TRD Pro 4High crawl Issue...gears?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jwrover, Jul 6, 2020.
  1. Jul 6, 2020 at 1:46 PM
    jwrover
    jwrover [OP] Member
    2019 TRD Pro
    Hey gang,
    New to forum. But not new to 4wheeling and Tacomas.
    Been around the block a couple of times with Jeep, Land Rover, and Toyota. On my second Tacoma. Took my 2019 TRD Pro out for a trail ride this weekend and was very discouraged by the 4 High- 1st gear ratio. A trail here in the San Juan's that I've done 100's of times in all the vehicles above...And I got stalled out on a 30 foot hill section!!
    I've read a little about nitro and revolution gear upgrade to 5.29 or 4.88 gears...Is this going help my issue? O, my Tacoma is a Manual.
    Thanks in advance!
    Junkhead likes this.
  2. Jul 6, 2020 at 1:48 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    If 4HI isn't low enough use 4LO. That's why it's there, it's not something you "save". Use it.
  3. Jul 6, 2020 at 1:49 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    The 4hi gear ratios are the same as the 2hi ratios because you haven’t put the transfer case in low gear. So you could try 4Lo?
  4. Jul 6, 2020 at 1:52 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Stock height and tires or lifted?
    If you are going for slow and finesse, use low range.
    Junkhead and doublethebass like this.
  5. Jul 6, 2020 at 1:56 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Night and day difference in hi range and low range. We have sand, deep sand here in Florida, even a slight hill will tax traction and power. Low range danced right up and out of all kinds of stuff, torque multiplication baby.
    Myles G and Junkhead like this.
  6. Jul 6, 2020 at 2:00 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    A lot of the time I wish I had 2 low with a locker.
  7. Jul 6, 2020 at 2:00 PM
    su.b.rat
    su.b.rat broken truck
    a little hard to know what's up from the wording about 4hi & crawling. o_O maybe a typo?
    the MT crowd here can help if you're having performance issues. i think most of us have at some point and there are many solutions. but what's the problem specifically?
  8. Jul 6, 2020 at 2:01 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Lower gears in the axles is what you need , use low range only for the rock gardens /boulders
  9. Jul 6, 2020 at 2:04 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    4LO is your best friend with a MT. I throw it in 4Lo as soon as it starts to get hilly, saves your clutch and multiplies your torque.
    Im in 4hi only when driving on FSRs or on snow in the city.
    02Duck likes this.
  10. Jul 6, 2020 at 2:04 PM
    jwrover
    jwrover [OP] Member
    2019 TRD Pro
    SO I get all the suggestions about " Well, Just use 4 Lo..."
    But here in the San Juan's the trails are varied and climb, then level, then climb steeper, then descending...blah blah..
    So historically in all my previous vehicles, (including an 08 Tacoma SR6) I was able to rely on 4-hi until it got quite technical or I was descending. This allowed more freedom to modulate progress with the throttle rather than the clutch. ( Again this is a Manual Transmission).
    The hill in question would never have been an issue in 4Hi 1st gear in any other vehicle. But the TRD Pro literally stalled out half way up...and it's only a 20-30 foot semi-steep climb on stable dirt.
    It really shocked me!
  11. Jul 6, 2020 at 2:06 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I disagree sir. I would use 4lo on reg trails. Your clutch will thank you. Thats what 4lo is there for. In AT you have torque converter, in MT you got the transfer case.
    02Duck likes this.
  12. Jul 6, 2020 at 2:07 PM
    jwrover
    jwrover [OP] Member
    2019 TRD Pro
    I'm really impressed with the quick feedback! This is my first post in TacomaWorld!
    Thanks!
    Thunder Fist and Junkhead like this.
  13. Jul 6, 2020 at 2:13 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Welcome to TW man!
  14. Jul 6, 2020 at 2:14 PM
    su.b.rat
    I'll throw a few things at you.
    1) these trucks have factory tuning that significantly mutes the power available from your hardware. OVTune threads around here can get you more info.
    2) beyond this, and don't take it personally, most experienced truck drivers who complain around here are having issues because they are not adapting their experienced drive style and refuse to rev up this 3.5 motor. if you are stalling it, that is on you. the motor even with the factory tune is strong enough to stay running if the driver keeps it in the powerband.
    3) you need this if you have a MT and appreciate a clear clutch feel: https://www.tacomaworld.com/threads/mt-accumulator-delete-mod-adm-and-bs-thread.568303/
    4) yes, lots of AT and MT trucks have gears, typically 4.88 or 5.29.
    more infos available.
    soggyBottom, Freegolf, AKGSD and 2 others like this.
  15. Jul 6, 2020 at 2:24 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Agree with you on all points. But, i just dont see the need for lower geared diff on an MT. The gears are already pretty low imo.
  16. Jul 6, 2020 at 2:28 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Have you used reverse?
  17. Jul 6, 2020 at 2:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Reverse sucks big time i agree. Thats why i have 2Lo mod, just waiting for the switch. But other gears work great imo. When going 90km an hour im already at 2k rpm, so going lower would be horrible for hwy driving.
    I dont think going 4.88 or 5.29 is really gonna fix the reverse issue. Reverse should be how it is when its in 4lo, stock.
    Edit: reverse in my previos MT trucks was stupid high as well. Must be a gear storage issue.
  18. Jul 6, 2020 at 2:39 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    X2 on low range. Reverse has nothing to do with when to use low range.
    If anything low range is easier on the truck because the ratio is in the trucks mechanical favor and easier on it.
  19. Jul 6, 2020 at 2:41 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    If you lower the ratio in the axles to 5.29 , it takes the strain off the clutch
    Never needed low range in my old 68 M38A1 jeep unless I was in a technical section were I needed to crawl and never had an issue with the clutch
    It had a GM SM465 4spd 6.54 1rst gear / 6.09 reverse
    Atlas / Dana 18 t/case 3.50 low range
    Saturn overdrive 15% reduction
    Dana 44's with 5.38 gears and Detroit lockers
    Worked out to 124:1 low range / in High range 35:1 gearing with it in overdrive , 29:1 straight thru gearing
    Junkhead[QUOTED] likes this.
  20. Jul 6, 2020 at 2:50 PM
    m603holden
    Marteeen
    New England
    If you put it in low range you take the strain off the clutch. The clutch is ahead of the axle in the ratio chain. The transfer case is in between them.
    Let's be honest. All opinions aside, the Australian guys run 4lo all the time up to 40mph. There's not a massive report of premature wearing parts or failures. The failures come from people hitting obstacles like bulls.
    Junkhead and US Marine[QUOTED] like this.
