TRD Pro 4High crawl Issue...gears?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jwrover, Jul 6, 2020.
  1. Jul 6, 2020 at 3:00 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    And that wasn't disagreeing with what @US Marine said. He's right. But you can also achieve that by going to low range.
    US Marine likes this.
  2. Jul 6, 2020 at 3:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Your 2019 needs 4600 rpm to give you max torque. That is not a good place to be with a manual transmission. Older vehicles got that torque at 1500-3500 rpm. With this truck you're going to need low range a lot more, especially with the manual. Newer engines were designed around automatic transmissions with torque converters.
    AKGSD likes this.
  3. Jul 6, 2020 at 3:08 PM
    m603holden
    Marteeen
    New England
    Yes and no.
    1st gear hi range can handle most things just fine.
    Most of the time just tossing it in low range is a good idea though.
    Dirk Diggler likes this.
  4. Jul 6, 2020 at 3:11 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    This what low gearing can and will do , this is Corral Canyon OHV park near Campo Calif in the East County of San Diego
    In low range at 124:1 gearing literally idling up this hill in 1rst gear scaring all of my Jeep club members . Just moments after this pic was taken the right front tire was 4' off the ground
  5. Jul 6, 2020 at 3:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This right here.
    saw a MT FJ out in the dunes of pismo stuck having all sorts of issues, rode over to him and went are you in 4lo? no? do yourself and your clutch a favor, 4lo. Got him right out.
    Seriously if you are MT and are not using 4Low when off road you are dumb. Hell im an auto and if im off road going less than 30mph in varying terrain im exclusively in 4low. Hell im in 4low ANYTIME im in the bigger dunes of pismo, keeps trans temps down, available power at the speeds im going is way better etc etc. 4hi only gets used in the snow/icy roads, higher speeds in the desert (to keep the front and rear axle mechanically mated together so that the rears dont lock under braking) or when i just need a lil bump over an obstacle that 2wd wont be doing nicely.
  6. Jul 6, 2020 at 5:21 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Or steep climbs. 4Hi might not cut it depending on angle.
    US Marine[QUOTED] and Junkhead like this.
  7. Jul 6, 2020 at 5:32 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    There’s a 2Lo mod that’s plug and play.... I’m not certain if you can lock the rear though. I need to go check because I have the mod. Now that I think about it, pretty sure you can. The truck thinks it’s in 4 Lo. But the front diff isn’t engaged.
    Junkhead likes this.
  8. Jul 6, 2020 at 5:57 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have the manual transmission and I’m always in 4lo when in any sort of technical terrain where I never need to exceed 30 mph or there abouts. It makes everything easier and is also the only mode that ATRAC is enabled, the rear locker can be engaged, and all the fun police options are disabled by default. 4hi is for only used for snow covered roads. YMMV
    That reverse gear is way to high though, but it has been in all my automobiles. Not clear why. Who wants to be barreling along at 10 mph reversing in a parking lot let alone a technical trail or backing up a trailer?
    02Duck, doublethebass and Junkhead like this.
  9. Jul 6, 2020 at 5:57 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I agree that the lower the gears in the rear diff, the better for off roading. 5.29 gears would make 3rd gen taco with MT, not a very good daily driver. I could see it being good in the city maybe, but on the highway the 4.30 stock gears are already not very fuel efficient. Well they are, if you are going no faster than 65:)
    Awesome photo by the way!
    MOC221_, AKGSD and doublethebass like this.
  10. Jul 6, 2020 at 5:58 PM
    OdiN1701
    Colorado
    I use 4Hi on lots of just service roads and such where it's mostly graded, washboard, a few rocks, etc.
    Especially washboard, 4x4 will really help your rear end from drifting.
  11. Jul 6, 2020 at 5:59 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Couldnt have said it better.
    I think the high reverse is due to storage of the gears.
    4x4spiegel likes this.
  12. Jul 6, 2020 at 6:07 PM
    gudujarlson
    Minnesota
    But drifting is fun. How else does one have fun on forest roads?
  13. Jul 6, 2020 at 6:40 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Thanks !!! :thumbsup:
    That pic is 25 yrs old
    Basically when figuring out axle ratios you have (3) ways to regear ....
    Economy gearing ... a slightly taller gear ( bring cruise rpm down by 200rpm ) it's like going up in tire size but your fuel economy increases
    Return to stock gearing ..... selecting a gear ratio that with your new larger tires , brings back the stock power level you had with the OEM wheels and tires
    Performance gearing ...... selecting a gear ratio (lower gear / high numerically ) that increases cruise rpm by 200 -300rpm . This helps by getting the motor in its powerband faster
    All my vehicles I've regeared I've always gone with a performance regear . Yes I'm spinning the motor 200-300rpm at cruise and fuel economy is down slightly but the motor is more responsive
  14. Jul 6, 2020 at 6:43 PM
    OdiN1701
    Colorado
    The ones I drive that have thousand foot drop offs... no I'll not drift.
  15. Jul 6, 2020 at 6:44 PM
    #35
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I just recently found out about the long press of the trac button
    :anonymous:
    I like my truck much, much more than i used to.:)
  16. Jul 6, 2020 at 6:45 PM
    #36
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    when you go out on trails put it in 4lo, especially on a manual. You can use gears 1-4 for varying levels of reduction. Just stay out of 5th.
  17. Jul 6, 2020 at 6:46 PM
    #37
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting, thank you for the input. You seem to know much more about gearing than i do :)
    US Marine[QUOTED] likes this.
  18. Jul 6, 2020 at 6:47 PM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Honest question, why stay out of 5th? Because its overdrive?
  19. Jul 6, 2020 at 6:49 PM
    #39
    gudujarlson
    Minnesota
    Haha. We have none of that where I live. I would probably have it in 4lo going 5mph on roads like that. :)
  20. Jul 6, 2020 at 6:49 PM
    #40
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Something like this? Haha
    Well, you cant really tell but it was very high.
