely a typo. Someone must have done a copy'n'paste and didn't remove "hood scoop" from the list for OR.
    Where is this from?
  3. Sep 1, 2015 at 6:29 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Must be typo.
  4. Sep 1, 2015 at 6:32 AM
    thecelt
    16' TRD OR MGM
    I agree its probably a typo. Thats right from the product info. There was a thread on here where i downloaded the tech specs and product info.
  5. Sep 1, 2015 at 6:32 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    That says it's not available on the or and it's standard on the sport.
    The more you know :)
  6. Sep 1, 2015 at 6:35 AM
    redacted
    redacted Member
    Don
    Longmont, CO
    Read it a little closer. "Hood scoop" is in the standard list for the OR.
  7. Sep 1, 2015 at 6:42 AM
    TeamSarcasm
    The better coast
    The scope is popular. Maybe it isn't a typo.
  8. Sep 1, 2015 at 6:45 AM
    redacted
    redacted Member
    Don
    Longmont, CO
    Non functional hood scoop? No thanks. If it does come on the OR I'll be cancelling my order pronto. But I doubt it since all the publicity shots of the OR didn't have one.
  9. Sep 1, 2015 at 6:56 AM
    thecelt
    16' TRD OR MGM
    I dont think it will be on the OR, it lists it as standard on the product info, but not the technical specs... and everything else points to the hs on the sport only.. i just thought that was odd when i saw it.
  10. Sep 1, 2015 at 7:19 AM
    redacted
    redacted Member
    Don
    Longmont, CO
    I agree. That was a good catch.
    I went back and looked at the docs TFL posted which I assume Toyota gave them.
    This one shows exactly what you posted above http://www.tfltruck.com/wp-content/uploads/2015/08/2016-toyota-Tacoma-Product-Info.pdf
    This one khas the same sheet but looks more official and shows what I would expect, plus elsewhere in the doc has the verbiage of "Trademark TRD Sport hood scoop" http://www.tfltruck.com/wp-content/uploads/2015/08/2016-toyota-Tacoma-Technical-specs.pdf
    So I'm confident the Sport will be the only one with the scoop treatment.
  11. Sep 1, 2015 at 7:43 AM
    thecelt
    16' TRD OR MGM
    Those are the links indeed. Im just really darn impatient, and my build date is 9/18 so i need something to talk about t
    aco related. :)
  12. Sep 1, 2015 at 9:18 AM
    yoTaco98
    yoTaco98 Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    Wouldn't mind having a hood scoop on the OR. My personal perference would be a OR with color keyed fender flares, bumper, mirrors, and a hood scoop. Or the locking diff on a sport. Maybe I buy a OR and someone with a MGM sport will be willing to trade.
    Hasn't anyone in TW made the hood functional. Maybe ran some vent tube to the airbox?
  13. Sep 1, 2015 at 9:23 AM
    TeamSarcasm
    The better coast
    When you open it up hot air is able to escape the engine bay. And there is a Cai for 2nd Gen pre facelift that makes it kinda functional.....not really...
    The way air moves over the hood places the scoop in a low airflow zone, iirc so not like a subaru scoop functional.
    yoTaco98[QUOTED] likes this.
  14. Sep 1, 2015 at 9:24 AM
    TeamSarcasm
    The better coast
    Lol....well the good news is no one is forcing you to buy anything :)
  15. Sep 1, 2015 at 11:17 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Parts catalog only lists hood scoop for TRD Sport, as suspected and just like it was on the 2015.
    Jeff
  16. Sep 1, 2015 at 1:22 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    The scoop can let hot air out while at speed? I think it would need to be pointing backwards for that to happen. And then the windscreen will make a positive pressure and not let anything out. I can see that it would let hot air out when stopped.
  17. Sep 1, 2015 at 3:10 PM
    TeamSarcasm
    The better coast
    When you're stopped or at low speed.
    If it's a low enough pressure zone at the scoop hot air will rise out until it catches the wind off your hood/grill. Then the hot air will be blown away.
    That's my take on it. Just depends on how much pressure actually makes it into the scoop when moving :notsure:
  18. Sep 1, 2015 at 3:13 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Hopefully the new models aren't using the stick-on hood scoops from the XSP-X models. :der:
  19. Sep 1, 2015 at 3:18 PM
    tubesock
    tubesock Well-Known Member
  20. Sep 1, 2015 at 5:37 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    That's not what a scoop is for
