TRD sport suspension mod for on road performance
Discussion in 'Suspension' started by ToyotaTRD, Apr 26, 2012.
  1. Apr 26, 2012 at 6:29 PM
    ToyotaTRD
    ToyotaTRD [OP] Well-Known Member
    TRD Sport
    It seems like all they have is lift kits for Tacoma. What about suspension mods for a 4wd TRD Sport that wants to stay a sport? I'm talking about sway bars, shocks springs, poly bushings, whatever. I can't find anything for some reason. Am I on the wrong forum all together?
  2. Apr 26, 2012 at 6:34 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can add a rear sway bar to help with the corners. I know you said you don't want to lift but Eibach coils are a great addition for the front. They're a stiffer coil and only lift you 1.5". They hardly roll at all in corners and virtually eliminate brake dive.
    Bilstein 5100's can be used with stock coils and really do help smooth out the ride. They also seem to be firmer than stock billies for a better on road ride.
    Other than that, you can attack braking upgrades with stainless steel brake lines and better pads.
    Lastly, supercharge :D
  3. Apr 26, 2012 at 6:36 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
  4. Apr 26, 2012 at 7:07 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    ToyotaTRD,
    Both Helwig and Addco make a rear anti-sway bar for Tacoma. Addco is cheaper ($125), Helwig ($240). Bilstein 4600 shocks may be what you are looking for. They are not the same as your TRD/Bilsteins.
    If you have not done the Rear Spring TSB, consider it. It will add a extra leaf to your rear springs and stiffen your suspension. One thing that I considered doing was using front coils taken from a V6 Double Cab on my Regular cab. I have not decided the value of this as yet for my application.
    Poly Bushings are available. I will look and find who has them.
    I do not know what tires you have on your Sport, but Dunlops came on my Regular cab and I trashed them before they got me killed. I installed Michelin LTX M/S2s. There was a tremendous difference in handling.
  5. Apr 26, 2012 at 7:13 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Not sure how accurate that is
  6. Apr 26, 2012 at 7:35 PM
    wolftree
    Rick
    Ohio
    OZ-T,
    I agree with you. I am trying to build the truck that Toyota was supposed to have built for hauling and as a road worthy daily driver. I live on a back road that only is accesible by 4X4, 4 months of the year. We find cars in the ditch when the snow melts in spring.
  7. Apr 27, 2012 at 2:33 PM
    ToyotaTRD
    TRD Sport
    Thanks for the info guys. I like the idea of poly bushings and rear sway bar. I'm still looking into the TSB for the rear springs. My last truck was a 2007 double cab trd sport and it could easily pull 20 bags of top soil that weigh 40 pounds each. Ive done that several times. That's 800 pounds and I have had a half yard of stone in the bed once and that weighs over 1000 pounds. It was not on the bump stops. I'm not sure why I'm reading about guys towing 400-500 pounds and resting on the bump stops. I thought these trucks cargo capacity was over 1000.
  8. Apr 27, 2012 at 2:42 PM
    Pugga
    Massachusetts
    I have a 2007 and replaced the suspension twice. Once was the TSB, the second time I replaced the leaf pack and used an AAL because the stock springs were junk. I couldn't haul a 400 lb bike without hitting the bump stops at every bump. Maybe you got lucky but I'm not a fan of the stock suspension.
    If you want, you can get a custom leaf pack to stiffen up the rear and put you at whatever ride height you wish.
  9. Apr 27, 2012 at 3:06 PM
    Pugga
    Massachusetts
  10. Apr 27, 2012 at 3:52 PM
    Pugga
    Massachusetts
    No, the lifts that go spring under to spring over usually have a replacement leaf pack. Spring under with the soft leaf packs that we have has got to put you on the bump stops very frequently!
  11. May 23, 2012 at 2:53 AM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    Do the 5100's lift the truck, or can you keep it's stock height? I'm always looking for better road handling. What about the Bilstein HD? I also want to replace the leaf springs for 4-leaf similar to Toyota TSB, but aftermarket. I don't want to lower it, though!
  12. May 23, 2012 at 3:01 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    im using 4x4 leafs in a spring under configuration. i have no problems.
    the concerns i have with that kit do not lie with the inverted leafs; just the rear shackle flip is sketch as fk. do not like
    and the front setup, which is pretty much an non-adjustable coilover sleeve, will only compress the strut, and not really help with handling. the ride will probably stiffen due to the compressed strut but that does not equal better handling per say.
    my two cents.
  13. May 23, 2012 at 5:16 AM
    Pugga
    Massachusetts
    The 5100's have 4 settings, 0 or stock, .85, 1.75 and 2.5" of lift so yes, you can use 5100's at stay at stock height. Bilstein HDs seem to have a good reputation also, they will keep you at stock height and do not have the ride height options that the 5100's have.
    For aftermarket leaf springs that keep you at stock height, check out companies like Alcan. They can make you a custom leaf pack at whatever ride height you choose and can beef them up to hold more weight if you choose. They're a little pricey though.
  14. Jun 12, 2012 at 12:32 AM
    sonocotaco
    ken
    Rohnert Park
    Thanks a bunch. I'll check out those Bilstein HD's.
