TRD Pro Skid Plate Install Directions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by strotman, Oct 13, 2017.
  1. Oct 29, 2017 at 6:27 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    The skid plate looks pretty bad ass I have to admit
    shakerhood likes this.
  2. Oct 29, 2017 at 9:52 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Does the Skid plate on the Off Road also act as a sort of a Air dam? I know that question is dumb, but I was just wondering as I thought the trucks with the automatic sixes all had the same EPA mileage ratings? Taking the dam off would seem to give the EPA a excuse to drop the mileage estimates for the off road. Enlighten this dummy as I have been thinking of adding a Skid plate to my SR5 for my rare off road ventures
    Thanks
  3. Oct 30, 2017 at 12:30 AM
    duckytw
    duckytw Well-Known Member
    Pretty sure the factory broke the weld nuts on my skidplate. Tried taking it off the other day to clean up some oil and the bolts spin but never come off :/
  4. Apr 17, 2018 at 3:24 PM
    lordcon
    lordcon Active Member
    Maryland
    2017 Black DCSB TRD OR
    Toytec 2.0 Boss kit, SPC UCA's, 285/70/17 BFG KO2, 17x8.5 SCS Ray 10
    I know I'm bringing this thread back from the dead sorta but does anybody know if you need to cut the TRD skid plate to accommodate a lift kit diff drop like you do for the factory skid?
  5. Apr 17, 2018 at 3:42 PM
    Yoshi_TRDpro
    Yoshi_TRDpro Member
    Derek
    Sacramento cali
    2018 Metalic grey trd off-road 4x4
    Fox 2.5 coilovers Total chaos UCA's Cali raised fog lights Cali raised 32" front bumper led bar 16x8 -20 volk te37's mag blue Goodyear wrangler duratracs 265/75/16 spidertrax 1 1/4 spacers front and back
    I never had to cut my stock OR skidplate the diff drop came with spacers for the skid plate
  6. Apr 23, 2018 at 7:38 AM
    18CementTaco
    18CementTaco Well-Known Member
    2018 Tacoma TRD Off-Road double cab short bed
    This thing is legit. It makes the OR stock skids look disgraceful in comparison. Highly recommended.
  7. Apr 23, 2018 at 7:43 AM
    Taco_Time
    Taco_Time Well-Known Member
    Seattle to LA
    '17 QuickSand TRD Off Road
    Definitely one of my next upgrades.
  8. Apr 23, 2018 at 8:01 AM
    brydav
    brydav Well-Known Member
    Bryan
    Austin, TX
    2015 Access Cab TRD SPORT 4x4
    Just got this one - it's a work in progress.....
    Thanks for posting this. It was helpful not to have to try to "trial and error" which bolts to remove while holding a heavy part. Made my life a lot easier. I think this is what the original poster was asking. Oh......and it fit perfectly on my SR5, for those wondering.
    Jaggerbub[QUOTED] likes this.
  9. Apr 23, 2018 at 9:01 AM
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    Anybody know the difference in weight from stock OR skids to these?
  10. Apr 23, 2018 at 9:09 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    there is a bolted on transport hook on the radiator support / frame cross member that you may have to unbolt to get it to fit.
  11. Apr 23, 2018 at 9:19 AM
    brydav
    Bryan
    Austin, TX
    I put one on my SR5 last week and just had to remove the air dam (and old skid plate, of course). Nothing else (hooks, etc) had to be removed.
    Sin City Taco likes this.
  12. Jul 20, 2018 at 8:04 PM
    daberg
    daberg Member
    I have a 2018 OR. I ordered a TRD skidplate and received mine with bolts for the front and middle attachments preloaded on the skidplate, but there were no bolts for the rear attachments. Does anyone know if I can use the stock bolts that came with the original plate?
  13. Jul 20, 2018 at 8:20 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    I'm not sure if they are the same length. Didn't bother to compare when I installed mine. Give it a go and try. If it helps, I might have an extra in the garage. I was missing one bolt and the seller sent me another two to replace them. So I have an extra. I'm sure you can find one to match at your local hardware shop. If you are local and want it, let me know.
  14. Jul 20, 2018 at 8:30 PM
    Jaggerbub
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    The instructions say that the stock bolt is (M8 x 1.25 x 20 mm) and the trd bolts are (M8 x 1.25 x 35 mm) .... so the new bolts are longer. You can probably take the stock bolt to the hardware shop and have them find u one thats 35mm if the shorter one isn't long enough to tighten down.
  15. Jul 20, 2018 at 8:43 PM
    #35
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    You can find these exact bolts for a buck or 2 each at Lowe’s in the bolt aisle.
  16. Jul 20, 2018 at 10:30 PM
    #36
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Has anyone installed the TRD Skid plate on a Sport and KEPT the air dam?? I'd like to change my stock skid to one of these but also would like to keep my air dam - I like ito_O
  17. Jul 20, 2018 at 10:57 PM
    #37
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Hmm seems like you wouldn't want both? If the skid is doing its job and protecting your underbody, the dam would surely rip off if the skid took a hit. I don't think I've seen anyone run both. Not sure if it's possible.
    payrow[QUOTED] likes this.
  18. Jul 20, 2018 at 11:03 PM
    #38
    jmauvais
    NorCal
    ...stuff
    One guy did. Can’t find the pic but he cut the middle of the air dam out to make room for the skid plate, and left the edges in front of the wheels to deflect the air down around the wheels. Basically the pro skid sticks forward too far for the air dam to sit there.
  19. Jul 20, 2018 at 11:19 PM
    #39
    payrow
    Los Santos
    '18 DCSB Sport
    Thanks for the replies! I think I do remember seeing what that guy did. Don't really need it for the skid function, I just think it looks way nicer and more functional (filter access) than the stock skid :spending:
    Swilly9 likes this.
  20. Jul 20, 2018 at 11:23 PM
    #40
    jmauvais
    NorCal
    ...stuff
    Some say the air dam adds 1 mpg or so. I removed mine and I didn’t lose anything, and I think the truck looks better without it. Rip it off, and throw on the pro skid. Looks better. Functions better.
