TRD S/C Came in Today! Question...
Discussion in 'Performance and Tuning' started by 2wheelnut, Mar 7, 2014.
  1. Mar 7, 2014 at 5:02 AM
    2wheelnut
    2wheelnut [OP] Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Now I'm debating weather or not to do the dealer install. Dealer is asking $980 plus coolant.
    If I do it myself then I won't have the remainder of my factory warranty if I understand correctly and how do I get it to the dealer for a reflash?
    I've seen people say keep it off boost, but there's a freeway on the way to the dealer. I played around last week and can keep it under 2k rpm on the on ramp.
    I just don't want to blow the motor or get any lights to come on. $980 is doable but $149 for the reflash and a few hours of my time sounds a hell of a lot better.
  2. Mar 7, 2014 at 5:05 AM
    mbray
    mbray Well-Known Member
    Regina, Canada
    '14 4x4 TRD Sport
    JBL Entune Conversion, BHLM, Heated & Auto-dimming mirrors
    From what I understand, is if you do it yourself you won't void the trucks warranty. But if something were to break or happen that is caused by you installing it, then you'll be up shit creek
  3. Mar 7, 2014 at 8:10 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    $980 is not a bad price to have that done. You'll pay about $150 to have the dealer re-flash the ECU and you still have to buy coolant either way.
    The advantage to the dealer install is that the S/C will be covered by your powertrain warranty. If you install it yourself you DO NOT VOID your warranty, you just don't get coverage on the S/C after one year of the reflash.
    Driving to the dealer is not fun, the truck runs rough and you're always worried about it running into boost. I had mine towed to the dealer by my insurance company so I wouldn't have to worry about it.
    PM if you have any more questions, I went through the same thoughts myself when I installed mine.
  4. Mar 9, 2014 at 9:16 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    980.00 plus coolant is high in my opinion. I got mine done for 690 including everything. I let the dealer do this only for the warranty aspect. However, with what I know now, I would install the blower myself. If you do decide to install yourself; I recommend using aftermarket green coolant. That way if the pink coolant is leaking you know its the engine; if the supercharger is leaking its green. Another member Coupe came up with this idea; very clever.
  5. Mar 9, 2014 at 9:21 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    $980 is way too much for the install. Just scrap the whole idea, sell me the charger and let me deal with installing it.
  6. Mar 9, 2014 at 10:42 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Got it installed, did it myself. Not as bad as I thought, although I do have a couple of questions...
    Does anyone know what to do with the passenger side VSV valve? Do I out the old one back on or keep it removed? Secondly the Boost port should be connected to the fuel rail? Having it flashed tomorrow. Hope to find out by then.
  7. Mar 9, 2014 at 11:05 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I can't remember on the VSV. However, the boost port shouldn't be connected to anything. Unless you have a boost gauge installed anyway. Or unless you are doing the FPR mod which you shouldn't be at this stage of the game.
  8. Mar 9, 2014 at 11:35 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Thanks, better pull that hose.
  9. Mar 10, 2014 at 6:26 AM
    spithead051
    Patrick
    Fairfax, VA
    The VSV gets unbolted from the stock intake manifold, bolted to the bottom of the oil filler neck, and run the lines as described in steps 21B, 12C.
  10. Mar 10, 2014 at 9:10 AM
    2wheelnut
    Angelo
    Vallejo, CA
    I understood that part. That was the driver side vsv. Now the passenger side connector for its vsv just dangles there. Also should I cap off the boost port somehow? At the dealer now getting the reflash. Gotta button it up after to make sure it's all right
  11. Mar 10, 2014 at 9:57 AM
    2wheelnut
    Angelo
    Vallejo, CA
    Back at the dealer after the reflash, trac and CEL came on. They're reading the codes right now but I'm betting they won't know what's going on - suggestions?
  12. Mar 10, 2014 at 9:57 AM
    memario1214
    Colton
    Missoula, MT
    Yes, that boost port should have had a pink cap on it. It should still be on there. If not, find a way to cap it off. Tell us what the codes are
  13. Mar 10, 2014 at 10:14 AM
    2wheelnut
    Angelo
    Vallejo, CA
    Dealer said lean codes. Wouldn't say much more when I pressed them.
  14. Mar 10, 2014 at 10:14 AM
    2wheelnut
    Angelo
    Vallejo, CA
    It never came with a pink cap but I will plug it up asap
  15. Mar 10, 2014 at 10:17 AM
    2wheelnut
    Angelo
    Vallejo, CA
    The only other hose that's dangling now leads to the fuel rail. Right beside it is the connector to the old vsv valve. Where does the fuel rail hose go?
  16. Mar 10, 2014 at 10:37 AM
    memario1214
    Colton
    Missoula, MT
    They should tell you exactly what the codes are. There's no magic information there that only they know about. If you have hoses going to the fuel rail though that would certainly be a cause for concern when it comes to leaning out.
    If you bought it new it should have. See pink cap in pic below.
    Reference this for install help... I'm not at my truck and unfortunately can't diagnose all of the hose locations from memory
    http://www.tacomaworld.com/forum/technical-chat/101770-how-1gr-fe-supercharger-installation.html
  17. Mar 10, 2014 at 10:40 AM
    2wheelnut
    Angelo
    Vallejo, CA
    Yeah mine didn't have the cap. I've looked over the write up twice trying to figure out the connector. The instructions and the write up don't mention it either. I'm going to have play around and see what's going on
  18. Mar 10, 2014 at 11:24 AM
    2wheelnut
    Angelo
    Vallejo, CA
    These are the parts I'm asking about
  19. Mar 10, 2014 at 12:27 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Connects to this connector
  20. Mar 10, 2014 at 9:23 PM
    TRON
    Yes there are two electrical connectors that don't connect to anything. As you can see in the pic; I taped them up so they wouldn't flap around. The hose coming out of your fuel regulator should connect to your air intake passage. Pretty obvious with an aftermarket CAI. You can usually stop by an autozone or advanced autoparts; they can lend you a scan gauge and find out exactly what the codes are.
