TRD S/C + URD 7th Injector = ??AFR??
Discussion in 'Performance and Tuning' started by kckrawford, Mar 22, 2014.
  1. Jun 26, 2014 at 7:12 AM
    #121
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I put the cat on when I rebuilt my injectors and went back to the 2.2" pulley so I changed a lot. It was mainly due to the sensor not reading gas flow correctly though.
  2. Jun 26, 2014 at 7:41 AM
    #122
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You will probably have to retune everything. Current tune is probably from bad readings from your AFR sensor. Also clear your ECU so it can relearn with a proper AFR reading.
    Just be aware, some 5VZ's just ping and theres not much you can do about it. Try some seafoam into the engine to clean out any carbon build up.
  3. Jul 1, 2014 at 11:36 AM
    #123
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    My ping is still not completely gone :(. I will try to tune it out some more. What kind of numbers do you guys have in your timing map cells in the areas it pings?
  4. Jul 1, 2014 at 12:46 PM
    #124
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I don't have R4 numbers, but I'm pulling over 6 degrees in some regions on the 91 octane map. At that amount, IMO it becomes questionable if the piggy is even retarding it that much effectively- but I can feel a loss in power- like I mentioned before, my 5vz is very VERY pingy in high load/low RPM regions, to the point that to tune out the ping, it feels pretty ball-less in that region. After I get out of that load region, she wakes up.
    Any of you guys hit a really nice power bump after 3K RMP? Seems like around 3.3-3.5K my truck drops another sack and gets a huge boost in power when WOT/boosting. Air fuels stay essentially the same, I haven't logged OE timing numbers in that region yet. Feels like a big VE increase happens, or the OE ECU gets to advance timing and goes hog wild in that area.
  5. Jul 2, 2014 at 5:39 AM
    #125
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Mine sounds like it runs about the same as yours. Ping down low, but when I get past that it hits hard around 3.3k or so.
  6. Jul 2, 2014 at 6:04 AM
    #126
    kigmob
    James
    New Orleans
    The numbers sound about the same. In my areas of ping on the timing map, I had like 3.5-3.8 degrees. This was after I tuned it for the first time and slightly increased the numbers. I went ahead last night and bumped it up to 4.5 in the ping areas. I'm gonna load in this new map and see what happens. In Gadgets u tune guide, he shows a screenshot of the timing map from an S runner he tuned which he claimed was the worst pinging 5vz ever. The highest number he added in the ping areas was 4.5 degrees...
  7. Jul 8, 2014 at 11:14 AM
    #127
    kigmob
    James
    New Orleans
    So I added 4.5-4.8 degrees only in the ping area 3-6 psi, 2000-2500 rpm and smoothed it out to the surrounding cells. Looks like my ping is gone!! :thumbsup:
  8. May 17, 2017 at 4:48 PM
    #128
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Anyone have the base map for the newer urd 7th injector kit they could send me?
