TRD Supercharged 2011 SR5 Street built
Discussion in '2nd Gen. Builds (2005-2015)' started by Athlaos, May 14, 2018.
  1. May 14, 2018 at 6:03 AM
    Athlaos
    Athlaos [OP] Cthulhu is my co-pilot
    Leigh
    Edmonton
    TRD SC 2011 SR5 Manual
    Stuff you probably shouldn't try at home. Check build.
    Truck: 2011 Toyota Tacoma 4x4 SR5 manual transmission with 1GR-FE
    Color: Silver
    Engine/Fuel:
    TRD Supercharger (Power/torque at wheels: 350hp/430ftlbs)
    1.87" custom supercharger pulley (16psi boost) by Smoothflow Pulleys and 69.0" belt, belt re-route to maximize drive pulley belt wrap ("noose mod")
    Performance camshafts by Kelford Cams
    UCON-EMS by URD
    7th Injector by URD
    URD TCAI with URD air filter
    Upgraded supercharger reservoir tank (by @mightytacoman)
    Custom fuel cooler
    Snow performance water/methanol injection - two separate systems - stage 1 @ 225ml/min (nozzle #3) and stage 2 @ 675ml/min (one #2 nozzle at 175ml/min and one AEM v3 nozzle at 500ml/min)
    Bed mounted water/methanol reserve tank with transfer pump
    Walbro 255lph fuel pump upgrade (kit by URD)
    76mm Tundra throttle body (adapter by URD)
    Solid Offroad motor and transmission mounts (great upgrade - talk to @Bonzen for those)
    Moroso oil accumulator with Canton solenoid valve - manual switch activated
    Exhaust:
    URD spec-U equal-length headers
    Custom straight-through axle dump exhaust with Magnaflow muffler and two Vibrant silencers
    URD Y-pipe
    Synapse Engineering NoDrone Resonator
    Cooling:
    Throttle body coolant shut-off ball valve
    Intercooler capacity upgrade (2nd pump and 2nd radiator)
    4-Core radiator by Champion cooling systems; shroud by Ledfoot Racing, Spal electric fan
    Radiator integrated oil cooler - Mocal thermostatic sandwich adapter with braided steel lines
    NST lightweight water pump pulley
    Powertrain:
    URD stage 3+ clutch
    Ultra light weight steel flywheel from URD
    Eaton Detroit TruTrac rear LSD carrier
    URD hydro bearing kit and clutch accumulator delete
    Suspension:
    Front and rear Addco sway bars
    Front "franken-strut" stiffening/leveling kit with sawed-off OME springs and Bilstein 5100
    Hellwig rear spring helpers
    Wheels:
    20x9 +30 offset
    275/55/20
    305/50/20 rear (summer only)
    2" spacers (rear only)
    Lights:
    OSRAM Super Bright Premium High Wattage Headlight Bulb H4 (Single)
    Corner light to fog light hack (fog lights turn on with first stage of headlights)
    Upgraded high-wattage front turn signal bulbs
    Entertainment System:
    Alpine head unit with iPod connectivity
    JL Audio door speaker replacements
    JL Audio HD900/5
    JL Audio custom moulded fibreglass box, behind passenger side rear seat
    Alpine SWT-10S4 truck subwoofer (HIGHLY RECOMMENDED)
    2 Farad capacitor
    Interior:
    URD short shifter combined with Hurst short shifter
    Custom billet titanium shift knob
    Fake Nardi steering wheel with spacer and NRG hub
    Console cupholder delete and added switch panel
    G37 Coupe heated front seats
    Other:
    High output alternator by Singer Alternators
    Energizer AGM battery
    Pedal Commander
    Custom cruise control switch relocation
    Boost gauge
    Dual AFR gauges
    Oil pressure gauge
    Fuel pressure gauge
    Water temperature gauge
    Air intake temperature gauge
    Would like to thank the following members for helping me out with various aspects of this project:
    @12TRDTacoma
    @Roostfactor
    @White lightning boosted
    @BassAckwards
    @Bonzen
    @Speedwaytacotuesday
    @mightytacoman
    @TodayWasTHeDaY
    @Torspd
  2. May 22, 2018 at 11:09 AM
    BassAckwards
    Robert
    2013 6spd AWD Tacoma
  3. May 22, 2018 at 12:20 PM
    BassAckwards
    Robert
    How do you like this combo? I just ordered the same pair for my 6spd, and I'm curious how the lightweight flywheel is
    Do you have any chirping from the TOB after doing this? I was going to upgrade to this as well, but they were out of stock, so I went with the sleeve & larger TOB for the time being..
    Are you running the same diameter tires, just a wider one? I'm guessing yes since youre a 4wd
    Curious how you combined these? I'm thinking about going with a TRD SS after reading about the URD ones breaking the ball off over time
    Got any pics of your gauges and how you mounted them? also why the dual AFRs? and where did you mount your sensors in the exhaust piping? I've read that its best to mount them before the front Cats
    Sorry for all the questions.. Just so much good stuff going on in here.. :popcorn:
    Loving your build! Definitely taking some inspiration from yours for mine :thumbsup:
    SnozzCumber and hoverlover like this.
  4. May 22, 2018 at 12:31 PM
    Athlaos
    Leigh
    Edmonton
    Your text included with answers below each....
