TRD S/C help! Knwoledge needed
Discussion in 'Performance and Tuning' started by Skyv118, Apr 25, 2012.
  1. Apr 25, 2012 at 1:59 PM
    Skyv118
    Skyv118 [OP] Member
    Luis
    Shreveport,La
    2010 SR5 TACO TSS
    22s, SS grill, Carbon dash kit
    So I'm thinking bout buying a Used TRD supercharger and installing it myself. I have never done one before but a little mechanically inclined. Im buying a fit kit from my local dealership to fit my 2010 sr5. What do I need to do before installation and after regarding the dealership read something bout getting the OE calibration before installation and what after installation? Any guidance will help. Are there any links on how to install this bad boy?
  2. Apr 25, 2012 at 2:02 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    This scares me... It's not like bolting in a cold air intake... Dealer needs to flash your ecu before you turn the thing on... Good luck to ya
  3. Apr 25, 2012 at 5:25 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    there is a reason somebody went to all that work to remove the s/c??
  4. Apr 25, 2012 at 5:35 PM
    grant99
    grant99 Well-Known Member
    London, ON
    05 4DR TRD Sport 6SPD
    Do you have a big impact gun? If not I would consider getting a local mechanic to break the crank pulley bolt loose ($20 should get it done). I will be a buggar!! Other than that I did mine on the weekend, and made the appointment at the stealership for the reflash on the monday after. I drove there (don't boost it) they did the flash and everything was golden after that. There is an great install thread on here that does very well to accompany the install instructions what come with the SC
  5. Apr 25, 2012 at 7:26 PM
    Skyv118
    Skyv118 [OP] Member
    Luis
    Shreveport,La
    2010 SR5 TACO TSS
    Well there is every tool you could possibly tink of at my job, also a shop I can do it at on the weekend. THANKS everybody for the info
  6. Apr 25, 2012 at 8:01 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    No, you can run the truck with the charger on it and no reflash... You're just likely in trouble if you get into too much boost. You could just putz along to get to the dealer.
  7. May 3, 2012 at 6:23 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
