TRD Pro, 37 miles, suspension or front end popping/clunk
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Putt4Doe, Aug 11, 2020.
  1. Aug 11, 2020 at 8:39 PM
    Putt4Doe
    Putt4Doe [OP] Member
    TRD Pro Taco
    Hi all - longtime lurker on the forums, and just recently joined the Taco family, with the purchase of a 2020 TRD Pro.
    Immediately upon driving my vehicle home, I noticed when entering my driveway a faint/muffled popping noise when my front passenger wheel was entering my driveway apron and my drivers side wheel was still on the pavement. It seems like any time there is body roll or an uneven suspension load (driveway apron, speed bump that I take at an angle, etc) there’s a creaking/popping noise from the front. At first it sounded like it was on the passenger side, but after rolling my windows down it’s coming from both sides.
    I’ve seen several threads talking about noises from the front, but it seems like those noises were more clunks/metal on metal sounds, not a creaking sound. Also, it seems like none of these were on a new truck.
    Couple of questions: is this normal? Am I hearing the shock/bypass and thinking it’s something else? I can’t imagine the creaking sound to be normal. Maybe the sway bar bushings are tight or getting worn in? I now have over 400 miles and it’s pretty noticeable. I’ve seen other threads talking about the body mount bushings being bad, but is it possible to come from the factory like that?
    appreciate the help. I plan to ask the dealer to look at it when I’m getting the first oil change, but I’m sure I’ll just get the standard “we couldn’t replicate it” or “everything looks fine” routine. I’ll also try to get a video of it to post on here as I know trying to diagnose something without seeing/hearing it is tough!!
  2. Aug 11, 2020 at 8:42 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. For piece of mind I’d take it in.
  3. Aug 11, 2020 at 8:51 PM
    pbandnv
    pbandnv Active Member
    2020 Tacoma SR5 Access Cab
    Not sure if this is helpful, but I had a similar problem when I bought my Highlander brand new. Took it in over and over, was told it was a “tolerable” noise in the bushing and nothing was wrong. They did nothing! After 6 months ran across a forum with similar stories. Long story short, a guy in the forum figured out the the area of the noise and just doused it with some silicone spray. He uploaded a picture of where it was. Everyone on the forum did the same thing and it fixed the problems. That was 4 years ago and I’ve never had the issue again. Just wanted to pass this along in case they give you the same “tolerable” noise BS.
    Junkhead, AKGSD and Shellshock like this.
  4. Aug 11, 2020 at 9:00 PM
    Toy1985gc
    Toy1985gc Well-Known Member
    G
    2020 TRD Sport 4WD DCLB Tech Pckg Cement
    3 & 1 leveling kit 32 BFG KO's x17 Method Roost wheels/ TRD Skid
    See below- maybe this helps. I have a 20 Sport 4WD DCLB. I installed the TRD skid plate (which you have) and since than noticed a creep noise when front suspension was compressed ( pulling in/ out driveway). Turns out was a result of skid plate- added spacers and noise gone. However, someone else with a TRD pro also had similar noise and determined was body mounts I believe .
    https://www.tacomaworld.com/threads...y-2020-sport-fixed-was-trd-skid-plate.675562/
    BillsSR5 likes this.
  5. Aug 11, 2020 at 9:30 PM
    Putt4Doe
    TRD Pro Taco
    super interesting - I’ll check the skid plate tomorrow!! Thanks!
    Junkhead likes this.
  6. Aug 13, 2020 at 6:31 AM
    Putt4Doe
    TRD Pro Taco
    Out of curiosity, what size spacers did you add?
  7. Aug 13, 2020 at 6:33 AM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Chasing clunks, pops, and squeaks is the story of my life
    Rockefelluh, b3itz, Junkhead and 3 others like this.
  8. Aug 13, 2020 at 2:31 PM
    Toy1985gc
    G
    Want to say 1/2 inch
  9. Aug 13, 2020 at 2:34 PM
    Deo taco
    Deo taco Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    it can be the bypass shocks opening its valves to allow fluid flow. if your driveway entrance would be a quick instant input to the shocks. also sounds like its long travel time. that totally fixes the issue some how. i think of that later
    Rockefelluh and Natetroknot like this.
  10. Aug 13, 2020 at 2:47 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Grab a torque wrench and some sockets and make sure everything thing is torqued to spec. Make sure you are on level surface, not and incline driveway.
  11. Aug 13, 2020 at 2:52 PM
    VooDoo808
    VooDoo808 Well-Known Member
    Marc
    Hawaii
    2019 Voodoo Blue Tacoma TRD Pro
    My pro had a similar issue brand new off the lot, chased it for a little bit. Ended up being the sway bar endlink nut being loose at the sway bar mounting point.
  12. Aug 13, 2020 at 2:56 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Front radiator support bushings
    danielgonzzz and Junkhead like this.
  13. Aug 13, 2020 at 3:02 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    More than likely you have a dip in your drive and a sharp turn it probably is the steering stop against the lower control arm totally normal.
  14. Aug 13, 2020 at 3:14 PM
    eurowner
    eurowner Duke Sky
    Scoty
    First oil change is at 10,000.
    Take the truck off road and cycle the suspension.
  15. Aug 13, 2020 at 3:53 PM
    windyhill
    windyhill Active Member
    2019 Tacoma TRD
    None.
    If you don’t like clunks, pops and squeaks, whatever you do don’t engage crawl control.
    That is disturbing to say the least!
    DRob and photogr4x4 like this.
  16. Aug 13, 2020 at 4:09 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Congrats on the Pro and welcome aboard:wave:
    In yer shoes I'd roll under it on the creeper and make sure nothing is obvious.....if nothing jumps out I'd drive her hard (as safely as poss) for a few hundred more and see what becomes of it. Worse, or same, take it in and let Toyota have a look see. If they give you the 'ol run around like you suspect, report back here with a vid and you'll have the best Taco minds around going to bat for ya.
    Good luck
  17. Aug 13, 2020 at 4:21 PM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    2020 sport here. I had a very similar issue that started before 100 miles, it seemed to get worse up to maybe 2000-3000 miles and then almost instantly went away. It was driving me crazy and i could never exactly pinpoint it. I’m at 6000 now and it’s completely gone. I realize you have the pro suspension but figured I’d throw in my 2 cents. Almost seemed like it was the suspension working in and getting locked in after a little time. Good luck
  18. Aug 16, 2020 at 12:13 PM
    Putt4Doe
    TRD Pro Taco
    Well, found where it’s coming from! I had checked the passenger side suspension but couldn’t replicate it.... however on the driver side, it was easy as could be to replicate. Sounds like it’s the spring on the shock, or maybe a rubber bushing on the control arm. Here’s a video:
  19. Aug 16, 2020 at 2:08 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Torque that bolt down, UCA 85 ft lbs, see if that works, if not probably bad bushing.
    UCA will make a clunk.. did it to me..Hit the 3 bolts on the top of the strut/coilover while you are there.. 2020 Year model Can see the bushing being bad.. is probably not torque down.
    Added the torque specs here for you
  20. Aug 16, 2020 at 2:41 PM
    MedTechBrew
    MedTechBrew Well-Known Member
    NC
    2017 Quicksand TRD Sport DCSB 4x4
    Looks like I’ll be under my truck tomorrow. Still searching for the culprit.