    I like it a lot, this is actually the second 3+ clutch and they've improved it since the first one I had. It is a lot more driveable. It's heavy - but not bad. The flywheel is very light, I think it was around half the weight of stock or less, but it's still very driveable.
    Yes, I have an intermittent sort of quiet "flutter" noise. It will come for a few days then be gone for a few days. It's only when the clutch pedal is down. With the kit, URD supplies an adapter that is held onto the clutch pressure plate with a clip, my theory is there's a little bit of play in the adapter and it's squeaking when it slowly rotates to a certain position. The clutch functions fine, and I'm not worried about mechanical failure. I would have to remove the transmission to fix it, which is an outstandingly painful job, so I'll live with it.
    That's correct, the tires in the rear are lower aspect ratio to make them pretty close to the same diameter as the fronts (like within 0.2").
    EDIT - the URD ball did break my shaft before I combined it with Hurst. I believe Hurst uses better metal for their shifter than Toyota did. I'm not worried about it. I've had them working together for a couple of years now.
    I did have to grind out metal using a dremel from the two little half-moon spacers that come with the URD kit in order to fit their shifter ball onto the Hurst shaft. I actually made it so it is a press fit - I banged the URD ball onto the Hurst ball with a hammer. It's not coming off. I don't need to use the URD set screw because it's pressed on. Sorry I don't have any pictures of this install.
    I will take a picture this afternoon of the interior, I need some new ones for this thread.
    EDIT - Dual AFRs, one on each bank, so I can more easily diagnose where a fuel problem is coming from, if it ever happens. I don't have cats, but I believe you're correct on putting them before cats if you have them. Mine are at the end of the headers.
    Thanks man, ask questions any time, I love talking about it.
    That's all I really hope for.
  5. May 22, 2018 at 12:33 PM
    BassAckwards
    Robert
    Thanks for the info! Just what i was looking for:hattip:
    SnozzCumber likes this.
  6. May 22, 2018 at 12:38 PM
    Athlaos
    Leigh
    Edmonton
    @rjbiii I made a couple of edits, noticed I hadn't answered a couple of your questions the first time....
    SnozzCumber and BassAckwards like this.
  7. May 22, 2018 at 12:42 PM
    BassAckwards
    Robert
    :fistbump:
  8. May 22, 2018 at 12:43 PM
    dingram1485
    dingram1485 Well-Known Member
    Dylan
    Youngstown Ohio
    2012 SR5 4x4
    Sweet !!
  9. May 22, 2018 at 5:22 PM
    Athlaos
    Leigh
    Edmonton
    @rjbiii Here are some pictures of the interior/gauges:
  10. May 22, 2018 at 8:04 PM
    BassAckwards
    Robert
    Awesome looking interior! Whats the little red switch for at the front of you cup holder?
  11. May 22, 2018 at 8:08 PM
    Athlaos
    Leigh
    Edmonton
    That activates the tail pipe injectors. It causes an enormous flame to shoot out the tail pipe.
    Just kidding. It's for my ejector seat.
    Just kidding again. It's actually for my water/meth injection. I wanted a switch to deactivate the system at will rather than have it linked to the ignition. Here it can get mind-blowingly cold in winter, and there'd be no point in having it on while driving.
  12. May 22, 2018 at 8:25 PM
    BassAckwards
    Robert
    :laugh:
    Athlaos [OP] likes this.
  13. May 23, 2018 at 8:30 AM
    Athlaos
    Leigh
    Edmonton
    @rjbiii not meaning to become your stalker or anything, but I followed you on instagram.... I'm posting my car and truck projects on there all the time. @ra60f if you're interested
  14. May 23, 2018 at 8:32 AM
    BassAckwards
    Robert
    lol its all good, I will follow you as well, but just a fair warning my IG game is weak.. I rarely post on there.. mostly stick to TW
  15. May 23, 2018 at 9:21 AM
    Athlaos
    Leigh
    Edmonton
    @rjbiii I totally forgot to mention this. The stage 3+ clutch with the hydro bearing is really, really painful to drive while it's breaking in. It has this super pop thing going on that's hard to control. So if you feel that, don't fret, there's nothing wrong. It'll go away after 500km or so. Then it settles to an excellent point.
  16. May 23, 2018 at 9:22 AM
    Athlaos
    Leigh
    Edmonton
    @rjbiii oh, and you might need to re-adjust the pedal after break in.
    hoverlover and BassAckwards like this.
  17. May 23, 2018 at 9:24 AM
    BassAckwards
    Robert
    Thanks for the heads up! Is it the herky jerky whenever its just about to engage?
  18. May 23, 2018 at 9:26 AM
    Athlaos
    Leigh
    Edmonton
    Kind of, yeah. It's like 'ahh so soft and nice' BAM launches your foot into orbit then engages and causes an embarrassing stall.
  19. May 23, 2018 at 9:27 AM
    BassAckwards
    Robert
    Haha oh boy.. looking forward to the break in:D
    Skootter14 and hoverlover like this.
  20. May 23, 2018 at 9:29 AM
    Athlaos
    Leigh
    Edmonton
    Oh, and another thing... the clutch does chatter off the line. It's not terrible, one learns how to drive it so that doesn't happen. It's part of racetruck life.
