Trd Sc
Discussion in 'Performance and Tuning' started by danusa, Dec 28, 2007.
  1. Dec 28, 2007 at 6:47 AM
    danusa
    danusa [OP] Well-Known Member
    Once the SC is bolted on is a cai or other mods useful?
    If so, what?
  2. Dec 28, 2007 at 8:53 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You'll need fuel mods to control the pinging and lean out associated with the SC. Head on over to URDusa.com to check out what they have.
  3. Dec 28, 2007 at 2:54 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    I believe he has the 4.0l newer tacoma, you're thinking of the pingin issues with the older ones.
  4. Dec 30, 2007 at 5:06 AM
    danusa
    Yes it is the 4.0L 1GR.
    The kit comes with a colder Iridium plug and larger injector jets.
    I only need the power in the winter. I am thinking of leaving the stock jets.
    Would this be too lean if you used the gears for power?
    I don`t wish to burn a valve.
  5. Dec 30, 2007 at 7:24 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    Why would you not install the larger injectors that come in the kit? You should not leave the stock ones on if you put the SC on, it would likely cause you some problems.
