TRD S/C Maintenance How-To
Discussion in 'Performance and Tuning' started by SManZ, Jun 1, 2014.
  1. Nov 24, 2021 at 6:53 PM
    #141
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Haha, thank you anyhow.
    I was thinking start with 20nm
  2. Nov 24, 2021 at 7:40 PM
    #142
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Make it 15 foot lbs. Once it stops turning give it a turn 1/4 to 3/8 torque past.
    Sterling_vH111 likes this.
  3. Nov 24, 2021 at 10:52 PM
    #143
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just be careful @Sterling_vH111. After all, the entire blower is aluminum, and soft aluminum at that. If you torque too hard you could pull threads, or worse, even crack the nose assembly housing and that's the last thing want.
    To put into perspective what I am talking about I did an oil pan install on an LS2 once. Torque spec called for 10 or ft lbs. Of torque for each bolt on the pan in a sequence, which I did to a T because I DID NOT want leakage as the cast all aluminum pan was stupid to get to. Upon completing the install with just 2 or 3 bolts left, I was tightening one and heard a nice crack sound out of that section of the oil pan. Luckily it was on the edge, where I was generous with the silicone and the bolt was already on, so I stopped and moved on, it never did leak, but my point is that NEVER should had happened, especially because I was following FSM tq spec.
    The reasons above and the inherent industry- wide switch to aluminum engine blocks and accessories is the reason why I don't trust that torque spec bullshit.
  4. Nov 24, 2021 at 11:19 PM
    #144
    Sterling_vH111
    Sterling
    socal
    Fair point — I always feel uncomfortable without a torque spec, for the exact same reason you don’t like to follow them lol
    I’ve accidentally stripped stuff by overtaking them, but never when I follow the torque spec.
    I left them a 15 foot pounds, as thats what I felt they were close to when I took the bolts out.
    Ty for the help!
    I am stoked to get this supercharger & a few other go-fast-parts on my truck! It’s been pretty much all stock oem in this aspect for its life!
    12TRDTacoma[QUOTED] likes this.
  5. Nov 24, 2021 at 11:28 PM
    #145
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good stuff. I'm glad it worked out for you.
    Torque spec for me is okay on steel to steel applications like wheels and lug nuts, and the other sections I mentioned above, where YOU KNOW they won't skimp out on the build quality and material surface area. It's almost impossible to break a wheel unless they are that cheap. I'll leave the FSM spec values for the rookies (Who I theorize the values were targeted for, specifically the day 1 guys at dealerships not to point any fingers). :D
  6. Nov 25, 2021 at 5:36 AM
    #146
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Wish some one would just make a stud kit instead of these bolts.
  7. Nov 25, 2021 at 9:34 AM
    #147
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    The valve cover bolts snap pretty easily also. Luckily I was able to remove mine cfrom below after the top snapped.
  8. Nov 25, 2021 at 10:25 AM
    #148
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    the bolts holding down the fuel rail are easy to snap to if going to Torque spec. broke one when swapping everything from one motor to another.
