TRD S/C Maintenance How-To
Discussion in 'Performance and Tuning' started by SManZ, Jun 1, 2014.
  1. May 19, 2021 at 2:07 PM
    #121
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    With new rotor blades the cost was going to be closer to $2300. Plus you have to provide shipping both ways. Plus taxes. So that's closer to $3k when all said and done. You can buy a brand new one for $1500 more
    Norton likes this.
  2. May 19, 2021 at 2:12 PM
    #122
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
  3. May 19, 2021 at 2:20 PM
    #123
    1997tacomav6
    Denver
    Depending on what is involved and included.
    I think they change 400 ? just for rebuilt rotors if u need them and u will not know till its opened up
  4. May 19, 2021 at 2:22 PM
    #124
    australian hilux
    Justin
    None at this point
    I’m assuming there is no other mods they can do to increase psi?
  5. May 19, 2021 at 2:23 PM
    #125
    1997tacomav6
    Denver
    The 1st gen grey unit can be ported, another 400.
    Later one piece casting can not
  6. May 19, 2021 at 2:27 PM
    #126
    australian hilux
    Justin
    None at this point
    Bummer. Thanks
  7. May 19, 2021 at 7:17 PM
    #127
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Guess that depends on what actual quality bearings they replace them with.
  8. May 21, 2021 at 3:40 PM
    #128
    scootter82
    Aurora, CO
    what happened to all the pictures on the front page?? I was going to remove the nose drive assembly just now and they're all gone....
  9. May 21, 2021 at 3:45 PM
    #129
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    scootter82[QUOTED] likes this.
  10. May 21, 2021 at 3:47 PM
    #130
    scootter82
    Aurora, CO
  11. May 21, 2021 at 3:49 PM
    #131
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    it might need some persuasion
  12. May 21, 2021 at 4:08 PM
    #132
    scootter82
    Aurora, CO
    just got it off. i was missing the super long bolt underneath. Then a flat head turned sideways in the gap at the top helped to pry it enough to get it off.
  13. May 21, 2021 at 4:17 PM
    #133
    scootter82
    Aurora, CO
    TheNatural likes this.
  14. May 21, 2021 at 5:33 PM
    #134
    scootter82
    Aurora, CO
    my coupler also looked just like the one on the front page, with the spring blown out a little on one side.
  15. May 21, 2021 at 6:01 PM
    #135
    TRON
    It’s got permatex liquid sealant on the perimeter you got to break free. And don’t forget about the one nut. All the others are bolts. It’s a piece of cake.
  16. May 31, 2021 at 12:04 PM
    #136
    atompson
    atompson Well-Known Member
    Andrew
    Dallas, TX
    Tompson
    None.
    Just completed the belt change. Taking off the shroud and fan definitely gives more space. The hardest thing was getting the 12mm bolt back in the tensioner bracket. I spent about an hour trying to do it from above. Then I finally took off the driver's side front tire, pulled out the rubber flap and the bracket is right there. Bolt went in with no problem.
    I also did the accessory belt since it's 90% the same job and I had it on hand.
  17. Oct 26, 2021 at 3:20 PM
    #137
    happyabortion
    happyabortion Well-Known Member
    brian
    port arthur TX
    99 tacoma prerunner
    I only got maybe 4oz out of mines and I wasn't able to put more than 4oz without it spilling back out. Anyone experience something similar?
  18. Oct 26, 2021 at 4:11 PM
    #138
    TRON
    The best way to change the SC oil is to take the blower off the engine and fill it with the access plug facing up. You can get more oil in that way.
    zerotimeouts likes this.
  19. Nov 24, 2021 at 6:16 PM
    #139
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Anyone know where to find the torque values for the nose assembly? Also is lock tight or anti seize recommend?
    @12TRDTacoma
    :oops:
  20. Nov 24, 2021 at 6:50 PM
    #140
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm the wrong guy to ask about torque values because I will always tell you that torque spec is gutten tight unless it involves engine/ transmission internals. I recommend neither Loctite or antiseize.
